Question about Remote Starter with Keyless Entry
Remote won't work and parking lights blink
I just installed an RS1100 in a 2004 F150 Ford Pickup. I did include the 791 Transponder. When I plug either or both of the red wires into the box, my flashers blink and I can't the remote to reset or work. I've rechecked all the wiring and they are where they should be.
  • downrange Nov 30, 2008
    Same here...I have an '04 Ford SportTrac. I bought the T-harness and transponder. I placed the extra key into the transponder. Directions say key should be "tight." HOW? You can't bend the loop around the key as mine is wires coated in a hard covering that cracks if you were to try and bend it. Does the key have to be touching the loop or just rest inside. I put some double sided tape on the key to keep it from moving around. Can you have too much tape that the loop doesn't pick up the key's code?. I have a Red LED on the transponder module that is always lit (Should it be?) Where does the blue wire from the transponder box go? My red is hooked to a constant 12V and the ornage is ground.
    The starter module clicks and dash lights flash. OH, and what about this hood switch? It talks about resetting the module by undoing this wire...blah, blah...and stepping on the brake while pressing any key on the remote...yet the t-harness setup does not appear to need this hood switch installed. Love how they leave the details out of an instruction manual that is general enough for over 1000 makes and models of cars. Bulldog...can you get specific please!
  • mrham52060 Jan 16, 2009
    when i plug my remote start in it makes a clicking sound and my lights flash , nothing works
  • 34 Answers
The blue wire needs to go to -input then unit should work
Posted on Jan 09, 2009
  • wyciwug Nov 20, 2010
    What do you mean by blue wire needs to go to - input. The blue wire is the aux AMA - already.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Won,t come out of park
Not sure what coming out of park has to do with custom sub boxes? May be you can give us a clear ask?
Dec 14, 2014 | JVC Mtx Thunderform Custom Box For Ford...
2002 ford f150 won;t shift out of park, changed the interlock switch did not help!! HELP ME
try turn ignition key toward on but do not go to where the power on and try put it to neutral if that works , It might be the fuse for Backup lights
Jan 11, 2014 | 2004 Ford F150
1997 ford f150 no tail lights, all other lights work except rear parking lights
problem with a wiring plug in the loom somewhere at the back of the vehicle ,quicker to rewire the rear lights from the switch back
Dec 17, 2013 | 1997 Ford F150 Regular Cab
My viper 5701 transponder gives error code of five blinks even though it does the function
Five blinks of the parking lights during remote starter operation is an error code for the (+) brake shutdown. If your foot is not on the brake then, there is an issue with your brake switch or your parking lights and brake lights wires are making contact, possibly in one of the front or rear light housings. Corrosion maybe.
Mar 15, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have an o3 ford escape with an aftermarket autopage remote start system.when i try to use the remote start it flashes the parking lights and all the accesories fire up but will not ingauge the starter....
the issue is the securilock system I installed one in my 03. You need a spare coded key (one that starts the vehicle) and a Bulldog 791 kit. ths will store the spare key and tell the vehicle it is not being stolen. Its the only way unless you want to leave your key in the ignition. BTW, the Theft light is on when you engage the remote started w/o the key in the ignition, Been there.
Dec 27, 2009 | 2003 Ford Escape
I installed a remote car starter. I was wondering
use the 791 and wire it up for VATS, you will not use the loop at all
Dec 16, 2009 | 1997 Chevrolet Lumina
I have installed a bulldog security rs82p on a 2004 merc sable. The bypass module used was originally labeled as a model 20402,23402,27402,&29402. This is now the 791 the unit turns on but does NOT...
put your key in the ignition leave it in the off position, now press the remote starter, if it starts you need to adjust the key in the 791, or adjust the transponder loop around the key chamber
Oct 25, 2009 | Bulldog& Remote Alarm System With 1-wire...
My f150 is not starting the theft light stays on and blink fast when try starting
Have you tried a different key. It has a transponder key system and each key has a different frequency.
Jun 30, 2009 | 2002 Ford F150 Regular Cab
1990 f150 pickup driving lights,parking lights dash lights won't
either faulty light switch or blown bulbs, would check these first then start checking the wires
Jun 15, 2009 | 1990 Ford F150
Viper 791 XV Automatic Start Not Working
Viper Working installed in my 2000 Honda Civic. It's the 791 XV model I nite diagram
Nov 05, 2008 | Viper Security and Remote Start System...
Remote Starter with Keyless Entry Logo
912 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
