Question about RCA F25422 25" TV
RCA F25422 the picture on my RCA F25422 is not working but the sound is fine i'm wondering where the solder would be loose at.
    Sergeant:
  • 337 Answers
The solder could be loose in the CRT board witch is at the end of the picture tube neck,before you take the back cover out try a simple test put your forearm in the face of the picture tube and the hair should stand with the tv on that will mean you do have high voltage going to the picture tube but if the hair in your forearm does not stand with static it means the picture tube is missing high voltage and then reason for that is not necessarely a loose conection but a bad component in the main board.If you not familiar with tv service be safe and call for assistance.
Posted on Sep 28, 2006
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
Problem with RCA F25422 25
what is the problem with your tv might can help you.
Sep 17, 2012 | RCA F25422 25" TV
How do i get dish network to work on rca f25422 tv
Well, you have a couple options with this. You can use either coax cable, or RCA cables. If you use coax, you want to connect it on the receiver that says TV set out, and out the tv set on channel 3 or 4. If you use RCA cables, you want to connect these to the color coded connections on the back of the receiver labeled with a Green 1. The tv will need to be on channel 3 or 4, and a video in put, usually Video 1 or 2.
Becki Barned
DISH Network Customer Service
Feb 01, 2011 | RCA F25422 25" TV
I had kids messing with my rca gemstar f25422 tv the did something to the settings and i can see the menu to get it back
you should power off the television and power it on to see if the menu is still there or not , and it does not work.
check the remote carefully if menu is on it, then press menu to exist the menu . GOOD LUCK..........
May 21, 2010 | RCA F25422 25" TV
I have a rca model number F25422 perfect picture no sound what
I HAVE A 25' RCA WITH THE GUIDE PLUS ON IT. MY DVD PLAYER WILL NOT WORK ON THIS TV. HAVE ALL THE CABLES I NEED(RED,WHITE &YELL) AND THE CONVERTER BOX.
Apr 02, 2009 | RCA Televison & Video
RCA Home Theater (Model #P46924) No Picture, just sound
Sounds like a possible solder issue with the vertical output IC. Try resoldering the Vertical output IC connections
May 17, 2008 | RCA P46924 46" Rear Projection Television
Speaker for RCA F25422
i have a problem with mine If i get another one instead of fixing this one i will give it to you.
Jan 02, 2008 | RCA F25422 25" TV
Cable Input (Tuner)
why? and what is your main problem? can you wright your problem please!
Oct 08, 2007 | RCA F25422 25" TV
RCA F25422 25" TV Logo
153 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
