Question about Apple iBook G3 Mac Notebook
Replacing CD-rom and hard drive
I need to replace broken cd-rom and a larger hadr drive. How to do that?
My emachine wont reconize or read any games or cd i put in it
Spend $35 to purchase a replacement CD/DVD reader/writer, to replace the "broken" device.
Jul 19, 2011 | E-Machines emachines (emachinees) CD-ROM...
How do I change the type size on this computor?
if you want to increase the size of your computers hard drive you need to install a bigger hard drive
or if you want to increase the actual size of your computer you will need a larger computer case/frame /box
hope this helps
Nov 29, 2010 | E-Machines emachines (emachinees) CD-ROM...
My samsung cd-rom sc-148c drive is not working. It is not listed in "My Computer". I have uninstalled and reinstalled it but that does not work.
Is the CD-ROM drive on a separate cable on the second IDE controller on the desktop motherboard? Then the jumper setting can be set to Master or Slave if no other drive is connector to this cable.
If the CD-ROM is also on the first IDE controller and IDE cable as the hard drive then the jumper setting on the CD-ROM must be set to SLAVE because the hard drive would be jumpered as MASTER.
Check the BIOS setting to see if the CD-ROM drive is detected.
If the CD-ROM still does not work after you checked and configured the CD-ROM drive, then is is faulty and needs to be replaced.
Dec 16, 2009 | Samsung SC-148 CD-ROM Drive
I have an Evo laptop and the hadr drive died. HDD2181. Can you use an external drive without the internal drive? Or where would be the best place to get a harddrive?
You are able to use an external hard drive as your main drive but you will need to boot it at startup. If you need more help then just ask
Thanks
Cbz123
Nov 20, 2009 | Compaq Evo N610C Notebook
The cd-rom drive in my computer has stopped working all of a sudden. The cables inside the tower are all connected however it does not recognize a disc being in the cd-rom drive! I also get a warning that...
Replace the Cd-rom drive, sounds like you may have a bad spindle motor and or Laser assembly. Cd-roms are very cheap these days, and you might consider replacing it with a DVD drive instead, which is downward compatiable.
Sep 28, 2009 | Gateway GM5084 PC Desktop
My CD-ROM does not work properly
try to use an external DVD/ CD Rom or replace the one you have. Many time the roms tend to break and will have to be replaced. it usually a piece that is loos or broken from the rom.
Jun 03, 2009 | Computers & Internet
I have an old computer, a Packard Bell Windows 95. I'm trying to recover it. I have the Master CD and recovery disks but the computer keeps saying that the CD ROM is undetectable when it is connected. I...
have a look on the back of your new CD ROM drive where the long cable goes next to that is a small piece of plastic check that it is in the same position as the broken CD Rom this selects between slave and master switches hope this helps regards Jim
Apr 20, 2009 | Computers & Internet
Replacing with harddrive 40GB
Did you simply swap hard drives? "Couldn't find NTLDR" basically means the PC cannot find any version of Windows installed because the boot file is missing. This could be because you have a CD in the drive or the hard drive is missing or broken.
If you put in a new hard drive to replace your older smaller one you need to reinstall Windows on that new 40GB drive or it just won't work. If you have some PC Tech friends they should be able to move the data which is tricky or help you out.
Mar 18, 2009 | Compaq Presario 5000 PC Desktop
A cd broke in my cd rom
I've seen and come across cd-roms where cd's have broken (or in most cases exploded/shattered). In one case the drive flew open and bits of cd flew across a classroom, in most cases the drive remains shut (even the tray can get jammed).
This problem is usually caused by a flaw on the cd itself, a scratch or mark on the cd causes it to 'wobble' and due to the speeds cd-roms spin cd's they come off the 'spindle' inside (all that holds it on is a magnet).
I have taken cd-roms apart and removed all the cd parts and the drive has worked perfectly afterwards. Other times the drive has needed to be replaced, so i would say its purely luck if your drive isn't damaged in some way.
Although the problem could have been your drive. Without being able to get the drive ejecting and spinning cd's again you'll never know... just make sure you don't use an important cd to test it with!
Dec 27, 2008 | E-Machines emachines (emachinees) CD-ROM...
Apple iBook G3 Mac Notebook Logo
44 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
