Question about Canon PIXMA iP4200 InkJet Photo Printer
  • 421 Answers
Error also refers to the EEPROM for the printhead. I would reset the EEPROM and see if that helps.
Printer servcie manual here and it will show you how to do it:
Hope that helps
Posted on Nov 14, 2008
2008 impala no tach signal to pcm
DTC P0651: 5-Volt Reference 2 Circuit
You have a bad sensor or a short on the five ref. circuit .
The 5-volt reference 2 buss provides 5 volts to the following sensors:
The APP sensor 1
The crankshaft position (CKP) sensor
The throttle position (TP) sensor 1 and 2
The brake booster vacuum sensor
A bad sensor or short on the five volt ref. circuit will bring down the PCM and you will have a no start . I would pull the connectors off each of these sensors listed above to see if five volt ref. comes back to five volts . Well first check five volt ref at easiest sensor to get to . watch this video , he explains better !
2006 Cadillac DTS Shorted 5v Reference Circuit
Dec 05, 2016 | Cars & Trucks
Print head
The carriage does not accept one or more of the printheads. Typical causes are dirty contacts on the printheads or carriage, defective printhead(s), or a defective carriage.
If parts are replaced or fixed in any of the steps listed below, attempt to verify printer functionality by turning the printer on and printing internal test prints. If functionality is verified, no additional parts should be replaced.
  1. Turn the printer on.
  2. Allow printer to complete initialization.
  3. With the printhead icon highlighted, press ENTER.
  4. Select Replace Printheads and press ENTER.
  5. If the message "Printheads still functional" appears, select Yes to continue testing the printheads.
  6. Open the top cover.
  7. Open the carriage cover and remove all of the printheads.
  8. Turn the printer off.
  9. Clean the electrical contacts on the carriage and the printheads using a lint-free cloth dampened with water.
  10. (for this step I suggest using the erraser on the back of a regular pencil instead of a cloth and water)
  11. Allow the contacts to dry.
  12. Reinstall the printheads and close the carriage cover.
  13. Close the top cover.
  14. Turn the printer on and attempt to verify functionality, as instructed in Step 19.
  15. If the error reappears, replace the affected printhead(s).
    NOTE: If the printhead error icon is a question mark, each printhead will have to be tested separately, as the printer is not sure which printhead is causing the problem.
    1. Following replacement of the suspect printhead(s), attempt to verify functionality (Step 19).
    2. If the problem persists following, replace the carriage and trailing cable (refer to pages 8-36 to 8-46 of the service manual).
    3. Following replacement, turn the printer on.
    4. Make sure the printhead alignment completes successfully and that no error messages appear on the front panel.
    5. Print a troubleshooting plot (as instructed below) to ensure the print quality is acceptable.
      1. On the front panel, select the printer icon and press ENTER.
      2. Select Utilities and press ENTER.
      3. Press the UP and ENTER buttons simultaneously.
      4. Select Yes to enter the Service Menu.
      5. Select Service Utilities and press ENTER.
      6. Print pages 1, 2, 3, 4 and 5 to prove printer functionality.
Mar 25, 2014 | HP DesignJet 5500PS InkJet Printer
Copy and Alarm Button Flashing
Regarding your Pixma MP830 printer inquiry (Canon PGI-5 / CLI-8 ink cartridges) and A200 error message, most likely the built-in PRINTHEAD is reaching it's end-of-life and may need to be replaced with a new one. Typically, the average printhead only produces ~4000 to 5000 pages before it electrically fails.
For information on PRINTHEAD failures, please refer to our support page:
However, let's run thru the full checklist to screen out additional variables:
Canon A200 Error, Troubleshooting:
Replace ink cartridges if they are empty:
At the risk of stating the obvious (frequently not so obvious in the heat of the moment), find out if the ink cartridges are empty. When in doubt, try a new Canon original ink cartridge to see if this corrects the error.
A data cable of print head is open:
Did you just replace an ink cartridge? Perhaps you shifted a data cable to the print head.
Replace PRINTHEAD if it is damaged. Refer to for replacement part.
Turn off the printer for some time
In other troubleshooting tips we have advised any inkjet printer not seeing regular usage to run a test print page. If you are making heavy usage of a Canon inkjet printer, consider giving it a break. This will avoid saturating the printhead with heat, prolonging useful service life.
Update the printer driver:
If you have followed all this with no success, from the printer menu (not computer) push the buttons to get a demo or test page. If everything is ok when you do this, however you get the service error code A200 when you try to produce something productive, odds are good, the print driver the computer is using has gone south (corrupt). When printing on a network, a corrupt printer driver can spread like an unwanted virus. Depending on the network, a driver that has gone rogue may be seen as an updated driver, which network will 'helpfully spread' as an update.
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD failures. We do NOT suggest refilling these types of ink cartridges.....refilling of original/genuine ink cartridges is only suggested!
Canon PGI-5/CL-8 Ink Refilling Services & Additional Cautions:
However, if your printer works routinely after inserting a brand new Canon OEM (original) PGI-5 and CLI-8 ink cartridge(s) in it, this will confirm the cause of failure.
Please visit for more information or contact us directly at INKJET411HELP@GMAIL.COM
NOTE: For North American ink refill store locations and details on ink refill pricing:
Costco USA Ink Refill Service (453+ stores):
Costco Canada Ink Refill Service (52+ stores):
Costco Mexico Ink Refill Service (38+ stores):
Costco United Kingdom (select stores):
Fry's Electronics Ink Refill Service (34 stores):
Best Buy Canada (4 stores): Downsview, Sherway, Toronto, & Vancouver
Micro Center Ink Refill Service:
(8 locations are providing ink refilling services)
-Thank you
Jan 14, 2014 | Canon MP830 All-In-One Printer
Gas Pedal Stops Functioning
it sounds like ecu is sending wrong signals these new cars are entirely ran off of computers one minor glitch and it screws everything up, but in turn there is million different possibilitys I would take it to oreilys or autozone they offer FREE hookup and will check and see what codes it reading get that information and i could help you alot more miss
May 31, 2013 | 2007 Ford Five Hundred Limited Sedan
Switch on and it displays "printer problem b200 refer to manual. The manual is useless what do I do
Unplug the printer for at least 5 minutes to see if it will clear that error message. The b200 error message is referring to the printhead overheating. It is possible that a printhead nozzle burned out while printing a page and ink ran out. No ink flowing through a nozzle can cause it to overheat and damage it. If waiting for the 5 minute power down doesn't do it, you may have to purchase a new printhead and also check to make sure that you have new ink cartridges.
Mar 02, 2011 | Canon PIXMA MP620 All-In-One InkJet...
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
Oct 23, 2010 | Dishwashers
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Why flash by 5 times the orange led?
    Probably your waste ink counter should be cleaned or replaced before resetting but usually you can get away with resetting once.
    1. Start with printer OFF
    2. Hold down RESUME and then hold down POWER
    3. Release RESUME
    4. press RESUME twice, then release POWER
    5. let green light blink until printhead has finished moving.
    6. Select functions below with RESUME, execute with POWER
    0 presses - green light - Test Print (exit service for i960)
    1 press - orange light - EEPROM info print
    2 presses - green light - EEPROM initialise
    3 presses - orange light - reset waste ink counter.
    This also applies to the i550, i560, i950, i960
    Good Luck, I hope this helps?!
    Aug 12, 2009 | Canon PIXMA iP5300 InkJet Photo Printer
    E000 sYSTEM eRROR
    Solution: Unplug unit for 3-5 minutes, then plug the unit back in
    Unplug unit for 3-5 minutes, then plug the unit back in.
    I hope it helps!!!
    Dec 12, 2008 | Canon ImageClass MF5770 Laser Copier...
    Print head assembly on my Lexmark Optra S 1855 needs to be replaced. My question is what causes the print head to malfunction in the first place?
    I guess you're getting an error message which is normally one of the below (causes underneath)
    Error Code 931
    No first HYSNC Signal
    Error Code 932
    Lost HYSNC =
    These errors usually indicate a
    failure in the HYSNC signal to the
    printhead. Check the continuity of
    the cables connected to J3 and J8
    on the engine board. If incorrect,
    replace the defective cable. The
    voltage at J8-4 measures
    approximately +5 V dc. If incorrect,
    replace the engine board. The
    voltage at J3-7 measures
    approximately +24 V dc. If incorrect,
    replace the engine board. If correct,
    replace the printhead assembly.
    Error Code 934
    Mirror Motor Lost Lock
    Error Code 935
    Mirror Motor unable to
    reach operating speed =
    These error codes indicate a
    problem with the mirror motor circuit
    in the printhead assembly or the
    mirror motor cable to the engine
    board cable or engine board
    assembly. Check the continuity of
    the mirror motor cable connected to
    J3 on the engine board. If incorrect,
    replace the cable. The voltage at
    J3-7 measures approximately
    +24 V dc. If incorrect, replace the
    engine board. If correct, replace the
    FRUs in the following order:
    engine board
    printhead assembly
    Jun 19, 2008 | Lexmark Office Equipment & Supplies
    Canon PIXMA iP4200 InkJet Photo Printer Logo
    690 people viewed this question
    old marine
    old marine
