Nike Mettle Chisel Watch Black WC0045 001 Logo
Bruce Buirkle Posted on Mar 12, 2012
Wc0045 set time
How to set time
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 05, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
603
Points
I have a Nike WC0045 the battery died on it.I replaced battery and it only lasted 3 days.
I am very sorry to hear that news, just dreadful :>(
I was trying to find out who actually makes this watch, but there is no data. Normally you send to the maker and they repair it. My late wife bought me a Seiko, and although I live in Canada, I send it to the UK where it was purchased and where the service centre is for servicing. you could ask Nike who was contracted to produce it? My guess is Casio, because it has the Casio look to it.
One thought I have is that the battery that was put in it was the wrong type or it was inadvertently replaced with a battery out of another watch that came in for repair. I would have another battery put in it and see what happens. It is actually a collectible watch.
https://www.google.com/search?q=Who+makes+Nike+WC0045
There are a few ideas which battery is the correct one
https://www.google.com/search?q=nike+wc0045+watch+battery+replacement
tip
Manual of instructions for wacth Nike Chise Wc0045-001
I'm trying o find a manual of instructions for wacth Nike Chise Wc0045-001.<br /> If somebody have it please send me by email <a href="mailto:[email protected]">[email protected]</a><br /> thanks<br /> Valeria
1helpful
How to set the time on a Dakota one button watch
To set the time on a Dakota one button watch, you will need to follow the instructions in the user manual that came with the watch. If you do not have the user manual, you can try the following steps:
  1. Press and hold the button on the top right side of the watch: Press and hold the button until the time display appears.
  2. Set the time: Use the button to set the time. The specific sequence for setting the time will depend on the make and model of your watch.
  3. Exit the time setting mode: Once the time is set, you will need to exit the time setting mode. The specific steps for exiting the time setting mode will depend on the make and model of your watch.
It is important to note that the steps for setting the time on a Dakota one button watch may vary depending on the specific make and model of the watch. If you are unable to set the time using the steps above, it is recommended to refer to the user manual or contact Dakota customer support for assistance.
If you have a "his and hers" set of Dakota watches, the steps for setting the time on both watches should be the same. You can use the steps above to set the time on both watches.
1helpful
How to set time on polar rs300x
Access watch settings scrolling by UP/Down button.
<Settings> <Ok> <Watch> <Time and Date Settings>
In Time Settings:
Set the local time (Time 1) and a time difference to it (Time 2).
With Time zone, you can select which time zone is used.
In Time view, you can easily change the time zone from Time 1 to Time 2 by pressing and holding DOWN.
Set the date with Date setting.
You can also download the user manual from the link below
http://www.polar.com/e_manuals/RS300X/Polar_RS300X_user_manual_English.pdf
How do I change the time on my fossil watch dq1185
Time Setting Instructions:First press and hold ST/STP for a few seconds and make sure it says (Time 1). This watch has a (Time 2) to use in other time zones.You change from Time 1 and Time 2 by pushing the ST/STP button for a few seconds.Time 1 setting:- Press and hold the SET button (Light Function will blink) use the ST/STP button to select on or off. Then push the Mode button to go to the next function.- The Chime function will blink. Use the ST/STP button to select on or off and then push the Mode button to go to the next function.- Next will be to select 12hour or 24hour time by using the ST/STP button then press the Mode button to set the Hour, Minutes, and Seconds.- Continue to set the year but when you get to the Month/Day you have the option of putting the day first then the month, use the ST/STP to select then push the Mode button to enter the month and day.- When satisfied with your settings push the SET button and your done.
Time 2 Setting:- Press and hold the ST/STP button it will say Time 2 and then go away only showing the time and date for Time 2- To adjust this time to another time zone you push and hold the SET button.- Use the ST/STP button and the RESET button to move ahead or behind in hours depending on time zone. Push the SET button when done.-Your time 2 is set for a different time zone and your Time 1 is set for your local time. Remember to use the ST/STP button to go back and forth from Time 1 to Time 2.
If my light and the alarm noise is out, does that mean I have a low battery?
Not necessarily , you can try opening the back and exchanging the battery. It is pretty easy to do and the batteries only cost like 3 dollars.
If its not that then it will need to be serviced in order to work again , if you had bought it within the last year then you can get it done free from Nike .
http://www.nikewatchrepair.com/
thats the link and instructions you do not need to fill out form if you do not have receipt just send a note with watch when you bought it and whats wrong with it along with your name email phone number and return address.
hope that helps
2answers
50helpful
Tipsy clock programming lost leaflet. would like to down load leaflet. bought this inexpensive clock at BB&B.
Hi I was having a hard time with this too, but luckily I found my leaflet.
To set time:
Press Mode 1 time
Press Set 2 times/ press up or down for hour
Press Set again for minute
Continue Pressing Set (up to 6 times) until everything is set
Back to normal mode- Press Mode 4 times
To toggle between 12 hr and 24 hr, press Mode 1 time
To Set an Alarm:
Press Mode 2 times
Press Set 1 times for hour, continue pressing set like you did for the clock.
Back to normal mode Press Mode 3 times
To cancel Alarm Press Mode 2 times and Set 5 times
Jan 16, 2010 • Watches
Top Nike Watches Experts
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
ADMIN Eric
ADMIN Eric
Are you a Nike Watch Expert? Answer questions, earn points and help others
