Hotpoint ultima wt746 error f-12 - Washing Machines
Just had F-12 on my Hotpoint Aquarius washing machine. Problem was due to water not draining. Power off. My machine has access plate at bottom on the back. The water drain is held onto the drum via a jubilee clip and when i took it off the drain was clogged with hair, sweet wrappers, money, hair bobbles Once cleared, put back as was - machine now running ok..
Posted on Dec 02, 2008
Getting F-02 error code
wt-960 1600spin washing machine show error code f-12 each time
you switch on
Jul 21, 2014 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint ultima wt746, every time it spins its really loud and it walks across the floor, i have had hotpoint out to it to many times to remember, they always change the shocks and it never solves...
Hello there and thank you for choosing fixya:
Thjese machines have a device on them called a out of balance switch on them that senses the movement of the tub and when it is out of balance it is supposed to do 1 of 2 things
either shut the machine down or let it run in a lower speed
So what you can do is first slide the machine out away from the wall about 3 feet then tilt the machine back so that the front of it comes off the ground at least 12 inches then set it back down
This will reset the switch if it is still working then make sure that the unit is 100% level in the front and back and both sides then try it again and if it does it again then i would be calling the manufacture and telling them the problem with the make and model number of this unit
Some of these units are under recall for this very problem ok? and see about the warranty
Hope this helps
Best regards Mike
May 09, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima washing machine has error code f-12
The code F12 means the following:
F12 - No mixed fill. It is likely that the water is not turned on at the taps.
here is a link to all hotpoint error codes:
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
If this helps please rate me
Sep 10, 2010 | Hotpoint Washing Machines
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Ultima wt746 lights on wont start
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 10, 2009 | Washing Machines
Machine wont work and flashes f12 on function display
F12 is classed as a communiction error.
Either faulty connections or electronic panel
May 27, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpopint Washing Machine WT741 flashing F-12
Resolved the problem.
Switched off the power to the machine. hit the on /off button and the f-12 error code disappeared .
On reappling the power to the machine the orignial programme continued to completionj
Jan 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Error code on display panel
F-12 is a drain problem.
Check if the drain hose is free, if cycle stops and gives you f12 without draining the water, there is a problem with the drain system.
The Hotpoint should have a removable paner at the back on the lower side. The panel gives access to the pump. If cleaning the drain hose does not solve the problem, the pump must be removed and cleaned or replaced.The repair should be done by a technician.
Dec 14, 2008 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint washing machine wt746
hi, hotpoint wt746 trips electric a few seconds after closing the door
Oct 16, 2008 | Washing Machines
Washing Machines Logo
762 people viewed this question
Top Washing Machines Experts
