Question about Cameras
Nikon Coolpix 4300 lens stuck in out position. system error message on monitor. No mishandling. Has been great for several years.
I found a really tiny Philips screw driver - unscrewed the case, removed the long plastic label from top and undid clips underneath the label. Took it apart - looked at it in depair and put it all back together again - and the lens slid back in . It is now working perfectly!! You only risk this sort of action as a last resort.
Posted on Nov 04, 2008
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
System error
This error usually comes due to faulty sliding mechanism.Put a bit of force on the focusing lens to push it back into camera casing. That's the reason the sliding mechanism won't work. The lens is stuck and if you force it back in, the sliding mechanism will work again. Not responsible if your camera screws up, so try at your own risk.
Or else try out this method
Pull the lens fully out and then it will work.It will be bit tricky to get the lens out. Use your nail to "grab" between the outer glass and the little plastic cover.
Thank you !!
Jun 19, 2010 | Nikon Coolpix 4300 Digital Camera
Lens error nikon coolpix 4300
This error occurs if camera is turned on before lens cap is removed. If you are removing the lens cap before turning the camera on and still getting this message, camera should be serviced by a qualified technician.
May 17, 2008 | Nikon Coolpix 4300 Digital Camera
Sytem error 10
Hi - I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Sort of like a Windows Restart to reset the memory.
Hope this helps.
May 09, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon coolpix 4600.
Hi I found this info on the Nikon Australia website:
Seems you may just have to remove and replace the battery - sort of like a Windows Restart to fix a computer problem! - this would reset your camera's memory.
Hope this helps.
Apr 29, 2008 | Nikon Coolpix 4600 Digital Camera
Lcd reads system error
Apparently often related to a lens motor malfunction. My old 4300 just gave this error for the first time today. The lens extended but made a whirring noise before the message popped up. Nothing I tried would fix it - but after I drove home it worked fine again.
I had a similar problem over a year ago after the camera fell out of my backpack (it was in its own bag but not well padded). When I used it the lens stuck and refused to retract, but I don't recall a "System Error" message. After a few tries, the lens went in and it's been fine since, until today.
Make sure there's nothing (dust, dirt) stuck in the lens barrels. Otherwise, just keep turning it on and off and hope it works.
Dec 31, 2007 | Nikon Coolpix 4300 Digital Camera
Lens stuck in the out position
Please reload the Firmware and your problem will be solved.
Nov 23, 2007 | Nikon COOLPIX L3 Digital Camera
System error
This is fundamental break down and may not be repairable. Check out th Nikon Web site technical support
Jun 17, 2007 | Nikon Coolpix 4300 Digital Camera
Lens stuck
the temptarture has probaly mellted or damaged the insides did you leave it in a car in the summer
Dec 26, 2006 | Nikon Coolpix 4300 Digital Camera
System error
turn it on and off 6 or 7 times while banging on the body beside the lens. worked for me, cameras been out of commission for 3 years ,apparently lenses tend to stick on coolpix cameras
Dec 17, 2006 | Nikon Coolpix SQ Digital Camera
Cameras Logo
213 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
