Question about Dell Dimension 2400 PC Desktop
Dell 2400 PC- blinking amber light.
My Dell has a blinking amber light. Does this mean my power supply unit within the pc is going bad? If so, how can I fix it?
Thanks!
Sherri
  • Dell Master
  • 1,183 Answers
Hi Sherri,
The symptom that you are facing generally refers to bad power supply. The same can be resolved by replacing the same. You can call dell sales to procure a new power supply. However to troubleshoot and make sure if power supply has gone bad , use the link below
http://tinyurl.com/6ezjbp
Thanks
proton
Posted on Nov 03, 2008
Amber light blinking
Amber light blinking means your processor is working does it mostly when you reboot or running a program all it is used for is to show your computer is in a process working.
Oct 12, 2012 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 diagnostic led lights abc=off,d=amber, please help
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/advtshoo.htm#1105412
Since that isn't one of the listed codes, it is important to see what the POWER LED indicates.
If it is Flashing Amber, most likely a bad power supply
If power LED is solid amber, then either the motherboard, or a expansion card in the motherboard has failed. Remove any expansion cards, (Modem, sound or video card) try booting again.
If no Change then a motherboard
Jun 26, 2011 | Dell Dimension 2400 PC Desktop
POWER LIGHT BLINKS BUT PC never comes on. amber color
check your power supply. A flashing amber power button usually means its gone bad
Dec 09, 2010 | Dell Dimension 4700C PC Desktop
I have a dell dimension 2400 with a blinking amber light what do i do
The blinking amber light on the dimesion 2400 generally means that the power supply on the system has gone bad. Switch off the system and disconnect the power cord from the back of the system . Press and hold down the power button in the front for 10 seconds.
Reconnect the cable back and try powering on the system.
If the same ,fails you would have to take the system in for repairs
Thanks for using Fixya
Proton
Sep 03, 2010 | Dell Dimension 2400 PC Desktop
When I turn on my desktop the power button stays yellow and computer doesn't boot up.
A flashing Amber power button indicates a bad power supply. A solid amber means a motherboard failure or a failed component attached to the motherboard preventing post.
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Jun 14, 2010 | Dell Dimension 2400 PC Desktop
My dell dimension 2400 goes on standby automatically.
If the power LED on the Tower is blinking amber, then most likely the power supply in the tower is failing. Replace the power supply.
Dec 31, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Aug 11, 2009 | Dell Dimension 2400 PC Desktop
Blinking amber light with green 4 light
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
Jun 15, 2009 | Dell Dimension 9100 PC Desktop
Dell comp
To help you better , could you let me know , when the system goes into sleep mode, the power light in the front of the tower is it amber or blinking amber or is it of some other color.
If the power button is blinking amber , the power supply on the unit is going bad.
Thanks
Proton
Oct 29, 2008 | Dell Dimension 2400 PC Desktop
Blinking power light
Jul 15, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
1,284 people viewed this question
Alun Cox
