Question about KitchenAid 32 in. KECC508 Electric Cooktop
What electric voltage plug do I use for KitchenAid 32" cooktop
What voltage plug is needed
    Scholar:
  • 60 Answers
I would use the 220volt 60amp available at any hardware store. Just make sure you check the wall outlet you are going to use. The Dryer and Range are not the same.
Posted on Nov 07, 2008
The stove top of my electric KitchenAid Superba is locked. How do I unlock it?
keep your finger on the unlock button for about 10 sec.
please rate this response, with the thumbs up selection
Dec 19, 2010 | KitchenAid 32 in. KECC508 Electric Cooktop
Clipped and now cracking ceramic cooktop
Sorry to read about your problem, I hope this helps you out.
you may want to think about a new unit, the glass replacement will cost from $600.00 to $900.000
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 18, 2010 | KitchenAid 32 in. KECC508 Electric Cooktop
Electric igniter does not work every time
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 03, 2010 | KitchenAid 32 in. KECC508 Electric Cooktop
Kitchenaid KECC502 Electric Cooktop: LED light at the left rear knob is always on but the left rear burner single or dual does not work. I tried to turn knob on and off but nothing enable burner.
I wish I had the exact answer, because I have the same exact problem!!! You posted this about a month ago, which is when my unit started having LED "on" problems. Just in the past week, the top left power on LED will not go off, and nothing I can do gets the dual large burner to come on. Any thoughts??? Reply to: mchunko@csonka.com
Mar 25, 2010 | KitchenAid 32 in. KECC502 Electric Cooktop
One of the burners on my kitchenaid cooktop will not heat up. What do you think the problem is? Is this something that can be easily repaired?
If it is not a glass top stove, with the power OFF, and cold, pull out a working element of the same diameter and install it where the non-working element was. Try it now. If it works, replace the heating element. If it does not, check for voltage at the element connector. CAREFULLY. Worst case is that the switch requires replacing.
Dec 17, 2009 | KitchenAid 32 in. KECD805 Electric Cooktop
Burnt on stains on the inside glass door of my kitchenaid oven
DeBruce Polish should remove those types of problems and also render the surface more "Cleanable". This stuff really works on glass anomalies.
Check out debrucepolish.com.
DEBRUCE METHOD on You Tube
Apr 11, 2009 | KitchenAid 32 in. KECC508 Electric Cooktop
I need tips on cleaning my kitchen aid ceramic eletric cooktop.
Use DeBruce Polish. debrucepolish.com. a "True Multi-Surface Cleaner. I guarantee it!!
Oct 12, 2008 | KitchenAid 32 in. KECC508 Electric Cooktop
Our cooktop will not turn on!!
Plug the power line press the reset button.
Jan 03, 2008 | KitchenAid 32 in. KECC508 Electric Cooktop
KitchenAid 32 in. KECC508 Electric Cooktop Logo
381 people viewed this question
Top KitchenAid Cooktops Experts
vince
Dale Copeland
Dale Copeland
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
