Question about Tascam DP01 All-In-One Recording Package Microphone
Replace Tascam DP-01FX/CD -- the CD R/W won't work
After getting all of the songs ready to burn to CD, the CD writer won't recognize the CD. It says to insert an Audio CD. I tried several CD's. I even tried reading a regular audio CD. It won't recognize it. I'm guessing that the CD R/W is toast!! So...how do I replace the CD R/W? I am a PC technician, but I'm afraid to venture in to the body of the Tascam.
  • 1 more comment
  • bobbopgh Jan 12, 2009
    I have the same problem as the other individual. I have inserted every type of CD stated in the manual and NONE work. It continues to state "insert Audio CD" I've tried many different Audio CD's and Audio CD-R's. Does this mean the CD drive needs to be replaced? Or is there something I'm missing in the manual? Thanx
  • McDargh Jan 13, 2009
    Thanks for trying. I was burning Audio CD-R's just fine and then one day, it just quit. I've only burned maybe 10 CD's on it so I ordered the repaired manual from Tascam for $30. It looks horrid to replace, but once I get everything backed up, I'm going for it.
  • fldrvr1995 Jan 18, 2009
    I am having a somewhat related problem in that the CD won't open at all. I bought the unit off of ebay and unfortunately have not used the CD function until now (many months later). Any thoughts?
    Scholar:
  • 58 Answers
I don't think there is a problem with your CD writer.  You have not inserted the type of disc your write drive requires.  You must use a BLANK "AUDIO CD-R".   Check your instruction manual concerning the type of disc required.  Data CD-R's will not work in this type of drive.  if the disc has "DATA CD-R" or "700"mb or "800mb" printed on it it will not work.  audio CD-R's are not as common and are a bit more costly.   They are the only type of disc that will RECORD in your drive.  Regular audio CDs should play in your drive.  I hope this solution will work for you and I wish you every success! Michael Mittelsdorf
Posted on Jan 11, 2009
Tascam DP-01FX/CD wont turn on
Refer to your manual (1st) It appears that "maybe" your unit may be
locked - until you get through the menus - and type/press EXIT.
If you don't have a red indicator light - lit. Turn off power switch (rear)
and unplug unit for 1 minute. Plug in - then turn on switch (rear)....if
still no red indicator light....you'll need either Tascam or Samsung
tech to service your unit. Good Luck.
Feb 28, 2014 | Tascam Digital Portastudio Dp-01fx/cd
Tascam dp-01fx system 80 error It says " No CD
hey mate i got no solution for yah but if yah work it out e mail me man i got the same problem
da_monk_bomberman@hotmail.com
if i can get some info on it ill contact yah ok
Dec 08, 2010 | Tascam DP01FX All-In-One Recording Package...
I have a Tascam DP-01fx/cd that after powering on it reads sreset error :12 please power off. How do I fix this so I can use the machine again?
Jan 02, 2010 | Tascam DP01 All-In-One Recording Package...
DP-01FX/CD Problem
nslo, tell him to try replacing the power supply first, power supplys burn up ALL the time, as long as the plug fits and it has a rating of equal or greater amperage, same voltage, equal to or greater watts then it will work. Those variable voltage multi plug ones they sell at k-mart work but I've never had one that lasted long.
Jul 09, 2008 | Tascam DP01 All-In-One Recording Package...
DP-01FX/CD sound quality of CDs
Nothing really specific other than to make sure you are recording as close to 0 db as possible without going over. Your master fader also needs to be set at 0db or above as this effects the volume when mastering.
Commercial CDs use a lot of compression to attain volume levels which aren't attainable without it. You should however be able to reproduce onto CD the volume levels you are hearing on your Tascam without resorting to compression.
To troubleshoot, you might want to try exporting your master tracks as wav files onto your computer via usb and then listening to them there. If the volume is low there you aren't creating master tracks with good volume (see above: master fader level), if the tracks sound good as wavs on your PC, then burn them onto a cd from there. If that CD has proper volume then you may have some problem with your Tascam CD burner although I've never seen a situation where a burner actually caused low volume like this.
Best of luck.
BD
Apr 21, 2008 | Tascam DP01 All-In-One Recording Package...
Problem with dp001fx/cd
You have to set the in and out points before you master
Mar 31, 2008 | Tascam DP01 All-In-One Recording Package...
Mastering the songs
You’re trying to master with the OUT point at the zero position.
Set the OUT point and try again.
Check chapter “IN and OUT marks” on page 29 of your manual if you don't know how to set the 'in' and 'out' marks.
C.d tray
Hold down "Shift" and press "Exit" at the same time.
Nov 12, 2007 | Tascam DP01 All-In-One Recording Package...
Tascam DP01 All-In-One Recording Package Microphone Logo
599 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
