Question about Microsoft Xbox 360 Console
X box will play dvd's but won't load games
  • 225 Answers
This is common if the heat on the back of the DVD drive has got too much you can fix it by using a good Xbox 360 Repair guide.
Posted on Mar 13, 2012
  • 22 Answers
This is the symptoms of a worn laser. Doesn't matter which way the console is stored, the laser will wear out all the same. It takes more effore to read the Security Sector on a game than it does to read a DVD-Video, which is why movies still work. Get the laser replaced and you should be fine. You can eliminate laser wear by installing your commonly played games to HDD.
Posted on Aug 22, 2012
5 Suggested Answers
SOURCE:
SOURCE: X-BOX 360 not playing games
Are you sure that in the system settings the xbox is set to Load game instead of boot to dashboard? This will be located on the blade on the far right of the dashboard. If no help, try this: First, a stupid step - Make sure a compatible game disc is in the xbox, and turn it off. If it continues to boot to dashboard upon powering up, you could always try removing the system updates by: 1. Turn the console off 2. Press and hold the small sync button on the front of the console (the one you use to connect new controllers) 3. Turn on the console whilst still holding the sync button 4. By the time it has booted to the dashboard, the updates should be cleared. As the first version of the dashboard did not have the option to boot to dashboard by default, game discs should start normally now. If this is the case, feel free to re-download the updates from xbox live. Hope this helps!
Posted on Jun 24, 2007
SOURCE: x box 360 wont load any discs . game
As long as it is the original drive in your system then it will need to be serviced or replaced with a new one. We can provide this service. Email us for a free estimate if interested.
xbox360fixer@verizon.net
Posted on Jan 16, 2009
  • 25 Answers
SOURCE: x-box 360 won't read discs
sounds like the reader lens has burnt out on it .is your xbox stood upright ? seem to hear the lenses burn out alot faster if the consol is upright as opposed to being led down, you can buy the parts from ebay or other computer shops , or send it back to microsoft to repair , you are able to lay downloaded games as they play off of the hard drive memory , where as the disc games obviously read off of the disc when the laser gets tired they work intermitantly then eventually stop all together.
hope this is of help to you
kind regards
bert31000
Posted on Mar 19, 2009
djredskyy
  • 670 Answers
SOURCE: Xbox 360 won't play new game - screen
old or new generation model? it might just need a good cleaning with one of those dvd cleaner cds you can buy. I have a game in general "home front" that sounds like my box is gonna blast off.
Posted on May 08, 2011
Disc won't play
May not have been finalized properly and is therefore corrupt.
Apr 19, 2013 | Sony Handycam DCR-DVD850 DVD Hybrid...
MOST GAMES WON'T PLAY THEY WILL BE INSTALL BUT WON'T RUN
is it compatible?
Right click on the game icon and select properties. Click on the compatibility tab and tick the box in the compatibility mode section. Select xp and click apply.Start the game and hopefully it works.
Sep 26, 2012 | Video Game Consoles & Games
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
I've installed My Horse and Me but every time I try to play it, it just runs the set-up to 'Modify', 'Repair' or 'Remove' the game. It won't let me play it.
I've this same issue, if someone's got a solution, please do share. :( I'm no noob when it comes to laptops but also not too much of a nerd either, i've ran the installation as administration and checked all the possible boxes and also changed the graphics. Still nothing.
Jun 06, 2012 | Atari MY HORSE & ME for Windows
My farmville won't open . The loading bar will not go all the way to the end
I don't have Farmville but I had a similar problem with the Sims 3 Ambitions, just delete the app and redownload it on iTunes (it will be free as you've already purchased it). Hope this was helpful!!!
Mar 20, 2012 | Zynga FarmVille by Zynga
Compact Disc rewritable DVD player won't load or play
Check the data connector on the rear of the drive. If this doesn't work you may need a new drive, they are cheap and readily available.
Jan 19, 2012 | Lenovo Computers & Internet
Apex DVD/Tv combo GT2015DV won't play dvd's
Something is wrong..crbr799 your DVD-TV has a TV-DVD button on the right front to switch from TV to DVD play...OPEN button on left side ,place DVD in tray, close & press PLAY...
I something simulator that needs the remote control for the SPECIAL functions....by the way the ORIGINAL r\c is $135 to $155, a replacement ($35) will turn the TV\DVD on ( which you can do without the r\c) and NOT function with anything else.
P.S. they will try to sell you universal r\c that work with the CABLE boxes, the ones that you pay a monthly fee!!
Aug 11, 2011 | Apex Digital Televison & Video
I bought a DVD set from Ireland and it won't play on my DVD player or my Wii. Is there a setting I need to change?
Hi there!
North American TVs, consoles and DVD players play video and games in the NTSC format (region 1), while Ireland's and most of Europe's play in PAL(region 2). You best bet to be able to watch your dvd set will be to purchase a dvd player that plays multi regions (these will be a bit more expensive) or to order a region 2 dvd player from Ireland or somewhere in Europe that uses region 2.
Hope this helps!
Jul 05, 2011 | Nintendo Wii Console
Can't load up a 3d game to play on my computer
If your Graphic Card does not support the 3D options, you won't be able any 3D PC games!
You have to look at your PC/Laptop specifications & the PC games requirements to play any higher graphic PC games. For any PC gaming PCs you have to install "DirectX' ie. latest version and updating graphic cards drivers too.
Hope it helps.
May 22, 2011 | Computers & Internet
Xbox 360 won't play new game - screen flickering on the 'press start' screen. plays cd's perfectly and was ok with games till put in new game from Morrisons.
May 08, 2011 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
489 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
