Question about Canon i450 - Printer - color - ink-jet - Legal, A4 - 600 dpi x 600 dpi - up to 18 ppm (mono) / up to...
Canon i450 Printing issue
My Mother-in-Law has a Canon i450 at her office that she has had for years. She recently replaced the ink cartridges, however the balc ink is not working properly. It was initially printing as if it were almost empty and now does not print black at all/ we replaced the cartridge with a new one, we ran a cleaning and a deeper clean I ran throught the other diagnostics as well, yet it still does not print black.
Any siggestions?
  • Geoff Coburn Nov 03, 2008
    Thank you, will try it today.
  • Jackie Johnson May 11, 2010
    Printer will not print with black ink. Canon i450 microfine droplet technology? Help? Color works fine, but not black. It comes out blank. Any help:
  • 196 Answers
This clearly indicates that the printhead of your black cartridge is completely blocked and it needs internal cleaning which cannot be done by printers cleaning commands.the print head has to be removed from the printer and and then cleaned with isoprophyll and soft tissue very slowly and gently.if u dont have a technical idea taking it to the repair center is advisable.
hope this helps.....
Posted on Nov 03, 2008
How to reset inkje even with new refilled cartridge
Regarding your recent inquiry about the Canon 240 (black) or 241 (color) ink cartridge ink alert/error condition and the inability to print to your Canon MX452 printer, to reset the cartridge ink low/empty alert message condition, depending on your printer model, we suggest you follow the documented procedures below and/or provided on Inkjet411 at the following link.
Essentially, in most cases, all you need to do is press the 'Stop/Reset' button (triangle symbol inside of a circle) for 5-8 seconds and the ink error ("ink has run out", etc.) indicators should extinguish; two common reset procedures are provided below (please refer to both videos):
Canon 30/31/40/41 - Refilled Cartridge Activation Instructions:
Canon 50/51 - Refilled Cartridge Activation Instructions:
Canon 210/210XL/211/211XL - Refilled Cartridge Activation Instructions:
Canon 240/240XL/240XXL/241/241XL - Refilled Cartridge Activation Instructions:
Canon 245/245XL/246/246XL - Refilled Cartridge Activation Instructions:
If you have already attempted the 5-8 second printer reset without success, then refer to WORST CASE SCENARIO section below.
NOTE 1: Providing you can still print, you will need to wait until the "ink has run out" message appears on your computer, before activating the 'Stop/Resume' button for 5-8 seconds. However, if printing is not permissible, then please keep reading....
NOTE 2: If you are able to print the internal self test print, this will demonstrate that the ink cartridge is 'at least' partially functioning. If this is the case, then we suggest you continue printing until the software prompts you to press the 'Stop/Reset' button for >5 seconds. For poor print quality performance issues (as you indicated in your inquiry), we suggest you run a nozzle/cartridge clean test from your Canon software, followed by printing our 'Ink Recovery Test' print:
NOTE: To rule out connectivity issues, please ensure BOTH carriage/flex cables (point where the cartridge connects to carriage inside the printer) and BOTH ink cartridge rear electrical contact surfaces are thoroughly clean before proceeding:
      If, after performing the suggested 'reset' procedures above, you still have an error condition which prohibits computer/host based printing (or permit copy/scan functions), then the ink cartridge probably has internal electrical damage (micro-electronics failure); such a failure is unrelated to the ink cartridge refilling process. Typically, when the cartridge fails the problem is 'masked' by the ink out/empty condition so it can be difficult to distinguish between the two. Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process (i.e. typically ~2 years from original manufacturing date). Refer to picture at bottom of this page:
      If, following a reset of the printer via the 'Stop/Resume' button, printing is permitted but the 'Ink Low' indicator continues to be lit then one of the inks cartridges may be suffering from marginal internal electrical performance - a potential failure of the cartridge may eventually occur which will prevent printing.
      CAUTION: Be advised, the use of Canon compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD failures (due to incompatible ink formulations which may contain volatile organic compounds, or VOCs). We do NOT suggest refilling these types of ink cartridges.....refilling of Canon original/genuine ink cartridges is only suggested!
      Canon 30/31 Ink Refilling Services & Additional Cautions:
      Canon 240/241 Ink Refilling Services & Additional Cautions:
      If you do need to purchase a new ink cartridge (to save on ink costs), we suggest you try a USA remanufactured ink cartridge from as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating and come with a 1-year warranty.
      Alternatively, if you are interested in the top 'refill friendly inkjet printer models', our suggested list is posted on-line and our internal labs have verified there are no issues (in ink compatibility or color output) with all of these models:
      Please let us know if you have any questions regarding the technical information provided above by sending an e-mail to us directly:
      -Thank you
Jul 20, 2014 | Canon Pixma MX452 Wlse All-In-One Printer...
I recently made my canon iP2770 a continuous ink one. It as going well, untill it said "The holder is in the ink cartridge replacement position.Close the printer's cover.Ink has run out. View the
Throw it in the trash and buy a laser jet.
People who print a lot, and do I, would be better off buying a new printer every time I went to buy cartridges.
The printer I bought was a brother HL 3140 cdw.
~$200 at staples
The cartridges are expensive ~$200 and lasted me for a year.
I said a year!
Jan 27, 2018 | Canon PIXMA iP2200 InkJet Photo Printer
I have a Canon Inkjet i475D printer that has been sitting for a year or more. I've tried to use it today - and the print heads are apparently clogged. I've tried the cleaning and deep cleaning utility...
if its been sat for a year it will need new cartridges. ink drys out over time when empty it drys to the head as there is nothing to keep it wet.
May 15, 2017 | Canon i475 InkJet Printer
Black not printing
Canon Bubble Jet i560 Ink Jet Printer not printing black
Aug 01, 2010 | Canon BubbleJet i560 InkJet Printer
Printing gives only blank pages...
Maybe you need performance a preventive maintenance if you know how great, if not you can call a Printer tech in your area.
May 27, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Canon i450 uneven printing
The problem could be as simple as your paper not going through the tray straight, or just aligning the print cartridges. Make sure when your paper is pulled through the printer that it isn't getting pulled more quickly on one side than the other. Also, go into your printer control panel to find the 'alignment option' and follow the steps to complete a proper alignment. If that doesn't work, get back to me with more details about the problem. (is it on a slant, are half the sentences printing on a different angle etc.)
Apr 16, 2009 | Canon i450 - Printer - color - ink-jet -...
Colors are not printing out true.
I replaced the Office Max ink substitute with an original Canon ink. This did not help. I decided this problem most probably had to be a printer head issue, so I gave up and bought a new printer instead.
Dec 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon MP170 printer
Jul 02, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Isn't printing at all...
try replacing the cartridge with the new one
Mar 14, 2008 | Canon BJC 80 InkJet Printer
Printer HELL !! need assistance
illustrate on how to replace the ink cartridge on printer
Sep 15, 2007 | Office Equipment & Supplies
258 people viewed this question
old marine
old marine
