Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi ultravision 55 inch
Just put conversions in it but does not power up the red light in front stays on but nothing else
    Novelist:
    Champion:
  • 203 Answers
Check to make sure you reconnected the jumpers to connect the board that you removed. Also, check to make sure no resistors are burning. If still no pix, make sure you reconnected multi pin plug by digital convergence unit (DCU). Next, disconnect conv. plugs marked red, green and blue. This should allow power to come up if chip(s) are bad. Next, check pico fuses on board by jumper connectors or in power supply. If these are open look for solder bridges around conv. amps. Also, if any of these are open check all zener diodes beneath heat sinks where you installed conv. amps. Probably 27 v glass zeners shorted if solder bridges were created when changing chips. Good luck, sometimes you just get a bad I.C,Russmann.
Posted on Nov 05, 2008
My hitachi 55" ultravision hdtv has a green pear shaped color on the screen, only when it has a dark background, other than that no distortion, no blueing in the corner, no blurriness, nothing. What i
Damaged Optical light engine, this is not the only Hitachi with this problem the ones before the oval was red and was finally settled two years ago in a class action lawsuit.
Dec 15, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
Apr 25, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
When i turn the tv on the screen stays black and the light on the front lights up red on the Lamp button?
Lamp light lit, that means TV needs new lamp.
Replace lamp in TV as existing lamp is dead/ broken.
Thanks.
Dec 06, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
I have a spot in the middle of the screen that red shows up as almost black. It looks like the old problems when magnets were put on the old fashioned TV's It is a 50 inch Hitachi Ultravision. I replaced...
That is going to be a failure of the light engine itself. The part number for that is UX25302R. The part is not a user replaceable part due to the complexity to remove and reinstall the new one. Here is a link for the part and to purchase it as it runs 521 dollars. Please take a few moments to rate my answer. Thanks...
http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/UX25302R/New.aspx
Nov 16, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
50 inch Hitachi Ultravision LCD Rear Projection Television
Hitachi has had problems with their light engines. Very expensive. Contact Hitachi as they may give you consideration even if this is out of warranty.
Apr 15, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Jun 13, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
My 50" hitachi ultravision won't turn on
i got a 62VS69A model type hitachi tv.... and it was thunderin and lightning outside all day .... and i left it on ... and when i woke up ... it was off..... and when i went to turn it back on.... it blinks blue,, then the light below it blinks red.... and the light below that light blinks red .... and then the first blue one again ... and over and over again ... untill finally it juss stays red... i donno whats goin on with this tv... im assumin it was the bad weather outside that did it but im not sure..... can someone PLEASE help a brother out ? lol
Nov 16, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitatchi Ultravision LCD Widescreen acts like it doesn't want to power up
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 10, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 53UDX10B 53" Rear Projection Television Logo
112 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
