The TV won't come on. When I push the "on" button it lights up for about a half of a second and then goes off. Inside the back of the TV, a red light stays on but no picture or light of any kind on the screen. i just moved the TV into my house.
  • 2 more comments
  • timberlanesp Nov 03, 2008
    The TV I have is a Hitachi 54" projection TV.
    Hitachi model # 61UWX10BA
    THERE IS NOTHING WRONG WITH THE POWER OUTLET. OTHER ITEMS ARE WORKING FINE THAT ARE CONNECTED TO THE SAME RECEPTACLE.
    IF THE SATELITE IS NOT CONNECTED TO THE TV PROPERLY, WIL THE TV SCREEN STILL LITE UP? THE RED POWER ON INDICATOR LIGHT COMES ON AND THEN GOES RIGHT OFF.
  • 3,037 Answers
The tv should work even if nothing is connected to it
It could be a protection mechanism (for example because the power supply is overloaded) or an under voltage.
If it is plugged into a power strip, you can test the second hypothesis by plugging it directly into an outlet. May be you can try a different one.
Fixing the first case is not trivial. In any case, if you don't have experience with TV repair, do not open it.
My guess is that something in the power supply broke when moving it and you need to replace the power supply which is very common with what you describe is happening on this tv.
Posted on Nov 03, 2008
  • 2,336 Answers
If the TV is shutting down, it could be due to different reasons and I'm afraid that none of them are DIY.
The first thing to do would be to check all the components that are associated with horizontal circuitry of the TV, for example the HOT, flyback transformer, voltage trippler. If those components test out OK, the next circuit to test is the power supply voltages.
If you are able to perform the mentioned tasks, you might be able to fix your TV.
Let me know if you need further assistance.
  • 749 Answers
Have the tv checked at a service center or a qualified service person. components inside the tv might gone loose or disconnected as you move over to your house!
have it repair before it could get worst as you try to switch it on over and over.
  • 10,594 Answers
It seems some lose connections or cold solder joints in TV, specially in power and deflection boards.
If you are tech person, you can re-solder cold joints and TV will function properly. If you have no experience in TV repair, I would suggest to call TV tech person to fix it because projection TVs has dangerous high voltage inside and can be harmful for novice.
Need further help, let me know please.
    Brigadier General:
  • 3,614 Answers
Check the connection. esp your cable connection
    Scholar:
  • 59 Answers
Hello sir.. As you mentioned that you moved to a new house and the T.V worked fine in the previous house, its obvious that some thing should be wrong with the new place. Please consult a T.V repair expert as it will not be possible for anyone to Fix it unless anyone sees it. The most possible reason will be the Power factor.You please disconnect and first make sure the power outlet is working fine by plugging in any other electronic product.  Also try to connect your T.V to a different outlet in any other room. Let me know if this is helpful.
    Genius:
  • 1,252 Answers
The back red is the indicator that it is receiving power, its better consult to the technician, the power require for the screen is not proper
    Genius:
  • 1,550 Answers
You need to provide brand and model number of your tv .
How old is your tv ?
Have a check over fuse .
Also you need to check whether the inlet power supply to tv is proper .
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
Tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 | Televison & Video
Tip
How to Unlock Any Appliance or Turn Off Child Lock
<span style="font-weight: bold;">Bosch Dishwasher:</span><br /> <ol> <li>To deactivate, press and hold the "&lt;" button until the Child Lock LED goes out.</li></ol><span style="font-weight: bold;">Bosch Microwave:</span><br /> <ol> <li>Press "Settings" followed by the number "5" to deactivate Child Lock.</li></ol><span style="font-weight: bold;">Bosch Washing Machine:</span><br /> <ol> <li>To deactivate Child Lock, press the Start/Pause button and hold down for 5 seconds.</li></ol>or<br /> <ol> <li>Press the Menu button until CHILD LOCK :ON appears in the display.</li> <li>Press the Select button until CHILD LOCK :OFF appears in the display.</li> <li>Press the Start/Pause button and the key symbol should disappear.<br /></li></ol><span style="font-weight: bold;">Danfoss Thermostat:</span><br /><br /> <ol> <li>Press the control knob or button and hold it in place.</li> <li>Turn the knob counterclockwise until you see the word "Code" appear in the display.</li> <li>Turn the knob clockwise and select the code "0033."</li> <li>Press on the control knob until you see an icon of a clock or a hand appear or disappear indicating that the child lock has been set or unset.</li></ol><span style="font-weight: bold;">Delonghi Microwave:</span><br /> <ol> <li>To deactivate Child Lock, press the STOP/CLEAR key until the beep is heard.</li></ol><span style="font-weight: bold;">Delonghi Portable Air Conditioner:</span><br /> <ol> <li>Pressing the "+" and "-" buttons on the control panel together for more than two seconds unlocks the keypad.</li></ol><span style="font-weight: bold;">Fisher & Paykel Dish Drawer:</span><br /> <ol> <li>Disable the child lock by pressing and holding the key with a key and lock symbol printed on it until the padlock symbol disappears from the screen.</li></ol><span style="font-weight: bold;">Frigidaire Dishwasher:</span><br /> <ol> <li>Press and hold the No Head Dry button (or the Rinse Only, Delay Start or Air Dry button depending on model) for 3 seconds.</li></ol><span style="font-weight: bold;">Frigidaire Dryer:</span><br /> <ol> <li>Press and hold the "Control Lock" button for five seconds to release the lock.</li></ol>or<br /> <ol> <li>Press and hold the "Options" and "Select" buttons simultaneously and hold for 10 seconds to release the door lock.</li></ol><span style="font-weight: bold;">GE Dishwasher:</span><br /> <ol> <li>Press and hold the Heated Dry button for 3 secs.</li></ol><span style="font-weight: bold;">GE Electric Stove:</span><br /> <ol> <li>Press and hold "Lock" for three seconds to release the child lock function.</li></ol><span style="font-weight: bold;">Kenmore Dishwashers:</span><br /> <ol> <li>Press the "Heated Dry" button, and hold for four seconds until the "Lock On" icon light turns off.</li></ol>or<br /> <ol> <li>Hold the "Sensor Dry" or "Lock" symbol down for three seconds until the lock indicator light goes off.</li></ol><span style="font-weight: bold;">Kenmore Dryer:</span><br /> <ol> <li>Press and hold the AUTO DRY LEVEL button for 3 seconds.</li></ol><span style="font-weight: bold;">Kenmore Microwave:</span><br /> <ol> <li>Touch and hold Cancel for 5 seconds to deactivate the lock.</li></ol><span style="font-weight: bold;">Kenmore Range:</span><br /> <ol> <li>Push and hold the Lock button for 10 seconds.</li></ol><span style="font-weight: bold;">Kenmore Washing Machine:</span><br /> <ol> <li>Press and hold "Drain & Spin" for 3 seconds to release the child lock.</li></ol>or<br /> <ol> <li>Press and hold Cancel for 10 seconds.</li></ol>or<br /> <ol> <li>Hold the "End of Cycle" button down for 5 to 6 seconds.</li></ol>or<br /> <ol> <li>Hold the Child Lock button for 5 seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Dishwasher:</span><br /> <ol> <li>Press and hold Energy Saver/Dry button for 5 seconds.</li></ol>or<br /> <ol> <li>Press and hold Lock button for 5 seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Microwave:</span><br /> <ol> <li>Press and hold the "Cancel" or "Start" button for five seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Oven:</span><br /> <ol> <li>Touch and hold START for 5 seconds.</li></ol><span style="font-weight: bold;">LG Dishwasher:</span><br /> <ol> <li>Press and hold the Spray and Rinse button simultaneously for 3 seconds.</li></ol><span style="font-weight: bold;">LG Dryer:</span><br /> <ol> <li>In models that include a rack dry, usually holding the [rack dry] button for three seconds will disable the function.</li></ol><span style="font-weight: bold;">LG Refrigerator:</span><br /> <ol> <li>Press and hold the Lock button for 3 seconds.</li></ol><span style="font-weight: bold;">LG TV:</span><br /> <ol> <li>Open the menu, select lock (padlock symbol) then select lock system, then select off.</li> <li>Press exit to exit the menu.<br /></li></ol><span style="font-weight: bold;">LG Washing Machine:</span><br /> <ol> <li>Press and hold "Dry" & "Spin" buttons together for a few seconds. </li></ol>or<br /> <ol> <li>Press and hold "options & select" until the light goes off.</li></ol>or<br /> <ol> <li>Press and hold "end of cycle" for over 5 seconds.</li></ol>or<br /> <ol> <li>Press and hold the PRE-WASH/Child Lock buttons for 3 seconds. </li></ol><span style="font-weight: bold;">Maytag Dishwasher:</span><br /> <ol> <li>Press the Heated Dry button for three seconds.</li></ol><span style="font-weight: bold;">Maytag Microwave:</span><br /> <ol> <li>Press and hold the "Enter/Start" button for 3 seconds</li></ol><span style="font-weight: bold;">Panasonic Microwave:</span><br /> <ol> <li>Press "Stop/Cancel" 3 times to deactivate Child Lock.</li></ol><span style="font-weight: bold;">Philips TV:</span><br /> <ol> <li>Using your TV Remote, press the 'MENU' button, select FEATURES and press cursor right.</li> <li>Press cursor up/down to select CHILD LOCK and press cursor right.</li> <li>The screen will prompt you for PASSWORD, key in you password if known. If the password is unknown, then key in the code 0711 twice.</li> <li>Press cursor up/down to select CHILD LOCK, press cursor right to change the status to OFF.<br /></li></ol><span style="font-weight: bold;">Samsung Dishwasher:</span><br /> <ol> <li>Hold down the Delicate and Rinse buttons simultaneously for three 3 seconds.<br /></li></ol><span style="font-weight: bold;">Samsung Refrigerator:</span><br /> <ol> <li>Press and hold the Ice Off/Lock button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Ice Off button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Lighting button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Child Lock button for 3 seconds.</li></ol><span style="font-weight: bold;">Whirlpool Dishwasher:</span><br /> <ol> <li>Press and hold Heated Dry button for 4 secs.</li></ol><span style="font-weight: bold;">Whirlpool Dryer:</span><br /> <ol> <li>Press and hold the END OF CYCLE SIGNAL button for 3 seconds.</li></ol><span style="font-weight: bold;">Whirlpool Washing Machine:</span><br /> <ol> <li>Press and hold the END OF CYCLE SIGNAL button for 3 seconds.</li></ol>
on Jun 17, 2011 | Washing Machines
JVC AV56P776 Projection TV Green Light Flashes Won't turn On
Could be an open internal fuse or power supply failure
Jun 17, 2017 | JVC Televison & Video
Printer won't turn on.
Common problem with this particular Printer is a Bad Power Supply,needs to be replaced,its nothing related to the cleaning you did.
you have Order a new power supply Board,open the back cover of printer and Install it.
Feb 04, 2012 | HP DeskJet 1220c InkJet Printer
Dishwasher won't run. keypad buttons light when pushed, and I've locked and unlocked the keypad, which seems to be otherwise functioning normally. It has been working fine until now. I push...
Hello, welcome to FixYa. If you can provide the model number (usually on inside of door frame or tub frame around door opening) and make/brand name, I'll see what I can find for you. It does sound like a door switch, but I'll need to clarify the make & model before moving forward. Regards, Macmarkus :)
Jun 04, 2011 | Dishwashers
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
TV will not turn on
Hey guys this one is a no brainer when you push power button AND STANDBY LIGHT COMES ON NEXT PUSH THE BUTTON ON THE LEFT NEXT TO POWER BUTTON AND WALLA IT TURNS ON
Nov 11, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
