Question about LG 42LC2D 42 in. LCD HDTV
LG 42in LCD TV no picture
We have just bought a second hand tv.... the first 2 night was working perfect but now there is no picture!! we have changed the scart plugs and there is no difference. it switches from stand by to on but there is no picture and on e had the same proplem?? any help please.... ????
Chuck it in the bin!!!!!!
Posted on Nov 03, 2008
LG 42in Class 1080p 120Hz LCD HDTV red light stays
Hi
Your tv set is stuck in the standby mode as a components went shortcircuit in one of the power supply rails and should be serviced by qualified personnel.
Sully
Sep 29, 2013 | LG 42LC2D 42 in. LCD HDTV
Falt screen tv has a white screen when I turn it on,audio ok,picture comes on after about 20 minutes,any ideas?
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jul 18, 2012 | LG Electronics 42IN WS LCD 1920X1080...
I just bought my 42in last night and I attached my cable box to it, with a normal black coaxal cable and the red/white/yellow hookups. The only problem i have is the picture looks kind of grainy and...
Cable box have HDMI port,hook it up on a HDMI cable to the tv,will improve picture quality greatly.Tries HDMI cable to hook up the PS3 system and go in setup changes to HDMI setup will get HD format picture,will be very clear no more grainy and inconsistanty.
Feb 17, 2011 | Sansui HDLCD-4212 LCD TV
Picture takes split second to focus
That normal,this tv a year or more right?Mornal progressing the aging of the tv.
Mar 19, 2010 | LG 42PQ30 42 in. Plasma TV
I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Feb 04, 2010 | LG 42LC2D 42 in. LCD HDTV
No picture or response - LG LCD TV
Hi, I have the exact same problem. I was wondering if you could tell me how you fixed it? Mine is only 2 hours old from the box
Jun 03, 2009 | LG 42LG30 42 in. LCD HDTV
TV/DVD Combo will not switch back to live TV when DVD is ejected.
I had the same problem with the same unit when I first bought it a few months ago.
First up remove the DVD. If the TV stations do not appear within a couple of seconds press the "TV" button (top, second from left) on your remote control.
Let me know if this doesn't work.
Apr 28, 2009 | LG 26LG30 26 in. LCD TV
Frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Dec 09, 2008 | LG 37LC7D 37 in. LCD HDTV
42 in LG LCD TV turns off by itself
Found that TV started switching off by itself. Would try to come on..green light blinked for 2-3 seconds, tv came on (with picture and sound) for 1 or 2 seconds and then it would turn itself off. Found that the issue is with one channel only. If you are facing this issue....try quickly changing the channel the moment it comes on. You can do it either with remote or with the TV buttons directly. also in the same logic, if this is still happening, try changing the source to another (rgb-pc, av1, av2 etc). Basically change it from whatever input it is on currently, if changing the channels does not work. My symptom was that the tv made a loud 'TIK' 'TAK' sound which is louder than normal.
Jan 22, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 42in LCD Television - turning unit off
The amount of standyby power consumtion is minimal. The only way to turn it off completly is to disconnect the power from the TV. This will however increase your start up time when you want to use the TV.
Nov 28, 2007 | LG 42LC2D 42 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
Computer Repairing
Computer Repairing
