Question about Neff H5470 Microwave Oven
Neff Combined oven and microwave
Model : E No -Nr.H7860N/GB FD No/01FD7809
No light inside but showing as 'on' on display panel. Light bulb needs replacing but manual doesn't describe how. Where actually is it? I expected to find it behind the glass cover in the 'roof' of the appliance because in my bigger Neff oven, the bulbs are behind glass covers. The manual covers replacing bulbs in the big oven but not the micro/oven.
Confused Iris
  • njt3 Dec 05, 2008
    (1) Where can I download a manual for the Jenn-Air JMV8208AAS?
    MY MANUAL HAS ONLY INSTALLTION INSTRUCTIONS.
    (2) THERE IS NO LIGHT INSIDE THE OVEN.  CAN I REPLACE IT OR DO I HAVE TO CALL IN A SERVICE PERSON?
    THANKS,
    NICK TURRO
  • Anonymous Mar 13, 2014
    need to replace a missing cooker filter and light holder on Neff hood model E-NR D5622XoGB or Type D-BX21-4
  • Neff Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Nov 09, 2008
The lamp of won't work
follow the steps and fix it. God bless you
ight Bulb
If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
Main Control Board
If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
Light Bulb Socket
If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
Jun 11, 2013 | Neff H5642 Convection / Microwave Oven
How do I replace the light bulb in a NEFF H7860B1GB/01 ?
Unplug power first. You need to remve the screwa that hold the bulb cover, access the bulb and replace it, I will wee if I can find a diagram.
Oct 06, 2008 | Neff Microwave Ovens
Although I have changed the light bulbs, the lights that illuminate under the microwave onto the stove top will not work. This is a Kenmore over the stove Microwave Oven Model 721.80592402. Have their...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one-year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Sep 08, 2010 | Kenmore 80599 Microwave Oven
The display works (clock, mode, etc) I can push
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 27, 2010 | Whirlpool GH9176XM Microwave Oven
Replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
How do you change the interior light. I cant see an access panel either on the outside or within the unit
I think on that model the whole outer casing needs to be removed. These bulbs are designed to last but appearently this one got by them in the inspection department.
Hope this helped you
Dave
Feb 22, 2010 | Neff H5642 Convection / Microwave Oven
Neff microwave turns and lights when started but doesn't heat
check on rating plate if fd number starts with a 7 or 8 eg fd 7908 then appliance will need mag leads recrimping they oxidise over time and break connection giving syptoms that you describe, its an easy fix but you need to remove outer casing.
NEFF MICROWAVE OVEN BLOWS 10A INTERNAL FUSE
We had the same problem, got Neff service engineer to come out after taking out insurance. He said the megatron cracks which is a large magnet and causes the fuse board to blow and needs to be replaced. This occurs through lack of ventilation on instalation. Total cost £370 may as well get a new one. Plus our insurance wouldn't pay the cost and cancelled the insurance policy.
Mar 24, 2009 | Neff H5470 Microwave Oven
H7881 Neff Microwave Light Bulb type
go to the NEFF spares area here: http://bshappliancecare.com/Neff/neffspares.html at BSHAppliancecare - if you an locate the FD or E-Nr inside the appliance door then you are laughing. The site's a doddle to use. It should have exploded diagrams and part numbers to look up - and order. The prices seem to be fantastic for the replacements I've made (oven and fridge seals)
Nov 15, 2008 | Microwave Ovens
Model JVM130G
what brand is this and did the light go on when the door was opened before you changed the bulb?
Jun 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Neff H5470 Microwave Oven Logo
432 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
