Question about EliteGroup P4VMM2 Motherboard
Memory card upgrade
I want to ask if i can change my memory card to pc 400? my mother board is p4vmm2, i been using pc266 only i want to replace it but no where to find the pc266 memory.!
  • jcyap888 Nov 04, 2008
    i dont need the premium plan just want to know if i can upgrade it to pc 400 or not. so if not i better change my motherboard to other brand.
  • 1,605 Answers
No! PC266, you can change them to CP3200.
if the clock on the motherboard is adjustable, you may able to get away with PC400. in general, it is not a good idea to do that.
Posted on Nov 05, 2008
Parts upgrade
The 333/400 is the speed of the RAM in MHz 333 and 400 MHz. That corresponds with PC2700 and PC3200 that is in your specification.
250 GB hdd will work. Make sure that it is IDE and make sure that you connect the jumpers for master/slave the correct way.
As for the graphic card. If you have this one 'VGA SPARKLE 7300GT 512MB DDR2 128BIT PCI-X' than it will not work because it is a PCI-X card not an AGP card. You will need an older card for this motherboard.
best regards
Mar 23, 2009 | EliteGroup P4VMM2 Motherboard
Compaq Presario 5LOXE1 Memory upgrade
So you mean only 1 video card is working and the other one is not?
May 04, 2008 | Compaq Presario 5000 PC Desktop
Can i install 1GB ddr2 on P4VMM2 Motherboard? i want to upgrade my pc; board is: can i P4VMM2 Motherboard; cani i use 1GB ddr2 on this and a 512 MB if vid.card?
Unfortunetly you cannot use ddr2 memory on this motherboard. The motherboard supports only PC2100/PC1600 DDR memory if you have version 8.1 of the motherboard. If you have v5.0 of the motherboard than you can only use sdram or ddr 266Mhz RAM. The same goes for the video card. The p4vmm2 motherboard is a rather old motherboard so I don't think it will payoff to upgrade the computer. It will be probably the best if you buy another computer.
best regards
Compatible memory for P4M266A-8233
No you can not!
This is what memosticks that mobo of yours supports
DDR 200/266
PC100/133 SDRAM
Max. Memory 4.0GB
Good luck
Mar 09, 2009 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Ddr not detected
if you want to use ddr ram with p4vmm2 mother bord you must replace the jumper near by the ddr2 slot
then your computer starts to work with ddr ram at 266Mhz also 400 Mhz too.
Feb 09, 2009 | EliteGroup P4VMM2 Motherboard
Memory Upgrade - from 256DDR1 to 1GB DDR1
EliteGroup makes two mother boards, P4VMM2, (No Revisions) & (P4VMM2 revision 8.1). Since your question states your memory is 184 pin DIMM your board must be, v 8.1. What does not make sense is the motherboard has two memory slots total.
(If you have 4 memory slots on the MB than the MB can not be the P4VMM2). Below is the link for the P4VMM2 (v8.1).
The P4VMM2 v 8.1 can only use, two Double Data Rate (DDR) SDRAM memory modules. These sockets support up to 1GB system memory using 184-pin unbuffered non-ECC PC2100 or PC1600 DDR DIMMs. The two DIMMS you are using must run at the same speed.
Example PC2100 266MHz. OR PC1600 266MHz.
Continuous beeping means the memory is not seated correctly.
When using only one DIMM it should be inserted in the slot closest to the CPU. Re-check your memory. Remove & reseat. Make sure the latches snap closed on each stick of memory while inserting. Below is all of ECS P4VMM motherboards;
Good luck sysa007!
More question, post here.
Thank you for using fixya.
If you find this helpful, please vote.
Jan 31, 2009 | EliteGroup P4VMM2 Motherboard
Upgrade my RAM
This mother board don't support 400mhz , so if you want to upgrade the RAM better just get another 266mhz...
Check this link for the info
Hope that helps.....
Jul 11, 2008 | EliteGroup P4VMM2 Motherboard
Motherboard upgrade
dont mix your pc400 to the pc266.
Feb 16, 2008 | EliteGroup P4VMM2 V8.1 Motherboard
RAM Support
if it works there is no problem, as the system would not boot up, but your memory will run at the slower of the two speeds, which will be PC266 and not PC333, as the faster speed ram is backward compatable because it always runs on the slowest speed.
Jul 30, 2007 | EliteGroup P4VMM2 Motherboard
P4VMM2 Motherboard problems with RAM Cards changing fron SDRAM to DDR
Depending on your version of motherboard, it may only take ddr when you change the motherboard jumpers, as i assume you have 2 SDRAM and 2 DDR slots, but you will need to refer to your manual
Apr 10, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup P4VMM2 Motherboard Logo
62 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
