Question about Cycling
Bicycle Flat Tire
I think my bicycle have a flat tire, how can I check this, and if it does what are the steps for changing a flat tire?
    Problem Solver:
  • 10 Answers
Push your bike into a lake, if it floats, tires are fine.
Posted on Nov 05, 2008
How to Replace a Blown Bike Tire Inner Tube?
unbolt wheel and using tire spoons or the handle of flat ware [as long as its strong enough to not bend ]place inbetween the tire bead and rim and pry up and over rim now either use another to pry again next to spoon or slide spoon under and slide around rim removing tire reach in and remove tube check inner tire for debris fix or replace tube install
How to change and fix flat bike tire Trek Bicycle How to Fix Flat Bike Tire
Oct 20, 2016 | Cycling
Tip
How to Change a Flat Bicycle Tire
1) Begin by looking at your old bicycle tire, and find the dimesions of the tire on its side. Write down these dimesions, becuase you must then go buy a new innertube for the tire that is the same (or about the same) size. I suggest going to a bicycle store; at the one near me tires run about 5-10 dollars.
2) With this new innertube in hand, you can begin changing your bike tire. You must start by taking off the entire bike wheel. To do this you need a hexagonal-shaped wrench thingy that looks like this:
See the hexagonal wrenches on the left side? You're ging to need something like that to remove the wheel. If you don't already have one, you can get this one from here (Walmart.com), or you can look up 'bike tool' on Amazon or Ebay.
3) You then use this tool to remove two hexagonal bolts, one on either side of the wheel; shown here:
Then use a flathead screwdriver or another falt object/tool to pop the outer tire off to expose the old innertube inside, like this:
4) Remove this old innertub, and put the new one around the wheel. It might seem a little big, but that's okay. Proceed by slipping the outer tire back on over the new innertube, using the same tool you got it off with.
5) Put the wheel back on the bike, screw the bolts back in, and inflate the tire to whatever PSI (Pounds per Square Inch) it says on the side of the tire.
6) You're bike is ready to ride again!
on Feb 16, 2010 | Cycling
How to change rear tire ?
Remove rear wheel with either a 15 mm or a 17 mm wrench. Take the tire off the wheel. If you are replacing a tire, reverse procedure. If you have a flat, replace inner tube, then reverse procedure
Aug 14, 2014 | Huffy Cranbrook 26" Mens Cruiser Bike
Flat tire
A bicycle repair shop should be able to tell you the tube size if you provide the tire size markings on the sidewall of the tire.
Apr 07, 2014 | Bianchi Milano
I puumped up my tire but as soon i pump it it goes flat
You have whats called a flat. TAKE THE TIRE OFF AND REPLACE THE TUBE INSIDE WITH NEW ONE. If this is a daunting task, take tire and rim to local bike shop and they will be happy to fix for you. Good Luck....
Apr 21, 2011 | Cycling
Repeated flat tires even after changing to a new tube
Find the cause and eliminate it before feeding a new tube to that thorn or sliver of glass. Sometimes we pinch the new tube while installing it, too.
Lots of videos on Google: search "fixing a bicycle flat tire"
Mar 05, 2011 | Cycling
How to change the flat tire? Can not remove tire off the rim. How i get the nuts off?
You're not supposed to remove the tire from the rim like with the bicycle. You take the tire nut wrench, jack and the spare tire from the trunk, loosen the nuts, lift the car up with the jack, take off the nuts and the tire, replace the tire with the spare, skrew back the nuts, lower the car down, tighten the nuts, pack everything back in the trunk, drive to the tire fix shop, get the tire fixed, change it back, keep the spare ready for another punkture.
Dec 16, 2009 | 1998 Volvo S70
The back rear tires will not keep air in them. How do I fix them or do I need to replace them? (Baby Trend Jogging Stroller)
More than likely there's a leak, maybe small but enough to cause a flat.
As for tubes your local bike shop may carry the 12" or the 16" depending on the stroller make and model. Check the side of the tire to see if you can identify the size, if not the stroller manufacturer or the site should give you more information.
The tires with these jogging strollers come off fairly easily with any regular bicycle tire levers. Although it's possible to take them off by hand, if it's difficult any bicycle shop would carry standard bicycle tire levers. I personally recommend the life time warranty tire levers by Pedro. They are very strong and designed to take off some of the beefiest mountain bike tires.
It would also be good to have spare tubes. You can find bulk tire tubes on eBay for cheap!
Nov 04, 2009 | Baby Trend Expedition Double Jogger
Cycling Logo
344 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
