SOURCE: I used tranfer paper on the Xerox Workcentre 7345,
It's possible, transfer paper can melt to the fuser roller, the drum, and other rollers in the printer and leave them sticky and unusable. Problems can manifest right away, if the plastic crud left behind is think. Or they can manifest several days later as toner turns the clear melted plastic black.
If several days later your still running, you're probably safe.
SOURCE: how to change ibt belt
The error code 004-346 is an IBT home position sensor. The belt may be damaged or didn't move.
The sensor which is mounted on the frame looks at the belt to see if it made a full rotation. Perhaps the sensor is dirty or damaged. Maybe the home reflective mark is damaged.
The belt may be damaged or shredded. Find out why the old belt was damaged before you install another part!
You probably need to purchase a new IBT belt PN 802K208991. The Xerox technician has a proprietary laptop to clear the codes and calibrate the "Belt Edge." The belt is very fragile, so whoever installs it needs to be very mehtodical and careful.
These may preclude you from repairing that yourself.
Whit
Item, Inc.
SOURCE: I have a Xerox workcentre
you have to reset the hfsi counters for the cleaner. in diagnostics go to hfsi and there are 3 numbers you have to reset. 954-802 954-803 954-804 then exit diagnostics.
Sepacal Boot setup option use machine will be ok
016-311 code is comming
sir 016-311 cod is comming
