Question about Alpine CVA-1004 Car DVD Player
CVA-1004 head unit set-up
I am moving my CVA-1004 head unit, NVE-N851A nav, CHA-S634 CD changer into my new(est) car. I bought a Pac 7 trigger for video bypass service. After installation, I am unable to access the 'set-up' screen. The disclaimer screen does not clear with pushing 'enter' on remote. I removed the Pac7 bypass and tried to connect the hand brake and foot brake leads on the heat unit and nav unit, but it is not clear in the manuals whether they are looking for 12VDC or ground. I have re-booted the head unit per manual, but no luck. Any advise out there? Much Thanks BB
The PAC requires both.. check the instructions and your wirng.. Good luck..
Posted on Oct 30, 2008
Salida de video
Posted on Mar 12, 2008
Check the cables, it may be one color switched
Posted on Jan 14, 2008
Does cd changer CHA 5604 play Mp3?
CD Changer CHA-S604 does not read MP3 discs. Alpine CD Changer CHA-S634 reads MP3 discs only.
Mar 08, 2011 | Alpine CHA-S624 6-Disc CD Changer
The magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame inside the caring which releases the...
Hi
Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine.
However Error1 means Battery inside CD Changer needs to be replaced.
And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer.
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again.
grease the moving parts with light lubricant.
Thanks for contacting fixya.com
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
Jammed CD & Magazine in an Alpine CHA-S634
Mine jammed after I dropped it, trying to swap it into a new car :-)
Same problem, however. Three of the six CD trays had wandered into the righthand mechanism (which selects and plays one cd at a time). Nothing else at all, most fortunately, was broken.
I removed the cover (3 screws on each side), and the small black faceplate that holds the eject button. The main faceplate came off too, needless to say; no screws, just tabs.
You have to remove the side brackets also, and the angle-adjust spring loaded pins on both sides need to be slid out. Then the body of the cd changer rotates out of its cover.
Now, you can see down into the mechanism. A CD was still stuck in the reader, along with several shifted trays. I could simply remove the CD, and with a small screwdriver, shifted the trays back over so that I could then successfully eject it. I removed and realigned the trays, which had been jammed, and it worked once more! Reassembled and reinstalled ;-)
Apr 26, 2009 | Alpine CHAS-634 6-Disc CD Changer
Video is off for you safety ?
pac tr7 module will bypass the video lock. the lock comes on if you have the aux on while in drive. shuts off the screen so you cant watch movies and drive. go to amazon or google PAC-tr7 module. costs between 15-30 bucks depending on where you buy it. Very simple hook up, just follow the wire chart.
Mar 24, 2009 | Alpine NVE-P1 Navigation Add-in Unit for...
Installing a cd
you must have a cd changer via ai net it is just a screen controller not a cd player
Feb 18, 2009 | Alpine CVA-1004 Car DVD Player
Not sure what the problem is
Check the changer and see if cds are inserted correctly or if 2 cds are in one slot.
Dec 13, 2008 | Alpine CHAS-634 6-Disc CD Changer
Alpine cva-1004 no audio video ok
Many aftermarket car stereo has to output trigger wires, one antenna and one amplifier. Antenna trigger only works in radio mode for the power antenna to operate. Amplifier wire operates in any mode the stereo is in. Check to make sure you hooked up the correct blue wire to your amplifer.
Bob
Nov 13, 2008 | Car Audio & Video
Error 1 on alpine cha-s364
Quick Note: It's really helpful to your cause if you make sure you include more information about your system and what you're doing to get an error.
It's also a good idea to make sure you type in your model number correctly - you've typed in cha-s364 (the actual model you're talking about "I think" is a CHA-S634 - please verify!!
Here's a link to the user manual
As for the E-01 Error message on your CD Changer:
The E-01 reading is an error message, usually because the changer magazine is jammed in the changer. To manual eject out the magazine, take a thin plastic ruler (at least 5-1/2" in length) and slip it between the bottom of the magazine and the changer. Now, push in. This will hit a release button in the back. If the magazine does not eject, you will need to send the unit in to be serviced. To locate the nearest authorized service center to you call 1-800-ALPINE-1.
Note: if the magazine is half way out, but jammed, DO NOT try to release the magazine. You will need to send the unit in to be serviced by a technician.
May 29, 2008 | Alpine Car Audio & Video
WONT READ CHANGER
You might have a pinched calbe try replacing it.
Sep 26, 2007 | Alpine CVA-1003 Car Video Player
Alpine CVA-1004
lol i had the exact problem that you are having with my alpine. The solution is taking the blue cord that was inside the vehicle (forgot what cord it was) and actually connecting it with the other blue cord thats different makes the factory amp read the cd player and ta-da it works. crazy isn't it
Sep 17, 2006 | Alpine CVA-1004 Car DVD Player
Alpine CVA-1004 Car DVD Player Logo
342 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
