Question about Sager NP-5650-S PC Notebook
Sony Vaio PCG-K415S Display Problem
I have a PCG-K415S laptop with a siplay problem. The display is extremely dim and unreadable although if you tilt it in the light you can see that what should be on the screen is actually there and of good quality its just to dark to actually read. I think it is just a backlight issue although a friend said it could also be the inverter.
I thought if the inverter was gone then nothing would appear whatsoever on the screen. Am I right in assuming that it is just a backlight problem or could it also be the inverter ??
  • willyherm Dec 11, 2008
    I have the same problem with a PCT-GRT170. I ordered and replaced the inverter board. That didn't change the problem at all. I know the inverter board is getting voltage and the screen tries to light up right at start up and if I push the lid closed switch but only momentarily in each case. Any more suggestions other than the recycling bin? BTW - even the monitor output which works at start up shuts off during boot up.
SONY VAIO PCG-61813M
I have the same problem, It works at an external display and the lcd and lcd cable work on another laptop.
The problem is that i have a sony vaio and it has no inverter, or at least i dont see one like an hp laptop for example. i tried to switch image from external monitor to lcd and it doesnt work. i tried everything. dont know what to do more, Hope you can help.
I have a Sony Vaio pcg-61813M.
Thanks.
Aug 29, 2012 | Sony VAIO Laptop Intel Core i3 Processor...
Sony vaio pcg 7173L wont turn on
my laptop is sony PCG-7173L. No thing display on screen and i even cant shutdown and there is no power led on power button and no sound of fan too....i cant go to advance boot option also..Please can any body help me...
Jun 16, 2012 | Sony Vaio Pcg-7173l Complete - Core 2 4gig...
Vaio k23 screen wont turn on when power on
Hello
OK, this problem can be a result of a couple of errors.
SO, let me start by asking you a couple of questions.
Do you hear a abnormal beep code at start up?
Does the display come on if you tilt the screen?
Let me know, i will gladly assist.
Kind regards
Andrea
Sep 27, 2010 | Sony VAIO PCG-K23 Notebook
Vaio PCG-9S1L Screen is very dark, extremely hard , LAPTOP SONY
As stated in your post "two year old may have dropped it"
If this is true than the backlight has probably been damaged. The small flourescent tubes that generate light through the LCD display.
Email service@lanprotec.com for service options
Mar 01, 2010 | Sony Computers & Internet
I have a Sony Vaio PCG-8A8M with display problems.
sounds like the display/monitor is about to go... backup your files...externally
Sep 13, 2009 | Computers & Internet
Sony Vaio Laptop PCG 9U1M
PCG-K415B is the correct model number the label is possibly the service tage or something.
Here are the specifications of your laptop
  • Intel Celeron D Processor 345 3.06GHz / 533MHz FSB
  • 512MB DDR SDRAM - Low cost double memory Offer - call for details
  • 40GB Hard Drive
  • DVD Dual Layer Drive - To read DVDs and CDs and write CDs, DVD+, DVD- and large Dual Layer DVD
  • 15.4" XGA xblacklogo.jpg Widescreen TFT Screen
  • ATI Mobility Radeon 345M 64MB shared graphics
  • Integrated wireless 802.11b/g LAN - Call for advice on Wireless networking
  • Integrated 3-in-1 card reader –Memory Stick, Memory Stick Pro, Memory Stick Duo
  • Operating System: Windows XP Home Edition
  • Includes Sony Software Bundle
My guess is that the laptop is around 1 or 1and half year old as the celeron 3.06GHz is a relatively new processor.
May 26, 2009 | Sony VAIO VGN-AR230G Notebook
Dim LCD display
ccfl tube goes down or inverter cirucuit is fail
need to replace it
Feb 02, 2009 | Sony VAIO PCG-K23 Notebook
Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Dec 20, 2007 | Sony VAIO PCG-K25 Notebook
Sony Vaio not Booting
Have you tried booting with a windows cd, and then running a disk check?
Dec 18, 2007 | Sony VAIO PCG-K25 Notebook
Malfunctioning keyboard Sony Vaio PCG K415S
Ebay or somewhere similar is your best bet for getting a 'used' and therefore much cheaper replacement. Just type in the make/model of your machine..
Most Keyboards are pretty easy to replace and if your not sure how to do it, run a search on the web or post on here with your specific model etc. If its put together anything like my Sony all you have to do is remove a bit of trim above the keyboard (carefully) and there are 4/6 screws holding the keyboard in place. Remove these and the keyboard just slides out. Then it's just a matter of disconnecting the ribbon and reversing the order to put it all back together.
Good luck, J
Nov 30, 2007 | Computers & Internet
Sager NP-5650-S PC Notebook Logo
500 people viewed this question
Top Sager Computers & Internet Experts
David Payne
David Payne
Are you a Sager Computer and Internet Expert? Answer questions, earn points and help others
