It sounds like the tub is rubbing when I spin the tub by hand. I noticed after I did a load of wash that is had a smell like something was burning. I could also see a little smoke haze. I noticed this after doing a load of towels with a high spin speed.
SOURCE: Front Loading LG Washing Machine leaves smelly sludge in wash tub
I have a front loading machine also and am not willing to have to constantly clean out the machine -- the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution. MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts. They are not very cheap but they work great -- I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain. YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health! I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon.
SOURCE: LG WM1812CW noise
Other than seperating the drums you could try to remove the heater element which will allow you limited access to the cavity between the drums. Shine a torch in there and rotate the inner drum slowly untill the offending piece comes into view. Remove with a long tweesers or hook.
SOURCE: LG WM0642HW washer gives error during spin cycle and stops.
I have this problem and you can find the solution on this same web page by searching. It is likely the Hall Sensor that needs to be replaced (see proflevy posting on Jul 16, 2008). According to the postings, it is from soap build up on the sensor and replacing it costs $18 for the part and is easy (many responses on this). I am waiting for the part and will try to fix mine soon.
SOURCE: Sewer smelling towels!!!
Put a cup of powdered dishwashing detergent in the barrel ie. Sunlight or Palmolive. Place 1 cup of bleach in the soap dispenser. Run on a quick cycle with HOT/HOT and run complete cycle. This does help and don't forget to clean the filter on the lower part of the unit.
SOURCE: Error Message and Tub not spinning
Depending on how many clothes are in the washer you may a unbalance error
