Question about Cameras
Have a canon e808e camcorder. Not been used for some time. Plugged it into the mains and used the mains connection. Power light comes on but only for a few seconds, then goes out again. Same if I press the eject button. Same happens if I try using the battery. Any advice would be appreciated
t00nz
  • 4738 Answers
SOURCE: Canon A540 flash charge not holding
Some of The Canon Powershot A530 and A540 cameras are subject to a advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Posted on Dec 16, 2007
t00nz
  • 4738 Answers
SOURCE: lens retract problem
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 31, 2007
SOURCE: When plugged in does not start up
Looks like the battery is screwed. This usually happens with laptop batteries when not recharged for a certain amount time(Usually around 2-3 months). Replace the battery and every thing will be back to normal.
Posted on May 23, 2008
SOURCE: Camera won't switch on
I thought the batteries had worn out because when I press the 'on' button the 'busy' light comes on for a few seconds and then goes out and nothing happens. Have changed batteries and checked installed correctly.
Any ideas please?
Posted on Jul 06, 2008
Lando93
  • 8 Answers
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Posted on Jun 10, 2009
I have an System ERROR E001 following Error E808 on my canon 2016j copier and waht shal i do me out guys
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the DC controller PCB.
E001 0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E808 0000 Fixing drive circuit failure
- The heater does not turn on.
- A fixing drive motor failure was
detected.
- Replace the fixing drive motor.
- Replace the power supply PCB.
Feb 19, 2011 | Canon iR 2016i Black and White Copier
I have Canon iR 2020 it show E808 code error
conon ir2020i can not innitiallise asking to switch off and on the main power switch
Jan 06, 2011 | Canon iR 2016i Black and White Copier
Model ir2016 e808
E808-0000 DRIVE CIRCUIT FAILURE
A zero crossing signal cannot be detected.
A fixing drive motor failure has been detected.
Main Cause/Symptom
- A fixing drive motor failure was detected.
Countermeasure
Oct 29, 2010 | Canon Office Equipment & Supplies
I have a Canon FS100 Digital Video Camcorder. I am attempting to download some video on to my iMac, but then I select "Connect To Camera" I get the message "No Camera Was Found". I have the camera plugged...
The computer is no longer detecting the camcorder for several reasons. It could be the ports on the computer, it could be the cable that you're using to connect the camcorder to the iMac, or it could be the camcorder itself.
Try connecting the camcorder into different USB or FireWire port of the iMac.
Try using different cable.
Try connecting the camcorder into different computer to test the device.
If all else fails, power cycle the camcorder by turning it off and remove the battery for about 10 minutes. Then turn it back on. Otherwise, contact the manufacturer for second opinion.
Hope these helps and have a great day!
Aug 12, 2009 | Canon FS100 Flash Media Camcorder
System error E808
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540 0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542 0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744 0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
Mar 22, 2009 | Canon CLC 1140 Copier
I am trying to load my video recording to my PC
I experienced the same thing. The compact power adapter is simply the power cord used also to recharge the camcorder. Plug it into the wall at the same time as you have the USB plugged into the computer and it should be able to download.
Jan 27, 2009 | Canon FS100 Flash Media Camcorder
When connecting the dvd burner and the camcorder to a cannon fs11
I'm not 100% sure of the question your asking here but I believe that the message you're getting is because you need to have...
(A.) Power cable plugged into the DW-100 (I assume you're OK there).
(B). USB Cable connecting the DW-100 and your camcorder (OK there too)
(C.)You must ALSO have your power cable plugged into your camcorder.
Many people forget about 'C' but Canon works on the premise that offloading data can take time and drain the whole battery so you must have everything running on A/C in order to do your work.
Hope this helps.
Jan 20, 2009 | Canon DW 100 DVD-RW Burner
Code E808
This problem was solved by turning off the unit and unplugging the power overnight. The next morning it worked fine.
Jan 15, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Canon mv800i fault
OK after searching the net to fix this problem and no one having the answer I decided to fix it my self.
My Canon MV 800i cam had the same fault to I took it to bits. Inside there’s the cams main board that has loads of ribbon cable connecting on to it from its bits like lens, power supply, viewfinder , cassette deek. I unplugged all of these and removed its main board and cleaned all the ribbon cables connecting end with isopropyl alcohol, you can use most electrical cleaners should do the some trick. Then just reassembled the cam and tested all fixed
Give that a go and see how you get on
Jul 31, 2008 | Computers & Internet
Cameras Logo
49 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
