Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
ERROR CODE 3802
I just changed my colour cartridge and now it shows error code 3802
This is how I fixed this problem may or may not work for you. I removed the ink!!! Then I removed the ink tray. This is fairly easy if you fell the top of the ink tray you will find a small square that is slightly raised push in on the square while pushing down on the tray this will release the print head. Very carefully clean with 92% alcohol and a q-tip! Don't apply pressure to the print head it will ruin it!!!!!!!
This allow to air dry for at least a 5min. Reinsert then recalibrate the printer! go to printer status and at the very top you will see a rench and hammer icon press it then follow directions!!!!!!
Good luck and god bless
Posted on Dec 25, 2008
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
Error code 3802
  1. Upgrade your printer firmware to the latest version
  2. If your printer firmware is already up-to-date:
  3. If the error continues:
  4. If the error continues,
for more help visit https://cbrtechsolutions.net or
CBR Tech Solutions
Jan 19, 2014 | Kodak Office Equipment & Supplies
Printer will not clear the Error 3802 , what do I do?
Hello and Welcome to FixYa!
Error 3802 generally occurs in the Kodak Inkjet Printers.
To solve this error Turn the printer off and then turn on, this problem is solved by doing this mostly.If the problem still there then remove the ink cartridges and the print head and after few minutes put it back in the printer .If you are still facing this then do it again almost five times & if still your problem is not solved and you still get error code 3802 then probably your KODAK EASY SHARE 5500 All-In-One Ink Jet Printer is in need of servicing by a service professional.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you and Keep using FixYa!
Aug 17, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
Error code 3802
usually 3802 is the cartridge issue
Reseat the cartridge
1.Turn off first your computer .MOve the carrier manually to the center .so you can get the cartridges open the cover
Used a clean paper wipe the area whre the ink goes out on both cartridges as well as contacts or the gold plate .
2.Clean also the area where you put in the cartridges
make sure its clean .
3. Once you return it back .MOve the carrrier manually from left to right 5x with your hands .
4leave it to the center close carier and the cover properly
.5,. Turn on the system ..
Hope it help
3.
May 23, 2011 | Kodak ESP7 PP All-In-One Printer
Getting problem code 3802
Hello thanks for using Fixya
Error 3802 Mean Print head Failure
Turn the printer Off and On, This problem is solved by this mostly.If the problem still there then remove the ink cartridges and the print head and after few minutes put it back in the printer .If the problem still there then do it again almost five times & if still problem not solver and you get error code 3802
then it is probably that your KODAK Esp 3250 Allinone Multifunction Printer is in need of servicing by a service professional.
So go to the KODAK Service Center
Your problem will be solved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation "if it is helpful"
THANKS
Keep Using Fixya
Feb 28, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
What is error code 3802 on an ESP 5 kodak printer?
Turn the printer Off and On, This problem is solved by this mostly.If the problem still there then remove the ink cartridges and the printhead .If the problem still there then do it again almost five times & if the problem still there then final option contact to kodak support
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Jan 26, 2011 | Kodak ESP 5 Printer
Printer wont copy error code 3802
Hi,error 3802 Means Printhead Failure
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it again for (5x)
And if the problem still there,
i will suggest you contact their customer care for further assistance.
Apr 16, 2010 | Office Equipment & Supplies
Error 3802 how do i fix it?
This is a printhead error message.
Reseat the printhead severly times. If the problem persists, you need a new printhead.
May 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printhead Error 3802 I have the Kodak ESP 5 all in one printer. It started printing blank pages a little while ago. Sometimes if I tried to print a couple of times it would eventually come out, so I knew...
3802 Mean Printhead Failuer
Do it that again for (5x)
Tell this to kodak support
And tell the troubleshooting steps you did.
Mar 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak 5300 first said error 3802 now says print head missing or loose
I got the same Problem as listed above. This is the way how I was able to solve it:
  • Remove the color and black ink cartridges and the printhead. (the 5300 Printhead can be removed by pressing a button on top of the carriage and a slight pull --> for better instructions use this official Kodak PDF)
  • Try to clean the printhead and the carriage with a slighty wet cloth from ink. CAUTION!: better not touch the green electronic chip! Be carefull while cleaning.
  • Reinstall the printhead and the ink cartridges.
  • If the printer detects a 'new' printhead just do a calibration and your are done. If not try to print a test page.
Hope this solves the Problem. Best wishes
May 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
857 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Sajid Najmi
Sajid Najmi
Level 1 Expert
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
