Question about Cycling
Bicycles Brakes Tightening
I think my bicycle brakes need tightening, how do I tighten my bicycles brakes?
  • Anonymous May 01, 2009
    putting back front brakes,
  • 55 Answers
Are the brakes center pull or side pull?
Center pull would have a nut directly in the center of the brake. Now go to the brake lever on your handle bars and tighten the turn screw where the cable handle is. Keep turning the nut till your brakes grip.
If you have side pull brakes. Then where the cable meets the breaks. Their is a nut that the cable slides through. Loosen the nut and firmly pull the cable till its tight and retighten the nut.
Posted on Nov 08, 2008
How to tighten the brakes on a giant trance x3
Hi... You will have to on your question, is something loose that needs tightening, or is it a setup issue, or has the blocks or pads worn over time?
If your bike came with disk brakes, you might need to replace the disk pads, or bleed you hydraulics.
With more details, a better answer can be supplied.
Feb 16, 2014 | Giant Trance X3
Tightening problem?
Hi all you need to is tighten the Black bolt the one with the front brake cable going thought it make sure the bars are in line before you tighten it good luck
May 25, 2013 | Cycling
Tightening brakes
Most brake levers have an adjustment barrel. You loosen the lock nut, unscrew the cable adjusting barrel a few turns to take up cable slack & adjust the brake lever freeplay then tighten the lock nut.
Apr 03, 2013 | Ezip The E-450 Scooter
Brakes need to be tighten
The wound steel cable that connects your brake lever to the brake pads can be adjusted via a screw or nut at the top of the brake pad assembly. Simply loosen the assembly and gently tug the wire end toward the front of the bike tire to tighten brake grip; tug it backward to loosen. Tighten the screw partially to hold the cable in place, test the brakes with the brake lever, and adjust again if necessary before fully tightening. It may help to put the bike on a stand or hold it so that you can spin the wheel, check that the brakes are adjusted so that the pads do not rub the wheel. You can do the same thing with the rear brakes. You will need a small tool to loosen and tighten the brake pad assembly; your household toolbox should have something :)
While you are adjusting the brake tension you should also check the brake pads for signs of wear. If your bicycle brakes squeal, show uneven wear or are perfectly smooth, go to a shop and get a new set! Regular brake maintenance is very important for bike safety.
May 19, 2011 | Cycling
Brakes are noisy and rub, how do you adjust them? tektrodisc brakes I think..
this is simple, all you need to do is to tighten the adjustment barrel to give the brake cable core slack. or if that dont work than losen the anchor bolt and give the cable a little more slack and re tighten the anchor bolt.
Oct 17, 2010 | Diamondback Topanga 26 Men's...
Hand brakes are loose and need to be tightened so they will stop the bike. How do I tighten the hand brakes?
loosen the anchor bolt the hold both brake shoes against the wheel rim pull the cable tight and tighten the anchor bolt
Aug 07, 2010 | Huffy Disney Princess 16 in. Girls Bicycle
How do you tighten from and back wheels so that
if the wheel is centered the problem is the brake linkage not re centering,
Jan 26, 2010 | Cycling
The brakes will no tighten up on the wheel
You have to adjust the break cable..
Loosen the little nut that hols the cable at the break.. Pull the cable out a little bit with pliers.. Tighten the nut at the break..
Thus taking a little bit of slack out of the cable and now the break will work properly..
Have a great day !
Oct 26, 2009 | Mongoose Menace Street Dirt BMX Bicycle
Brake pads tightening up
use a flat screw driver and push the pads back in on the calliper. Be gentile though.
Jul 30, 2009 | Avid Code Hydraulic Disc Brake
Cycling Logo
1,009 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
