Fixing the my computer shut off unexpectilly and when it turned back on..,the "Power On" window now appears and I can't get the computer to boot up or pass that screen...,it gives my three chances to enter a code...,can anybody help?
    Master:
  • 409 Answers
Sounds like you have a boot/hard disk password. You need to contact who ever set it to find out what it is.
Posted on Nov 03, 2008
Computer won't boot up
You have to give more information about the behaviour..You computer shuts off..when exactly ? Has it passed bios check? Are windows loading or windows screen appears..?Can you open bios setup while booting?
However..shutting off..seems to me that the Power Unit may have failed
Nov 11, 2013 | Gateway Computers & Internet
Tip
Reboot and run in safe mode in windows 7,Vista,XP or 2000
Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system.
1.) Click the "Start" button from the taskbar. Select the "Turn off computer" option if you are running a Windows OS Operating System before Windows Vista, or select the right arrow in Vista. Select the "Restart" option
2.) Press and hold the Ctrl+Alt+Del keys simultaneously. Do it again. This will reboot the computer
3.) Shut down the computer. Sometimes the computer will not respond to a reboot. Maybe the keys are temporarily disabled or the system has chosen to completely ignore you. In these rare cases, it may be better to shut the computer off using the power button. If you do shut off the computer, press and hold the power button for 3 to 5 seconds. Then be sure to wait a minimum of 45 seconds before turning it back on. This allows the capacitors in the computer time to discharge, which allows the memory (not the hard drive) to do a full dump of data. This allows a cleaner restart when you turn the computer back on.
4.)Disconnect the power cord. Do this as a last resort. Unsaved data may not be retrievable with this option, but sometimes it is the only option. Reconnect the power cord. Turn the computer on. else Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system. If you have a problem with your hardware configuration or your computer's display drivers that prevents Windows from loading normally, you may be able to resolve the problem by booting into Safe Mode and changing the relevant settings. To enter Safe Mode in Windows 7, Vista, XP, or 2000:
Note: If you have more than one partition installed, you may need to select an operating system and press Enter before entering Safe Mode.
Turn on or restart your computer.
After the memory test, the words "Starting Windows" will appear on a black background. When this happens, press and hold the F8 key. This will present a screen with the following options to choose from. The exact moment that F8 is pressed will determine the contents of the list, and the list may vary from computer to computer. For example, your computer may not do a memory test or it may have a SCSI BIOS to load in addition to the motherboard's BIOS. If you have trouble getting the list below to appear, restart the computer and then press F8 repeatedly while the computer is starting.
Safe Mode: Boots Windows with only the basic drivers needed to load the operating system. Uses basic drivers for mouse, keyboard, display (VGA), mass storage, and default system services and drivers, with no network components. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.
Safe Mode with Networking: Loads the Safe Mode configuration, but also enables network devices and services. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.
Safe Mode with Command Prompt: Loads Windows in Safe Mode, and, after logging in, opens a command prompt instead of the normal desktop. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.Note: You should try booting to the command prompt only if you feel comfortable operating within the DOS environment.
Enable Boot Logging: Boots Windows with all of the normal files and drivers, but writes their status to a log file at each step. In Windows 2000, this log file is located in the Windows 2000 folder and is named ntbtlog.txt.
Enable VGA Mode: Boots Windows using a plain VGA 16-color 640x480 display driver for the highest level of compatibility with video cards. In Windows 7 and Vista, this mode is called Enable Low-Resolution Video. It is otherwise identical.
Last Known Good Configuration: Boots Windows using the last registry configuration that is known to work. This is a way of undoing problems created by installing incorrect drivers or possibly by registry corruption. It will not, however, fix problems caused by corrupted or missing files.
Use the arrow keys to move up or down this menu to make your selection, and then press Enter. If you need to update software or access the Internet while in Safe Mode, select "Safe Mode with Networking".
on Sep 15, 2010 | Computers & Internet
My computer won't start, it appears to have no power. For the past 2 weeks when ever I would start up it up I would have to constantly push the start button 3 to 5 times till it would power up. Now it...
Most likley you have a fried power supply. Try this first unplug the computer from the power cord for 5 minutes then plug back in and go into safe mode see how to go into safe mode below.
To start the computer in safe mode 1.
You should print these instructions before continuing. They will not be available after you shut your computer down in step 2.
2.
Click Start and then click Shut Down.
3.
In the drop-down list of the Shut Down Windows dialog box, click Restart, and then click OK.
4.
As your computer restarts but before Windows launches, press F8.
On a computer that is configured for booting to multiple operating systems, you can press F8 when the boot menu appears.
5.
Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
6.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
Chris Thrash
B52computers
Please Vote
Jan 10, 2011 | Gateway GT5014 PC Desktop
How do i reboot my computer my self.
Click the "Start" button from the taskbar. Select the "Turn off computer" option if you are running a Windows operating system before Windows Vista, or select the right arrow in Vista. Select the "Restart" option. 2.)Press and hold the Ctrl+Alt+Del keys simultaneously. Do it again. This will reboot the computer. 3.) Shut down the computer. Sometimes the computer will not respond to a reboot. Maybe the keys are temporarily disabled or the system has chosen to completely ignore you. In these rare cases, it may be better to shut the computer off using the power button. If you do shut off the computer, press and hold the power button for 3 to 5 seconds. Then be sure to wait a minimum of 45 seconds before turning it back on. This allows the capacitors in the computer time to discharge, which allows the memory (not the hard drive) to do a full dump of data. This allows a cleaner restart when you turn the computer back on. 4.)Disconnect the power cord. Do this as a last resort. Unsaved data may not be retrievable with this option, but sometimes it is the only option. Reconnect the power cord. Turn the computer on. else Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system. If you have a problem with your hardware configuration or your computer's display drivers that prevents Windows from loading normally, you may be able to resolve the problem by booting into Safe Mode and changing the relevant settings. To enter Safe Mode in Windows 7, Vista, XP, or 2000:
Safe Mode with Command Prompt: Loads Windows in Safe Mode, and, after logging in, opens a command prompt instead of the normal desktop. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder. Note: You should try booting to the command prompt only if you feel comfortable operating within the DOS environment.
All the Best!
Fujitsu Lifebook N6470 will not boot
Most times these kinda errors are issue with some kinda corrupted driver. Have you tired to boot in to safe mode. To do so shut down the laptop and when you press power to turn it on start tapping F8 key until advanced windows start up shows up.If you cant i would consider taking it back to store where you got it since pressing this button is not supposed to do anything. Most new computers come with Operating System reinstall built in which kinda sucks since some times you just cant get to it like in your case. Restore disk shoud work and you can try making Bios settings back to original since Vista will boot to the CD/DVD drive if it detects media. If this does not work i would not spend too much time on it and would replace it or have it fixed if you have extended warranty. I would also be very careful about posting Product key on any web sites. Hope this helps.
Jan 13, 2010 | Fujitsu LifeBook N6470 Notebook
Compaq Presario CQ50-142US Notebook PC. Playing Jewel Quest III on PC. Arrow stopped working. Nothing else would work. Shut PC off by shutting power off. Turned PC on and screen saver appeared with...
no ops system stated,? windows 7? or VISTA\
circa 2008 to 2011 old.
every post with Compaq in it is long. why is that?
answer, it old and sux, tops list. sorry'
its dead. and the onboard recovery fails too.
reasons, all.\
1: its virus infected ,so up dates or startup fixes or refesh fails.
as expected with all virus. (dah)
so why not use the HP.com media fresh install kit
google that, and win or ask HP. they will help, for sure.
only that works every TIME. unless.......
2: bad HDD ( a 10 year old hdd, what is its chances.. up grade to SSD now, sure)
here try the test
get a live boot CD/DVD, windows PE 8 or 10 , or linux live boot anything, (google live CD and learn)
does PC run good now, off CD/dvd drive? booted ?
yes, good, there is hope, see? see you can boot off
DVD or Usb sticks now.(UDISK)
so do the full fresh install of w7? next> if PC is good.?
as seen here
http://support.hp.com/us-en/drivers/selfservice/Compaq-Presario-CQ50-Notebook-PC-series/3739787/model/3813492
here is the recover disk or stick page
http://support.hp.com/us-en/document/bph07143
there is no lack of HP help or documentation.
Mar 26, 2017 | HP Computers & Internet
Dell Inspirion 1000 power short circuit
Good Evening:
Hope that you are wellJ
  • There appears to be a shortage in one of your lines to you computer. But, before you replace anything, try these methods.
  • Shut down the computer.
  • Remove any CDs, DVDs or external storage devices (like USB keys or external hard drives) from the computer, if any are present, then press the power button to turn the computer on.
  • Press and hold the <F8> key as your computer starts. You need to press <F8> before the Windows logo appears.
  • If the Windows logo appears, and the system still fails to boot to Windows, shut down the computer and try again.
  • From the Advanced Boot Options menu, use the arrow keys to highlight Repair Your Computer, then press <ENTER>.
  • Click to select your language, and then click NEXT.
  • Log in as a user with administrative rights, and click OK.
  • From the Choose a recovery tool menu, click Startup Repair .
  • Once completed, click FINISH.
  • Click RESTART.
If I can be of further assistance, please let me know
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful weekend.
Oct 03, 2008 | Dell Inspiron 1000 Notebook
A problem has been detected an window has shut down to prevent damage to my computer
boot into safe mode by pressing f8 at windows boot time,
run a check disk by rightclicking the harddisk, properties, tools, check disk
check both options for file recovery and system file fix, click ok rebboot
see what happens and get back to me
or
use a bootable media like the windows system disk to enter the recovery console and run checkdisk from there
get back to me
Dec 14, 2007 | Acer Aspire 5630 Notebook
HELP!!! Computer stopped working when anit-virus was installed?????
Assuming you are using windows xp. 1. Boot up into windows safe mode by pressing the "F8" key during boot process. 2. Choose "Safe Mode without networking" on the menu and after entering your desktop a pop-up will appear telling you that you are using windows safe mode, just press "OK" then uninstall Norton Anti-Virus. 3. Shut-down and/or reboot computer. Another alternative would be to boot into safe mode and perform a system restore. If you choose to do this, you still need to uninstall Norton Anti-Virus because a system restore will only fix just system files not programs that were installed. In other words, you will have a partial installation of Norton Anti-Virus in your computer. As to why this happened, could be a compatability issue with the use of Norton and some other program. Good luck.
Jun 07, 2007 | Sony VAIO Z1VAP1 (PCGZ1VAP1) PC Notebook
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
