Question about ITT -2500-V Corded Phone (itt2500vas)
No dial tone
My phone does not have a dial tone.The problem has arrived other times ,but I do not remember which button I used to repair it. Thank you
0 characters
1 Points
M7310 Non-Stop Dial Tone
Intercom button/s provide dial tone when they are pressed. They are required to call other phones on your system.
Sounds like your button is stuck or issue with the motherboard.
Dec 17, 2012 | NorStar Meridian M7310 Phone
Phone is not getting a dial tone and will not dial out
Replace with a known good corded phone on this same wire to rule out wire problem. If the known good phone works, more than likely you cannot make the requied internal repair. Seek help through the "local repair" tab at
Thanks for your interest in ... please remember to evaluate this response.
Jul 04, 2010 | NexxTech 4318570 Corded Phone
Comdial Executech 6714x-PG We have nearly 20 phones. All of them get a dial tone but nothing happens when you press 9 to dial out, none of the phones will dial out. Calls can come in only. Thank you
they are either restricted or what you are hearing is intercom tone and not dial tone. the phones may be set to dial out from a diffrent line grop as well have you tried dialing 81 82 instead of 9 and see what happens
Jan 05, 2010 | Comdial 6714 14 Button Executech Phone
DECT phone has no dial tone
this is small problem........ dont worry...... dial tone wire disconnected...u can consult repair shop.......
thank u
May 12, 2009 | Phones
It sounds like rotary dialing
I have a similar Panasonic phone (KX_TGA101S).  Someone must have inadvertently changed the dial mode on you.  Here is how you change it on mine, which should be similar to yours.  Hit the Menu button.  Scroll down to "Set tel line" and hit the Menu Button (OK). If it isn't displayed, scroll to "Set Dial Mode" and hit the Menu Button. Select Tone instead of Pulse and hit the Menu Button.  That should do it.
Jan 25, 2009 | Panasonic KX-TG1033S Cordless Phone
Phone button tone replaces dial tone
You first need to determine if it is THAT phone or the jack it is plugged into. I would swap the phone with another in th ehouse and see if the problem stays with the phone or stays with the jack. If its the phone take it back or trash it. If the problem is the jack and if you have "lines keeper service" the phone company will repair the jack for you. If you do not have the inside wire insurance, ask the phone company how much it will cost to repair. You may want to get a private technician that will fix it for you for much less. Good Luck
Dec 23, 2008 | Phones
My VTech 2461 cordless phone is stuck on Pulse
To switch back to tone dialing, hold down the SELECT button for couple of seconds. The display on the base unit will read PU indicating pulse dialing. Now press and hold SELECT to change it to TN (Tone dialing).
Dec 17, 2008 | Vtech VT 2461 Cordless Phone
Changing from pulse to tone dial
For the GE electric 2.4 GHZ phone where there is no switch, you have to press the program button and hold until it beeps (talk button will start flashing), then press the tone (star) button and program again. It will beep for confirmation
Dec 12, 2008 | Phones
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
ITT -2500-V Corded Phone (itt2500vas) Logo
15 people viewed this question
Top ITT Phones Experts
Are you an ITT Phone Expert? Answer questions, earn points and help others
