Question about Whirlpool Refrigerators
Fridge doesn't get cold enough. Freezer works. Even on 4 milk is still going bad in the fridge. It is brand new... less than 3 weeks old. Whirlpool Top Mount Fridge ER8MHKXRQ
Shouldn't come with a one year factory warranty ??
Posted on Nov 03, 2008
Frigidaire frs26h5asb5
Hi Gary,
If your evaporator is not completely frosting over (top to bottom) this normally means the unit doesn't have a proper charge or the compressor can't pump all the freon as it needs to. I would check the charge, this should read "0", if less not enough, if higher than the compressor is failing. I hope this helps.
Aug 17, 2014 | Frigidaire Refrigerators
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
Fridge not keeping things cold enough
fridge coldest setting is 1
freezer warmest setting is 1
Dec 08, 2017 | Fisher and Paykel E522BLXEZ EZKleen...
Fridge side not getting cool, freezer works great
is the fan running in the freezer?.
is ther ice build up on the back wall of the freezer?
check fridge control, set midway, same with freezer control
Jul 01, 2009 | KitchenAid (KSRD22FKST) Side by Side...
My freezer works perfect but everything in the refrigerator doesn't get cold enough. My milk sours. My fridge is an inglis and supposedly brand new
Warm fridge cold freezer problem fixed
In the freezer section there was a one screw removable panel which housed a four bladed rotary fan. One blade had broken off adn was jamming the fan from rotating. Once the broken part was removed the fan was free to rotate, but out of balance, but it did get the fridge going again. It took about one minute to replace the fan once a spare was aquired. Now I understand how it works, if one side of your fridge freezer is not working it can only be the air movement or lack of it Robert
Robert
Dec 30, 2008 | Refrigerators
Tenant says fridge is not cold enough and that food has gone off
I would check to see if the heater is working? It would behind the plastic back wall of the freezer. if its all frozen up and ice all over, get a hair dryer and melt ice and get a new heating element. cost is about 50 dollars
Dec 06, 2008 | Belling BE808 Compact Refrigerator
Amana neither fridge nor freezer getting cold enough
the defrost system has failed. to get it working temporarily, take the back panel off inside the freezer. melt ice off with a hairdryer.
after that, fault can be in several areas - defrost heater, thermal fuse or the main pcb
Jun 30, 2008 | Refrigerators
Refrigerators Logo
137 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
