Question about Stoves 1000DFDL Dual Fuel (Electric and Gas) Kitchen Range
Replacing/refixing roller mechanism to door catch of fan oven
The top screw holding the door catch roller mechanism to the fan oven on my Stoves 1000DFDL has come loose and no longer holds the top of the roller mechanism in place, making the door difficult/impossible to close. the roller catch mechanism moves back slightly when you try to close the door which means that the catch on the door itself does not get caught by the rollers.
The first question is, is the roller mechanism held in place with a nut on the end of the screw or is there a thread in the body of the mechanism which may have stripped causing the screw not to be able to hold it in place?
If it is a nut how do you access the mechanism to replace it?
If there is a thread in the mechanism, is it an option to tap a slightly oversize thread and to fix a slightly oversize screw in it?
If the only solution is to replace the roller mechnism completely, can you give details how to do this and how to access the mechanism?
5 Suggested Answers
  • 1462 Answers
SOURCE: Fan oven stays warm
is the fan working when oven is staying warm? possible fault if you don't have an earth trip is a short to earth on the neutral side of the element
Posted on Mar 26, 2007
  • 139 Answers
SOURCE: Removing door on top oven
Pus the top part of the hinge down as it is on springs and try and pull is out.
Its hard to explain this.
or you can try to squeeze the two parts of the hinge to force the top part down, and basically yank it out.
I have to say again it hard to explain but thats the basic procdure..
Dont give me a bad rating please im trying to help ya
washdoctor
Posted on Aug 25, 2008
SOURCE: Seized screws in Stoves 'Range 1000G Gas Range Cooker (LPG)
I let the screws soak for a few days in release oil but with no success. I decided the only way to get the seized screws out was to drill and tap new holes through the hob and into the hob burner mixing tube support flanges. This allowed new screws (stainless as opposed to the standard, chrome plated steel screws) to be screwed into place. Once this was done I then drilled out the heads of the remaining seized screws. This allowed the hob tops to be removed so that the oven thermostats could be changed. The hob screws were then screwed back into place and lubricated with loads of high temp. copper grease to prevent corrosion. I will also remove and re-grease these screws every six months or so to prevent any chance of seizure in future!
A few points to remember: (a) make sure that any holes in the hob top are sealed with something such as a screw coated with high temp fire cement etc. to prevent any possibility of unburnt LPG getting into the space below the hob top. (b) make SURE that you do not drill or tap into anything that could damage the cooker and cause a gas leak or damage any of the gas ignition leads etc. (c) Make sure that the appliance is totally 'gas tight' after doing any work which will disturb the gas connections, and (d) If you don't have gas qualifications and are not sure of what you are doing then get an expert, registered gas engineer to do the work for you. Don't take a chance with gas!!
Posted on Oct 08, 2009
  • 160 Answers
SOURCE: Newhome 1000dfdl main fan oven appears to stay at
whilst the fan is running the heating element which is usually in parallel with it should heat.. This usually means a faulty element whilst the temperature light remains on.
but if the temperture light is off then its likely to be a faulty thermostat
Posted on Dec 18, 2009
  • 3 Answers
SOURCE: Top oven thermostat Stoves 800DF - fitting?
you dont need to remove the front panel, you need to undo the two black screws on the side of the hob unit, remove the two plastic plugs they went through allowing you to raise the hob, and remove just the back off the cooker this provides you access to all the areas you need you can then follow where all the cables go oh yes nearly forgot the thermostat is held in place by two screws you simply pull the knob off and there they are. ive just done the fan oven one and it seemed fairly straight forward, but please do remember to turn off the power to the cooker first all the connections push on using spade connectors, oh yes for legal reasons this is for information only and i wont be held liable for injury or damage caused by unqualified people following this information to fix it themselves as i would always have to recommend that you use a competant person ie a person who is trained, experienced and has sufficient knowledge to do the job, but those that do want to fix it do so at their own risk and i hope all goes well with getting the problem fixed
Posted on Mar 27, 2010
Model 720EF. Model No 059040415. The grill will not work. The top oven is still working but the grill light or fan will not come on at all. Stoves have told me over the phone that it could be the...
First things first. The top oven lights ONLY come on when the top oven is switched on. Operating the grill DOES NOT turn the lights on. If you wish to see what you are grilling, you have to turn the top oven control knob on to its first position as well as turning the grill on.
Secondly, the grill only works when the door is open. The grill does not work when you shut the door. When you open and shut the door, you should be able to hear the microswitch operating. It is located in the right hand side of the cooker, between the inner and outer panels - you cannot see it. I haven't seen the switch first hand but they normally come with an arm that contacts the door mechanism and the door mechanism operating, causes the arm to move, which causes a button on the switch to move and make the circuit. It has been known for the arm on the microswitch to bend with use so it no longer works correctly.
If you have checked all above and you hear the switch operating, then it could have failed. They are quite common, so if you can't get one from STOVES, try espares or someone like Maplin or RadioSpares.
The get to the microswitch you have to take the oven out of the housing and then take the right hand panel off. You should then be able to see it and check its operation.
All the best
Jul 26, 2011 | Stoves 720EF Electric Double Oven
Have to slam door to get oven to operate
Try a) Lubricate the latches. I sprayed wd-40, you probably can use vegetable oil. Both sides, latch and receptor. Just doing this may fix your problem. (I have to admit I did part b first before trying this so I am not sure, but after doing this, it made my part b fix work even better)
b) Failing this, I found opening it up (t-20 torx screw driver) and tying a wire in the top hole, through the bottom latch body and fastening to a bottom hole of the microwave frame to force the mechanism to stay in place. You want to pull it towards the oven cavity. This will keep it from bending out of alignment. I found that it is only the bottom latch that has to catch for the microwave to sense the door is closed.
Mar 30, 2011 | Panasonic NNSN797S Microwave Oven
Door will not latch
Door catches.
One of the latches may have broken off and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Feb 12, 2011 | Sharp R-55TS Microwave Oven
Door has been an issue when closing light stays on and you really have to slam the door for the light to go off
Door catches.
Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. The door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Jan 24, 2011 | Whirlpool GH4155XPS Microwave Oven
Door catch broken - door will not close. no sign of a broken piece. There was a bang and the catch just doesn't hold at all. door swings open
Door catches.
One of the latches has broken off and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Door switches
If one of the door interlock switches is not switching properly, that can cause the turntable/light to come on even though the "Starts" button has not been depressed due to the wiring of the switches.
Check for faulty door switches and/or contaminated actuators.
I hope that helps.
Jan 12, 2011 | Panasonic NNA554 Convection/Microwave Oven
The door latches wont latch
Door catches.
One of the latches has broken off and is not lifting the dother latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Jan 03, 2011 | Sharp R-1480 Microwave Oven
I want to remove my fan unit from a stoves 720ef 1999 model
You have to remove the entire oven unit from the kitchen carcass. Once you have done this, you will need to take off the top and rear panels to gain access to the items you want.
There are normally screws holding the oven in place and a pair of these may be seen once the top oven door is down. They are located near the top of the opening on either side.
Dec 28, 2010 | Stoves 720EF Electric Double Oven
Hotpoint ultima sdw80 45cm door will not keep closed when in use still doing the wash cycle
Door catch needs replacing. Can be done yourself. Top 6 or so screws removes the top section of the door and the catch is held in by 2 screws and has two easy to remove / replace.
Oct 31, 2010 | Microwave Ovens
Stoves 900GDO Bottom oven door seal
You will probably have to replace the oven door hinges.
This should solve the problem
Dec 02, 2008 | Stoves 720EF Electric Double Oven
Stoves 1000DFDL Dual Fuel (Electric and Gas) Kitchen Range Logo
56 people viewed this question
Top Stoves Kitchen Ranges Experts
paulcarew
Ismael Rodriguez...
Bargain Box
Bargain Box
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
