Question about Sharp AR-5316 Advanced Digital Imager Copier
Problem with changing the Toner Copier Cartridge
Good Day Sir,
Am having problem with the New Toner Cartridge i bought. if i insert it, the copier will begin to display F and 2 on the screen of the copier but if i insert back the old toner cartridge the copier will start normal. what can i do to use the new cartridge because the toner in the old toner cartridge has finish. how can i insert it and correct the F 2 that is blinking on the screen. please help
thanks
  • 1 more comment
  • lenient02 Nov 03, 2008
    thanks
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this a genuine Sharp cartridge or a refilled/remanufactured one?
  • Tim Babcock
    Is there two other number blinking after the f2?
    Try unplugging the machine from the outlet. Wait 30 seconds and plug it back in.
    This error isn't anything to do with the toner section of the copier, but the optics section of the copier.
  • Sharp Master
  • 2,794 Answers
F2 has to do with a toner sensor not working. It could be the replacement cartridge is missing something. Make sure you use a genuine Sharp toner cartridge and that should take care of the problem.
Posted on Nov 07, 2008
How can i solve error code f2-04 in sharp 5127
The main reason for the error code is an incorrect toner cartridge being used in the copier. You can turn the copier off, but it will not flush from memory. in order to correct the issue perform the following:
1. Turn the printer off 2. Remove the incorrect toner cartridge 2. Unplug the power cable from the wall outlet. 4. Plug the Printer back on 5 Turn the printer back on
You will see the message change to another message requesting to insert the toner cartridge.
6. Insert the old or new correct toner cartridge into the copier.
If this resolves the problem good else you will have to replce the carrtridge.
Sep 11, 2011 | Canon imageRUNNER 8500 Copier
How do i get the toner cartridge out to change it
If there is a specific point on here that you are having trouble with leave a comment and I will get back to you:
1. Open the front cover
2. Pull out the drum unit (with the toner cartridge in it). There should be a handle as soon as you open the cover to pull.
3. On the drum unit, find a green or blue tab on the left side to push down that makes the toner cartridge pop up. Pull out the toner.
4. Insert the new cartridge into the drum untill the tab clicks into place.
5. Insert the drum unit into the printer and close the cover.
Hope this helps. Good Luck!
Aug 23, 2010 | Brother DCP-7020 Black and White Copier
My MF8180C is asking to replace the K cartridge, and I have bought a 301 toner cartridge but the printer has a drum cartridge instead. How do I replace the black toner into the drum cartridge or do I have...
the toner crg is located in front of copier, the drum is separated from toner and it removes if you open upper cover.
If the copier ask you for toner open front cover and replace toner.
You do not have to replace drum if the copier doesnt tell you to replace.
Jul 11, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
Refill toner for samsung 4300
Good day Sir,
I suggest do not refill the toner cartridge. The machine warranty does not cover damage caused by using a refilled toner cartridge.
Always replace it with a new one and make sure the cartridge is genuine to prevent toner errors.
have a nice day!
Apr 20, 2010 | Samsung SCX-4300 Monochrome Laser...
Error code F2-04. Have replaced cartridge but to no avail for the Sharp Model # AR 168S Copier.
Try this solution I found on an other site.
In a Sharp MX-M450N copier this is due to improper cartridge.
The reason for the error code is of course due to an incorrect toner cartridge being used on the copier. You can turn the copier off, but it will not flush from memory. in order to correct the issue perform the following:
Dec 28, 2009 | Office Equipment & Supplies
Minolta copier 1030, changed toner makes no copies
take the toner bottle out. turn off the machine then turn it on with the bottle out. once the machine, ask for toner install the bottle.
Jun 18, 2009 | Konica Minolta Office Equipment & Supplies
Replacing of new Cartridge problem
good day sir
I am Josco and my Email:oyas20102005@yahoo.com.
I have a lot of Sharp Copier but there is one that is giving me comcern coming out with a code (showing H & 4) and i can not work with the copier Sharp Digital AR-5316. please what do i do and it is the newest copiers among all, please i will be very glad to recieve a code so as t clear the interupting showing H & 4 on the copier.
Thanks
Josco from Nigeria.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
I BOUGHT A REPLACEMENT CARTRIDGE FROM A COMPANY THAT REMANUFACTURES THEM THRU XEROX,ANYWAY THE INK TONER CARTRIDGE IS FOR YOUR Z-85II COPIER AND THE INK WAS EVERYWHERE WHEN I TOOK IT OUT OF THE PACKAGE AND...
You are right about the cartridges having a seal. These toner remanufacturing companies are known as TONER PIRATES, they don't change the drum or cleaning blade, they just dump in toner.
Try wiping the inside with STRETCH AND DUST cloths before you put the new cartridge in.
If that doesn't work, I have to recommend that you get it cleaned, as the spilled toner will blow straight through a regular vacuum.
Oct 28, 2008 | Sharp Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
126 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
