Question about Samsung SV5000W VHS VCR
Tapes keep getting stuck
I had a tracking problem for a while - bought a head cleaning device which seemed to solve that. Now my tapes continually get stuck in the machine. I have tried playing the cleaning video again but it won't play either in play mode or record mode. Please help!
  • 1 more comment
  • eskieguy Jul 27, 2008
    Checked inside, found that the tape guide by the pinch roller is binding & not swinging out of the way for eject.
    Can this be lubricated? What is recommended?
  • timcarder Nov 27, 2008
    The take-up reels are not turning when FF REW or PLAY are engaged, and when tape is ejected causing tape to not be rewound into housing. Capstan/pinh roller working OK. How to fix to get take-up reels working?
  • UncleJeff May 11, 2010
    My Sony Walkman GV D900 doesn't always respond correctly to physical controls. I press play or pause or display and it might rewind or fast forward. What should be done and where should I take it? I live in Orange County Calif. Thanks for your help.
    Jeff
  • 53 Answers
Yo guys for the most part some good answers. the first place to check would be the mode select switch. easy fix (if you know what you are doing) then new belts and a good clean/lube repair should not exceed $90.00 usd.
Posted on Mar 15, 2007
Buy a new vcr
Posted on Mar 10, 2007
We have 4 of the decks. they will often fail to unload panasonic and maxell tapes, i think its due to the design of the reel bases. sony tapes always work fine, they are flat where the others have a groove.
Posted on Nov 27, 2006
    Champion:
  • 221 Answers
Most likely problem is the gears/arms on the side of the cassette housing. The gears connect to the arms with a circular spring, but the tabs on the arms and gears are plastic. After many hours of operation, the tabs break and the spring no longer provides the connection between the gears and arms. Solution is rebuild of the cassette housing assembly, involving replacement of the arms, gears and springs. Typical cost is about 200.00 (parts and labor.)
Posted on Oct 11, 2006
    Novelist:
    Champion:
  • 275 Answers
If tapes are getting stuck / enmeshed inside the machine, itis 90% probability) a mechanical problem. Change the Belts, clean all rollers, idlers, and braking pads. I would suggest that you also replace the Capstan Pinch Roller.
Posted on Sep 29, 2006
    Problem Solver:
  • 10 Answers
No no to head cleaners ,but your problem is in the power supply 2 to five capacitors,always different
Posted on Sep 28, 2006
    President:
  • 3,130 Answers
If your tapes are getting stuck, then most likly it is not a cleaning issue, but a mechanical problem. It would be something in the take up supply reel mechanism. Like a bad clutch, take-up gear or idler, and /or a bad or broken belt.
2 Suggested Answers
  • 3 Answers
SOURCE: video tape gets stuck when playing
Did you also clean the rollers and other spindles where the tape also runs? It is not only the heads that will get 'sticky' & grab the tape.
Good luck.
Posted on Dec 18, 2012
The VCR is completely off track.. Does anybody has any solutions?
If by "off track" you mean it cannot track an image on the tape, it may just need cleaning. The heads, head drums, guides, and rollers in the playback mechanism require cleaning on a regular basis and, if they are not cleaned regularly, oxide particles and dirt accumulate to the point that the VCR is no longer able to play tapes.
Although automatic head cleaners are available, they're more for maintenance, and if it isn't playing tapes anymore it's beyond that. I would recommend taking the VCR to a repair shop for cleaning... shouldn't cost very much, and it should solve your problem. (Let's hope that the heads aren't worn down... bit more of an issue.... but try the cleaning first.)
Once you have the unit running again, buy an automatic cleaning tape and use it every few plays.
May 21, 2015 | Panasonic DMR-E75V DVD Player/VCR
Pixma mx452 error 5100
In my case the printer head was going all the way to the left and ending up "stuck" there. The print head could still be moved easily from left to right manually but when you turned the printer on it ended on the left side and I got the 5100 error.
I turned off the printer and disconnected the power. I took a flash light and carefully inspected the clear ribbon. In the middle there was a bit of goop on the clear "timing tape", about 1cm long. I used a clean paper towel with a bit of alcohol on it along with a rubber coated pen to keep everything away from the grease on the track and gently hold the ribbon in place while I cleaned the goop off of the tape. After that the 5100 cleared and the printer is working again.
It looks to me like the clear tape is just an indexed strip that's used to tell the print head how far it has moved. With some of the index obscured by the goop the print head thought it hadn't traveled as far as it had because it was reading fewer lines in the index. The goop was probably some grease from the track the print heads go back and forth on. Not sure how it got on the tape, but cleaning it off solved the problem for me.
I have no idea what the long term effect of ink on the plastic tape will be, but it got the printer working when I needed it and saved me from having to have it professionally repaired.
Nov 08, 2013 | Canon Office Equipment & Supplies
Vcr wont play properly tracking seems to be off i have opened up the vcr player and given everything a good inspection but cant see any obvious issue with the ''mechanics'' of the device. The tape being...
It is possibe that the guide of the tape transport is gone a little off. This can happen if the guide has not loaded properly. check inside for obstructions to the link. if not try to screw down the half split screw a little down on either side to release the tracking/ noise onthe screen. Also clean the tracking head which is also the audio head. clean your roller if this is holding down the tape. Please do this with caution and care. clean your head and also the lower section of the head drum for dirt. you will see accumulation on/under the lower drum , Hope this helps. Good day
Jul 10, 2010 | Sony SLV-940HF VCR
My jvc has developed a tracking problem when viewing tapes recorded on other recorders. I cant seem to correct the problem. It shows old tapes without a problem
VCR tracking has to be set up right, but even then many machines have problems with tracking other vcr's tapes. Generally a good quality commercial tape should track well. If it doesn't then either there's a fault with the tracking on your machine or the tracking is not set up right. Most tracking problems are caused by dirt, or wear on the heads or surfaces. Give your VCR a good clean up, every surface the tape comes into contact with, using Servisol Video 40. If that doesn't solve it you might have to look into the cost of replacing heads, maybe the control/audio head first. Or you should look at having the tracking set up by a proffessional (at a JVC service center). However if the tracking was off, after resetting any tapes the machine has done, may now have problems tracking, whilst other machines tapes and commercial will track normal.
Jun 28, 2010 | JVC HR-S6970 S-VHS VCR
Playing Tape to End Requires Head Cleaning Every Time
it seems your tracking needs to be looked at.also have a look at the tape open front section button at side slide open with your finger.look at the tape toward the light,if the edge of the tape is a bit wavey not straight you will need an alighnment as well.
Apr 26, 2010 | Sony DSR-11 DV / Mini DV VCR
Can't play a tape back. Shows ''Trac'' as problem but no idea how to fix it
"Trac" means tracking. If adjusting the tracking controls doesn't solve the problem, you might need to clean the tape heads with Servisol Video 40. Clean the smaller heads first, then the drum and head.
You can get Servisol from most electronics shops.
Jan 08, 2010 | Hitachi Televison & Video
Horizontal grey lines on tape playback
please state the age of your devices. It can help a great lot in solving your problems. The lines that you get aren't continuous, are they? They appear to be going up and down, are different sizes and shift as the tape plays, yes? well, this is simple. You need to clean your recording head.
Sep 23, 2009 | Canon ZR200 Mini DV Digital Camcorder
The tracking is off when I play back video.
You need to use a head cleaner. Buy a good head cleaning tape and run it for about 10- 15 seconds and see if you problem clears up. Check your tape transport for dust and dirt and clean it out with a small can of compressed air. Checkk the tape heads and see if they are worn out. Usually looks like a black strip in the middle of the head. You may need to replace the heads. I hope this information help you with your problem.
Jan 28, 2009 | Quasar VM-L152 Camcorder
No video playback
Maybe the video heads have become clogged. Try using a commercial head cleaning tape to solve the problem. I would recommend the one that uses the fluid.
Jul 29, 2006 | Daewoo DV-T8DN VHS VCR
Samsung SV5000W VHS VCR Logo
340 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
