Question about Sony KP-57WV700 57" Rear Projection HDTV
Service Manual for Sony KP-57WV700
Does anyone have a service manual for this tv they can send me in a pdf file format? I would really appreciate it!!
  • mgmjtech Jan 12, 2009
    My Sony KP57WV700 TV went blank and not sure what happen to it. When I turn it on, all i see is Red screen for 2-3 seconds then shut itself off. I unplug the TV for awhile then turn it on and did the samething. I got 7 blinks.
    Please help
  • 6 Answers
SOURCE: Picture background is Red Sony KP-57wv700
Is it a reddish tint or the picture is just red? Did it just happened, or you are just noticing a gradual change? Reddish tint: Blue and/or green CRTs are getting weaker. More likely the green CRT. Unplug the unit and somehow remove the back cover, etc. to get a direct view of the CRTs. Use a flashlight to inspect each CRT through its lens. CRTs with excessive wear will show a definite "burn" mark where the picture forms. Compare the center CRT (green) with the other ones. Normal wear in all three tubes is expected. What is important is to notice the difference. A significant wear in one means it has to be replaced, but usually all three have to be replaced in order to get the right purity. This is a major overhaul, and unless the TV has a sentimental value, it's not worth it. Picture just red: Green and blue CRTs not firing. This is easily observed by running the TV with the back cover removed. Probably a loose connection, but you will need the manual to trace it. You could gently tap the chassis while the TV is running and see if this restores the blue and green CRTs.
Posted on Sep 28, 2006
Slinteriors
  • 8617 Answers
SOURCE: KP-46WT510 Service Manual
I am posting a link where you can get the complete service manual with parts list for your model it cost 12.99 and they provide free support to help with diagnosis. They will email it within minutes of you placing the order. I have used them many times. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Feb 27, 2008
welcomejee
  • 10594 Answers
SOURCE: sony projecting tv kp-57wv700
Based on service manual info, it cant blinks 7 times as per symptoms, please count again blinks. It can be 5 times.
If its 7 times blink, Horizontal Deflection stopped in this case. If you want to repair it at your own, please let me know to guide you further but it is necessary you should have knowledge of electronics.
Posted on Aug 18, 2008
SOURCE: sony projection tv kp-57wv700 please help!!!
Follow these instructions:
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
They have fixed dozens of tvs with this problem, including mine.
Posted on Dec 20, 2008
  • 8457 Answers
SOURCE: Sony KP-57WV700 Convergence Repair Failed - TV won't stay on
Sorry ur convergence ICS are shorted and dead.Because u put in solders and take out solders to many times.The heat of ur soldering iron,and the electrostatics will kill the ICS,if keep putting heat in the ICS legs alots times.Buy the convergence kit again,replaced every componnents in that kit to ur tv.Because,the kit been research and put together.What the most common componnents that burn and dead in the convergence circuits.
Posted on May 04, 2010
Testimonial: "Very quick reply and helpful!"
I would like to find out what the flashing red light indicates.I would like to download the manual.
Hi nett1611,
First of all, thank you for posting your question here at Fixya.
Please email me at mjsvillanueva23@yahoo.com, I will send you the copy of the Sony KDL-32EX500 Service/repair manual. It is a pdf file format and can't be uploaded here.
Thank you for your patience.
Have a great Holidays!!!
Ratings and feedback are highly appreciated!!!
Mjsazon
Dec 27, 2011 | Sony KDL32EX500 32 in. TV
Tip
Sony KP-61XBR48 Service Manual Download
Download Sony KP-61XBR48 Service Manual
Would you like to download a free Sony KP-61XBR48 Service Manual?
Have you lost your Sony KP-61XBR48 Service Manual?
Would you like a digital, searchable, pdf version of the Sony KP-61XBR48 Repair Manual?
Follow this link (& click FREE) to download a pdf version of the Sony KP-61XBR48 Service Manual documentation.
I hope that helps.
___________________________________________
on Jul 05, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 05, 2010 | Sony KP-61XBR48 61" Rear Projection...
Picture is very blue, especially in dark scenes.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 21, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
Sony KP51WS500 blinks 4 times and picture will not stay on I have no money for a repairman but have someone that can repair it if they had the scalmatics. any info you could give would be greatly...
Click HERE and download free copy of service manual of KP-51WS500 tv. Download all 11 files on that page and unzip it with Winrar software to get PDF format manual copy that has all schematics of this tv. Now you can fix your tv with help of your friend and service manual.
Winrar is also available over internet and can be downloaded if you don't have in computer.
Thanks.
May 04, 2010 | Sony KP-51WS500 51" Rear Projection...
Tip
Sony KP-53XBR45 Service Manual Download
Download Sony KP-53XBR45 Service Manual
Would you like to download a free Sony KP-53XBR45 Service Manual?
Have you lost your Sony KP-53XBR45 Service Manual?
Would you like a digital, searchable, pdf version of the Sony KP-53XBR45 Repair Manual?
Follow this link (& click FREE) to download a pdf version of the Sony KP-53XBR45 Service Manual documentation.
I hope that helps.
on Jul 04, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 04, 2010 | Sony KP-53XBR45 53" Rear Projection...
Sony projecting tv kp-57wv700
Aug 18, 2008 | Sony KP-57WV600 57" Rear Projection...
Sont kp-46wt510 blinks 4 times
Four blinks is a "vertical stop error" I have a pdf file of the service manual and troubleshooting guide. If you want it,let me know where to send it.
Sep 27, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-57WV700 57" Rear Projection HDTV Logo
64 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
