Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
Cobra 29 LTD classic LCD channel display replace
I`ve got a new cobra 29 LTD classic, I would really like to replace both the lcd channel display, and the meter light to a different color. Have quite a bit of backgroung in auto wiring repair. Is there any info on this procedure that you know of, or is it pretty straight forward.
I`d take it to a shop, but there`s none local, I`d have to ship, heard too many horror storys
  • dulak Nov 05, 2008
    Guess I`ll just leave it as is.But I appreciate the advise, and help. Do you still do this work, should I decide to send it out
    Take care of yourself, I`ll leave it as stock I think. Thanks for your help
  • 204 Answers
Hello, the channel display is kind of touchy, as far as getting to it and of course it is soldered to a small circuit board and there is a certain way it goes back in. There is about 9 legs on top and 9 on the bottom that need to be unsoldered and resoldered( carefully). You can buy them in red,green, and bue. The meter light is pretty straight forward. You have a hot and ground wire. I used to use colored LED lights in the meters, way cool. They are not hot, and they last almost forever. The LED's are fairly easy because if you hook it up backwards, it just won't do anything. Let me know if you feel comfortable doing the solder work, and take a look inside the bottom cover at the channel selector because it has to come out with the channel readout. I used to charge $25.00 just for that because it would take me an hour just for the ch. selector, and about 15 min. for the meter light. Let me know one way or the other,,, Mechanic
Posted on Nov 05, 2008
  • Mechanic688
    Mechanic688 Nov 05, 2008
    Hello, I had to close my store due to health problems, this last year I've been in and out of the hospital twice. The second time was for 2 weeks. I have been doing a little light work on radios here at home, for my regulars that would just not leave me alone. At one time I had a radio shop in Iowa sending radios to me for repair, thru a regular driver, and my shop was in northern Indiana. Aw well, the good ole days,,, Mechanic
I have a cobra 25 ltd my cb receive great talks great but my meter doesnt move what is the problem
Posted on Jan 31, 2010
You can change the channel display yourself, it's not that big of a deal. as long as you are comfortable taking your radio apart and doing some soldering. I did mine the other day in about 30 min.
Posted on Dec 08, 2008
  • cbradio Dec 08, 2008
    the only certian way about putting the display in is to make sure that the small dots on the display are facing down, indicating the Bottom.
    You can also easily change the SWR meter light with an LED. You can go to Radio Shack and buy you choice of colored LED and appropriate resistor A 5v 30ma LED needs a 270ohm resistor to be able to hook it up to 12v. You can look up an LED resistor calculator online.
Lx29 blue tut. Locked in 9/10 mode. How do I reset it?
PDF]EIi?tr,iitts - American Radio History
Nov 5, 1993 - 64 AUTOPATCH SELECTOR FOR RADIO AMATEURS ..... Memorymodes can store readings while ..... est way to do it is to base the circuit .... width (with increasing values of CB), .... Electronics Engineers' Book Club, Blue Ridge Summit, PA 17294- ...... lock onto the 19 -kHz pilot sub- ...... manually reset.using fgets to read one line at a time - Experts Exchange > Questions
Nov 11, 2008 - 1: 2: 3: 4: 5: 6: 7: 8: 9: 10: 11: 12: 13: 14: 15: 16: 17: 18: 19: 20: 21: 22: 23: ..... helium viceroy Audrey Isaac provision grammar cobra adrift died Liverpool .....wriggle do carbuncle firebug Elsinore Connally annotate anaconda could ..... pretend quadratic Euphrates RCA amuse CB
Cobra 29 LTD Classic CB Radio - YouTube? 5:42 20, 2013 - Uploaded by C B WorldIn this product review we look at the Cobra 29 LTD Classic CB radio and ... Just like in the manual. most channels are below 3. a few are not.Cobra 29 LTD Classic Troubleshooting - iFixit 29 LTD Classic is not transmitting or receiving. The Antenna is not tuned correctly; The Radio is not in CB mode; The Radio is on the wrong channel; The ...Marine Radios ' Cobra Electronics Corporation
Jan 07, 2016 | Cobra Radio Communications
How can I fix my cobra 29 nw ltd classic? Everything works but the channel does not display and all I hear is static.
Check TR22 which is a 2sc1957 transistor mounted on side of case near heatsink for driver and final, left rear with speaker cover removed. Make sure the legs are not contacting case. Then check resistors R115, R116, R117 for open circuit and C133 for continuity.
I figure that 2sc1957 transistor is shorting to case or failed. A 2sc2314 is a sub for this transistor.
Oct 01, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
My cb cobra 29 ltd problem is channel 1 is ok but channel 2 not receive
Did you have someone get on channel 2 to see??? Maybe channel 2 was quiet and channel one had better receive or noise.. You never know until you check it with another radio. That is NOT a common issue at all on those radios. Better off doing that test.
Dec 28, 2010 | Cobra 29 LTD CB Radio
Have Cobra 29 LTD Classic, no sound when hooked to antenna, no light or meter movement on the RF/SWR meter, DOES have power to radio and channel display, any tips to repair, or check for problem areas?
check the squelch by turning all the way both ways. check the external speaker socket. if it is the swicthing type it could be either bad conntact or dry joints. try an external speaker to see if that works. another thing is I believe it wont work if the microphone is not pluged in or connection fault there. Good luck.
Jul 25, 2010 | Cobra 29 LTD CB Radio
I have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Jun 14, 2009 | Cobra 29 LTD CB Radio
Hard to find Cobra 29 Part #LL-2253YG
there are a whole bunch of channel displays on ebay that will work with your radio.
Jan 08, 2009 | Cobra 29 LTD CB Radio
Cobra classic 29 ltd
Had fixed the same problem yesterday. My cobra worked when it wanted to, when it didn't it looked like you explained. I found out that on my cobra the blue wire on the mike connector was broken. When it disconnects, no sound. after soldering, everything works fine.
Dec 04, 2008 | Cobra 29 LTD CB Radio
29 help
hi, sounds like you have a problem with the SWR' S Probably too high. Tumbleweed01
Mar 12, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
1,910 people viewed this question
Top Cobra Radio Communications Experts
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
