Question about Hitachi Televison & Video
LCD rear projection
Having a problem with my LCD rear projection the screen started out with a blue blob now has changed to a oval circle inthe middle of the screen that has turned yellow.
Called Hitachi
Posted on Nov 04, 2008
I have a ultravision 50v500 and it has a blue blob in the middle of screen. I have just changed the bulb with hardly any change in the blob. I also had the light engine changed approx 2 years ago.
That is caused by excess heat possibly due to poor air circulation/blocked filters.
It is damage to the LCD panels. It won't get any better, just worse.
So look for another Blue LCD panel and someone who is experienced to fit it.
Jan 07, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue haze/blob near the center and lower right corner.
Failing optical block. check this website
http://sites.google.com/site/sonylcdrptvproblems/sonykdf-55wf655opticalblockreplacement
Mar 08, 2010 | Sony KDF-E50A10 TV
50 INCH rear projection LCD Gettign blue spots on screen forming a circle?
A discolored Blob or blotchy pattern usually in the center of the screen. the problem is becoming all too common with Hitachi projection sets. What happens is that one of the lenses in the optical block (or light engine) starts to burn or discolor due to overheating because of a blocked air filter causing poor air (cooling) circulation. Nothing can be done when the damage is too far-gone except to replace the light engine-at a cost that makes it not worth repair. if the damage is minimal than to reduce further damage, the air filter should be replaced. The Light engine needs to be removed in order to replace the air filter
Have it checked by a tech it's worth the service call to know for sure
Oct 03, 2009 | Hitachi Televison & Video
Hitachi 55vs69a yellow blob in center
you most likely have a bad light engine.
Aug 20, 2009 | Televison & Video
I have a blue oval hue in the middle of my screen, how to fix?
This problem is known as a defective Light Engine. The cost is usually 800.00 plus.
May 01, 2009 | Sony KDF-E42A10 42 in. LCD Television
Yellow hue circle in middle of screen. after leaving tv on all night
spherical or oval shaped light starting in the center of your picture is an indication of an led backlit tv.. probably a hitachi. solution, replace light engine..ps no garuntees not with led backlit sets.. was bad idea to begin with. when the leds start going they start at the center and branch out.
Apr 13, 2009 | Hitachi 50V715 50" Rear Projection...
I have a hitachi 50 in rear projection tv and i am getting a yellow circle through out the middle of the screen what do you think that is and how do i fix it?
I looked back and see your talking about a crt type. My bad. A small yellow spot is most likely dirt or a bug in the blue optics. Tale the front off the set and with the tv on look down into the lenses. If you see a blob of dirt or a bug this is your trouble. Be careful not to move the blue tube but take the lens assembly off and clean the surfaces. There are four screw that hold just the lens assembly. The other screws shouldn't be touched. It will need alignment otherwise.
Mar 28, 2009 | Hitachi 50UX57B 50" Rear Projection...
Blue streak at bottem of screen
You have the classic "blue blobs," In most of Sony's rear projection LCD's, the Optical block is bad. Manufacturer's defect. The blue panel inside of the optical block starts de-laminating (due to heat from the lamp). This is a very common problem. I have changed about 70-80 optical blocks myself over the course of about 4 years.
There is no other fix but to replace the optical block. Unfortunately, it will get worse, and will probably develop "stars," or stuck pixels, as well. You can call Sony and try to get some assistance, but the extended warranty on these sets has recently expired.
Hope this helps you in some way...
Jan 04, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Zenith d52wlcd 52in rear projection
How this is it? Is it perfect or is it like a blob of blue going down the screen? can you see the picture behind it or is there no picture in that area?
Sep 15, 2008 | Zenith D52WLCD 52" Rear Projection...
Hitachi 50v500
To all that are experiencing the blue blob. This is result of poor maintenance. Projectors must be kept clean on all air intakes. This is to help you all understand the failure cause. Usally not worth repairing.
Aug 21, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
133 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
