Question about Cycling
Bicycle Disk Brake Problem
My bicycle have a disk brake problem, I removed the front wheel, and when I tried to attach it back I doesn't fit in, the gap is to narrow.
This is really frustrating!
I won't to ride my bike, but can't fir the wheel back on it, please help me.
Thank you.
  • 2 more comments
  • Anonymous Dec 22, 2008
    yes bikes do have disc brakes - I've the same problem :(
  • eitan ger
    eitan ger Dec 22, 2008
    Pluk- I think that your solution did not work
  • Anonymous Jan 03, 2009
    when do i change the gears
  • Anonymous Jan 07, 2009
    had a punkture so i took the wheel off then when i tryed to put it back on the disk brake pads got closer together and i couldnt fit the wheel back on
Lol some do
Posted on Apr 01, 2009
  • 4 Answers
I assume the rotor from the brake is not fitting back in the caliper.
Do you have mechanical or hydraulic disc brakes?
Posted on Nov 05, 2008
    Problem Solver:
  • 10 Answers
Bicycles don't have disc brakes
Installation of disc brakes on a gas bike
Motorized Rear Wheel Disc Brake Kit - YouTube
? 4:18
https://www.youtube.com/watch?v=ZFl5o6OyUTw
Aug 11, 2013 - Uploaded by bicycledesigner
Convert your mountain bike rear disc brake wheel into a motorzied disc brake ... How To Install a 48cc 4 ...
Custom Motored Bicycles - DISC BRAKES, ROTORS, 26 ...custommotoredbicycles.com/disc_brakes_rotors_26_inch_wheels_conve...More Disc Brake Parts for Motorized Bicycles coming soon! ... This lazer cut, offset bracket fitting allows you to install disc brakes on virtually any Bicycle [without ...[Brakes] - engine kit on a bike with disk brakes ' Motored Bikesmotoredbikes.com > ... > General Bicycle QuestionsJan 30, 2013 - Hello, I'm not sure if there is a post about this or if I'm posting in the right section, but I am wondering if it is possable to mount an engine kit on a ...Install engine on a bicycle with rear disc brake. - M
Dec 25, 2015 | GAS Motorcycles
Having trouble attaching front wheel. Owners manual or instruction sheet misplaced
How to install quick release front wheel on bicycle - YouTube
? 0:58
https://www.youtube.com/watch?v=xFx7UXyjW4Y
Dec 11, 2011 - Uploaded by Bicycles Online
When I went to reinstall my wheel my brake pads were stuck together and I don't know how to get them apart ...
How To Remove The Front Wheel of a Bicycle - YouTube
? 7:31
https://www.youtube.com/watch?v=BNwa0lONtbc
Jun 30, 2012 - Uploaded by cjhoyle
This is a quick tutorial showing how to remove the front wheel of a bike. ... Getting the lightly tightened other nut off shouldn't be aproblem.
Removing and installing your bicycle wheels - YouTube
? 4:06
https://www.youtube.com/watch?v=QslgCn9QX5I
Dec 25, 2015 | Cycling
The wheelchair brake is not touching the wheel on my runabout quint stroller. Can this be adjusted? How?
Not familiar with that brand but looking at the stroller it looks like it uses bicycle brakes. Anyone that is familiar with adjusting bicycle brakes should be able to adjust that for you.
Where the cable attaches to the brake caliper at the front wheel there should be a nut that needs to be loosened, the cable pulled further through the bolt and the nut re-tightened.
Nov 05, 2014 | Baby Gear
Aseemble a coaster brake on a bicycle
Ken, Check the attached links,instruction and guides on removal and install coaster brake. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Coaster Hub Overhaul Pedal Brake Hub
How To Install Cog On Coaster Brake Hub
Bicycle Coaster Brake Repair and Service
Oct 01, 2014 | Husky 26"" x 2.125 Industrial Chrome...
I have rockhopper sl, just taken the front wheel off for the first time, and accidently pressed the brake lever now the pads have locked and i cant get the wheel back in, please help, is it safe to use a...
Don't use a screw driver. That means you have hydrolic brakes. Take it to a bike shop. It is relatively difficult to open w/o damage it is easy to damage. Also, pick up some disk brake spacers that you put in when you remove the wheel to prevent just this problem.
Jul 14, 2011 | Specialized Bicycle Components Specialized...
How do I remove the Front Wheel on a Mongoose Bravo bicycle with a slotted disc brake. The disk brake hangs-up when attemping to remove the front wheel.
These types of questions are best served by search engines and yield immediate answers with video.
Google "how to remove a disc wheel"
May 29, 2011 | Cycling
Back hand brake rubs on pads cannot adjust basic hand brakes
If you can't adjust your brake position by using the adjustment screws you can loosen the wheel bolts and physically change the tires position to make it fit within the brakes. If that doesn't work take you bicycle into your local bike shop and have them check your rim alignment.
May 06, 2011 | Cycling
How do you remove the reae wheel from a five speed schwinn suburban bicycle
Should just loosen the nuts on each side of the axle. Assuming bicycle is upside down, you then have to lift the chain away from the sprocket as you slide it out of the slots of the frame that the axle fits in.
May have to loosen, adjust or remove the brake pads in order to slide the outer rim/tire through the brake caliper.
Take a picture first, so you can see how to deal with the rear derailer (sp?) when putting the wheel back on.
Sep 25, 2009 | Cycling
ReAssemble front wheel . Can't get front wheel over the brake pads of the bicycle
need to loosen the cable so the brake will spread apart
Jul 31, 2009 | Cycling
Cycling Logo
810 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
