Go to the makers web site and downloads area. there should be options to look for your spacific printer and download to your PC the latest drivers and software. Make a folder ready to download to, and after the download, unzipp the contents back to that folder. Run either the install .exe file from the software you have downloaded or run the printer wizzard in add printers, then chose the option to browse to the folder containing the downloaded software and drivers for your printer.
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a...
(More)
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a very old printer ?
Thanks
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not...
(More)
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not necessary)for my home that at least does decent photos for my personal use. Any suggestions?
HP4180 all-in-one gear slipping problem. We've had this machine for about 1 year and have run no...
(More)
HP4180 all-in-one gear slipping problem. We've had this machine for about 1 year and have run no more than 50 copies through it. Under the glass there is a mechanism that moves along a strip with gear teeth. On the underside of the moving mechanism there is an electric motor with a black worm gear on the shaft. The worm gear runs a larger, white gear that in turn moves the mechanism along the geared strip. My problem is that the larger white gear and the worm gear don't align perfectly and now the teeth on the larger white gear are worn concave on about 20% of the circumference of the gear. Where can I get a new gear? I spaced the larger gear up with a thin washer so the worm gear would ride on a small portion of non-worn teeth and it works now but its only a matter of time before it slips again. Can anyone tell me what this moving mechanism is called that goes from side to side under the glass. The worn gear is housed in the underside of this mechanism. Looks like avery poor design as there is no way to adjust or align the gears. Thanks.
my printer is a canon ink jet its about 2years old but i use it a lot for work at home printer say...
(More)
my printer is a canon ink jet its about 2years old but i use it a lot for work at home printer say it's jammed but i looked with a falsh ligth .i was haveing issue printing somer work last nigth butit worked
