Question about Toshiba CF36H40 TV
Toshiba CF36H40 no verticial output
Has anyone else had a vertical output problem, with a solid blue line across the tube? I replaced the Vertical Deflection Driver "TA8427K" and this didn't correct the problem; I have no Vcc on pin 7, could this be a cap problem? the diodes all check out. I would be very appreciative for any advice Thank you Larry Verticial output problem,Blue line across screen.
    President:
  • 1,952 Answers
You should have around 28 volts DC on pin 6. If not, I believe that there is a fuse (F301) which probably blew when the IC went south.
the vcc supply voltage is derived from a pin off the flyback. you probably have a protect resistor open off the flyback supplying it. look for a low ohms resistor(1 to 10 ohms).
Posted on Nov 03, 2008
  • mohammed marika thambi
    mohammed marika thambi Nov 03, 2008
    , I would first check to be sure that all of the connectors and cables
    inside the set are in tightly. Remove them and re-insert all of them.
    Next, we need to start looking at module replacement.
    Brigadier General:
  • 6,966 Answers
To my knowledge, for a TA8427K, Vcc is on pin 6, +24VDC (in some models) with pin 1 grounded. Often, pin 6 gets its B+ from the FBT through a diode/resistor series and of course a filter capacitor. You may want to check the zener diode normally connected on the output (pin 2). In some instances, it could be an open resistor in series with the input (pin 4).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • 1 more comment
  • Louie  Role
    Louie Role Nov 03, 2008
    In some versions, there could also be a fuse (F301?) with the vertical B+ closer to +28VDC.
  • Louie  Role
    A remote possibility but worth checking, have you determined the continuity of the vertical yoke?
  • Louie  Role
    Louie Role Nov 08, 2008
    Hi again,
    Any development(s) so far?
  • 10,594 Answers
You need to check VCC on pin 6 of TA8427K
Pin 7 is output terminal and you will get voltage only when IC start function.
Also check vertical input signal at pin 4.
Below is picture of TV8427K pin configuration and this would help you.
White line in middle of screen on a cx32h60 toshiba tv
The vertical sweep output is absent. Check its vertical output section circuit for the fault. Check all the solder terminals of that section, and resolder them by applying a little more solder. Take special care to the solder terminals of the vertical output IC. If these do not help you, check and replace the vertical output IC.
Jul 07, 2012 | Toshiba CX32H60 TV
One line across only...
This is failure of the VERTICAL DRIVER IC/circuit in the monitor . So what is need is to check the voltage on the vertical IC to confirm if there is a power break from the output transformer. normally there is a fusible resisitor that feeds the verticial IC and could fail if the IC or the coils fail.
Check you PC using another monitor to confirm before this is taken apart to check.
Aug 09, 2011 | Computers & Internet
Thin horizontal line across screen
Hello
You haven't specifed nothing about the model number or brand name of your flat panel teleivison. i assumes that it to be a picture tube based one and posts this solution before you.
A thin horizontal line across the screen with sound output is OK, is the sympton of total failure of vertical sweep. This may be due to failure of vertical output IC or loose solder terminals of that IC. The vertical output IC will heat up while working, and repeated heating and cooling may make its solder terminals to get loose. Just open your TV, pull out the board that contains vertcial output section, turn it upside down, resolder all the solder terminals of that IC by applying a little more solder, without making any solder bridge in between terminals. Check the voltage to the vertical output IC also. If this resoldering method does not help you, replace the vertical IC itself with same type and number will solve your TVs problem. OK.
May 07, 2011 | Televison & Video
Several lines run across the top of the screen
Several lines acroos the screen at the top along with picture is a typical fault. You are seeing vertical retrace lines. Either the supply smoothing capacitor to the power supply given to vertical output Ic or vertical output capacitor connected to the vertical output pin of that Ic may faulty. Usually the supply smoothing capacitor seen faulty. It may be over 1500Mfd eletrolytic capacitor used there. It may get value reduced by 40 percent or so, this falult will occur. Please replace the two capacitors together and will get the result.
Oct 15, 2010 | Toshiba 27A34 27" TV
Television blank , but there is a white line across tube. I can hear audio
Your TV is in what is called "vertical collapse". About 70-80% of the time it is due simply to bad solder joints on the vertical output IC. You can verify this by tapping on the side or top of the TV, the picture may jump back into position. If it comes back it's as simple as re-soldering the vertical IC. If not, the vertical output IC may be shot or it may be missing one of it's supply voltages.
If the picture has been shrinking or had lines at the top that means there are some capacitors in the vertical circuit that were drying out. If it happened all of a sudden I'd bank on it being just bad solder.
Don't run it like that with that bright line for too long or it will burn in on the picture tube. Then if you do get it fixed you will see that line there all the time!
May 24, 2010 | Toshiba 27A33 27" TV
Horiznal line across screen
The picture tube itself is not longer being manufactured and the replacement might exceed the price of a new TV.
The vertical line you see on the picture tube is not a failure with the picture tube but a different part inside the circuitry.
Dec 07, 2008 | Toshiba CN35F95 35" TV
TV Toshiba CF32G50
I think you have a vertical problem. Turn up screen voltage to see if there is a tin horizontal line across screen. If so replace vertical output IC and the 100uf/35v capacitor in the vertical circuit.
Oct 31, 2008 | Toshiba CF32G50 32" TV
Mitsubishi cs 35203
That sounds like vertical failure. Does the blue line run across the screen from side to side? Try resoldering the vertical output IC and see if that straightens it out. This is sometimes been a problem with that chassis. Let me know how you make out or if you need additional help.
Mar 29, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Sanyo 25" Standard Tube Vertical Deflection Problem
you can proceed as follow to fix it.
  1. reduce brightness to minimum to avoid screen burn.
  2. check voltage on vertical uotput
  3. check yoke connector for loose.
  4. check v/yoke winding.
  5. check v/drive from signal processor to vertical output
now your problem how to find out whether drive is there or not it is very simple even you donot have scope.
you simply touch with screw driver or meter prob  at the poibt where vertical signal is input to vertical stage
if h/line is spreadindg or tries to spread then your output is ok &problem is in drive ckt.
for schematic try given site give model no &download it
http://www.eserviceinfo.com/index.php?what=search2
hope this will help
Oct 12, 2007 | Sanyo AVM-2557 TV
Mistubishi Diva Horizintal Strip Picture on Tube
Nope, the good news is that it is NOT a Tube problem! From your description, it looks more like a Cold solder in the Vertical Output stages (80% probability. Another possibility is dried out Electrolytic Capacitors in the same stages, or in the Power supply Line to the Vertical Output Stage. Nothing you can do, unless you know solid state electronics. Better get a good Technecian to have a look. he will locate the Cold solder quickly enough, and do a resolder.
May 12, 2007 | Mitsubishi CS-35505 35" TV
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
