Question about DeLonghi Kitchen Ranges
Delonghi Hinge-Oven Door fit - DeLonghi Kitchen Ranges
Hi, I have a DeLonghi oven and grill, not sure of the model number I am afraid. It has a single pull down mirror looking door. In between the glass is stained and looks awful when you look at it from the kitchen. I have looked to see if the door can be removed and the inside unscrewed from the glass area and cleaned.
It appears that the metal rim wraps all around the frame and does not look like it can be removed.
Can you advise me please.
Regards
Steve Purssey
Posted on Nov 11, 2008
4 Suggested Answers
  • 4102 Answers
SOURCE: Is there a technique for
what is the make and model then i can give you the instructions you need and talk you through the process
Posted on Feb 29, 2008
vitg55
  • 78 Answers
SOURCE: adjustment to door hinge, as door does not close completely
In most cases door hinges needs to be replace but some time with old stile ovens and ranges help this trik:
1. Put small towels on right and left hinge between the door and range/oven body
2. Close door and gently push like you try to close completely.
3. Try several times.
4. Open door, remove towels and see if it helps
5. If not replace hinges
Posted on Nov 30, 2008
woodchuck789
  • 4070 Answers
SOURCE: DIGRAM OF HOW THE DOOR HINGE FITS IN OVEN.
Post your model number and search for the diagram- here-http://www.appliancepartspros.com/modelnumber_locator.aspx
Or post back here and i'll look it up.
Posted on Jul 12, 2009
I have a Delonghi defsgg 36 d ss pro style oven, and need a main oven door hinge.
Find part # for part you need and do a search on amazon or eBay
Sep 09, 2017 | DeLonghi Ovens
Oven door not sealing correctly on our A106G Delonghi oven. It is sitting out slightly at the top
One of the door hinges may have come off track at the base of the door. Need to release the clamp on both hinges and get the door out for inspection.
New hinge can be got from
Delonghi Male Oven Door Hinge
Sep 03, 2014 | Ovens
How to unlock the hinge on an Ariston Oven Door with door off
To Unlock the hinge on an Ariston Oven Door
Lay the oven door flat on the worktop with the inner door upwards and the locked hinge facing you.
With a pair of pliers and a good grip on the hinge, force the locked hinge towards you (by pulling it open towards you) and keep it in position by flipping the U piece over.
Fitting the Oven Door
Fit the door to the oven with the metal receivers in the slots on the oven.
Once the receivers are in the slot, fully open the door (in a downward position).
Flip the U shaped pieces over to lock the hinges.
May 17, 2010 | Ovens
Need to get the door off - model number B7425b1600E
To remove door: Open oven door fully open. On the hinge there is a small metal tag that swivels up and fits over a small hook on the hinge. Do this on both sides of hinge, then gently close oven door whilst lifting upwards- door will lift off. Reverse procedure to refit.
Mar 10, 2010 | Fisher and Paykel Ovens
I removed the oven door and took out the hinge to clean. When I tried to put the hinge and oven door back the hinge will not close it is stuck. How do I unlock or hook the hinge so my oven door closesI
You will have to pull the oven dorr up and out again, it might be a little hard to pull but the door didn't went in straight and it's preventing the hinge from closing. go to repairclinic.com for an ilustration on how the door and hinges fit in place.
Jan 14, 2010 | Ovens
Replaced hinge on smeg double oven but now oven doesn't heat
I have the SMEG F170-5 and had this problem after cleaning and replacing the door. It wouldn't heat unless I banged it shut. This action made the internal switch trigger, so I had to remove the oven (4 screws, slide out) and remove the right side panel (4 screws). The switch is actuated by the right hinge strut and it must have become bent slightly. I bent it a bit towards the door so that it would just a little bit more likely to make the switch trigger with the door closed and it now works fine.
Jun 12, 2009 | Smeg S351X/5 Electric Single Oven
Oven door hinge failure
U need to replace both door hinges together.
In your browser bar , type in youtube.com
Then in then search box type in fitting oven door hinge
Click on appropiate video and follow instructions.
This should be a big help to you.
Plz rate my solution.
thanks.
Dec 22, 2008 | Ovens
Adjustment to door hinge, as door does not close completely
Nov 29, 2008 | DeLonghi Kitchen Ranges
Door gapes open
My door is the same you can get a hinge for it 17.99 online at Currys I believe. Google the oven make and then parts.
Sep 27, 2007 | DeLonghi DEFSGG36-SS Gas Kitchen Range
Oven door
open door fully. there is a hinge lock - usually a little arm on the hinge which comes up. engage hinge lock, partially close door and lift off
Jul 01, 2007 | Zanussi ZBQ365 Electric Single Oven
Kitchen Ranges Logo
569 people viewed this question
Top DeLonghi Kitchen Ranges Experts
JP Services
JP Services
Vitaliy Gins
Vitaliy Gins
Paul Bade
Are you a DeLonghi Kitchen Range Expert? Answer questions, earn points and help others
