Hard drive unpartitioning
I have sony VGN-FS285B laptop with 2 hard drives of 40 GB each, one is near to finish and i am unable to use the second. Couls you help me with resolve this so that I can use the both please.
Thanks
Anwer
  • 1 more comment
  • furness Nov 04, 2008
    This laptop came in with C and D drive partitioned to 40 GB, I can use the C drive while whole of the D drive is empty and laptop recognise it completly. There has been no hardware modifications on this laptop.
    Thanks
  • furness Nov 05, 2008
    All the things that I download or save go to C drive and is only 2GB left while the D drive is 28 GB free. How to get the stuff to D rive which I wan to save on hard drive. I hope this makes it much clearer.
  • furness Nov 07, 2008
    Many thanks, problem solved.
  • 39 Answers
It would help to know why you aren't able to use the second drive. Is it not working at all? Does your computer recognize the drive? Did the second drive come with the computer and, if not (or even if it did), has it been formatted? Is it one drive that has been partitioned into two drives?
If the second drive is a seperate drive, and it has been formatted, you should be able to use it for storage if nothing else but you will still have to boot from the first drive unless you want to reinstall your operating system on the second drive - which really won't solve your problem.
Would it be possible for you to elaborate on the problem a little more?
Posted on Nov 04, 2008
  • 1 more comment
  • GrayesGhost Nov 04, 2008
    Ok - I'm just a little bit confused. If the computer recognizes the second drive, are you having problems accessing the drive and, if not, what are you wanting to use it for other than storage?
  • GrayesGhost Nov 05, 2008
    Ok, yes that is much clearer. Probably the easiest way to transfer the files and/or folders would be to open My Computer and go to your C: Drive. Once you have selected the C:\ drive and expanded the files and folders tree (just click on the + sign beside the C:. This is assuming that you are using XP. If you are using Vista the you will click on the > symbol beside the C:. This will expand the tree and you can then scroll down to the files and folders that you want to move to the D: drive. (An other way of expanding the tree would be to Right click on the C: and, when the menu opens click on Open if using XP or Expand if using Vista. Once the tree is expanded, simply scroll down to the files and/or folders that you want to move and then right click on each in turn. You can select more than one file or folder if you hold down the Control key while you are clicking but I would do it just one file or folder at a time until you get the feel of it. Once you have selected the file or folder that you want to copy, just right click on it and when the menu opens up, click on copy (you can also use the Cut command to save a step if you want to) then switch to the D: drive, open it up and right click inside the D: drive window. When the menu opens up, simply select paste and the file or folder will be copied from the C: drive to the D: drive. You can then go back to the C: drive and delete the file or folder that you have just copied. (As stated earlier, you can also use the Cut command and then when you do the paste, the file or folder will be moved to the D: drive and you won't have to go back and delete them. NOW - keep in mind that this only works for files and folders that are not connected to an installed program. You CAN NOT safely move files or folders from an installed program. (Well, strictly speaking you can, but that is extremely complicated and you will need additional software to do the job and we won't go into that here.) Any files that you have downloaded and haven't installed can be moved easily. Also, even if you have installed the program, you can still move the original file that you downloaded, just not files or folders from the installed program itself.
    Hope that helps - Graye
  • GrayesGhost Nov 08, 2008
    One other thought - with one single drive partitioned into two drives, you can get a program such as partition magic and turn it back into a single drive.
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
I have 320GB hard dsik capacity. But yesterday i have given by laptop to format and install OS(Windows 7). But now i am able to see only 296GB. Please let me know what will happen to remaining space.
There are many reasons.......
Maybe you have available unpartitioned space left in the hard disk. To check this:
1. Right click on the "Computer" icon on the desktop and select "manage"
2. After the Computer Management window appears, select Disk Management. It should show you if you have any unpartitioned drive space.
3. You can up or format your unpartitioned spaces from hereon. may be your harddisk is corrupted and has space 296GB only
or sometimes all drives contains some space for system file in that space is hidden
Jan 22, 2013 | SimpleTech 320GB SimpleDrive External by...
How much memory can a ASUS K501P accomodate?
ASUS K50IP vs SONY VAIO Sony Vaio VGN-SZ44GN? Sony: Processor Speed: 1,800 MHz
Hard Drive Capacity: 100 GB
Memory (RAM): 1,000 MB
Chip Type: Intel Core 2 Duo
Primary Drive: DVD+/-RW
Laptop Size: 13 inches
Features: 10/100 LAN Card, Firewire, Modem, USB, Wireless Network Card
ASUS:
Processor Speed: 2,200 MHz
Hard Drive Capacity: 320 GB
Memory (RAM): 2,000 MB
Chip Type: Intel Pentium Core 2 Duo
Primary Drive: Dual Layer DVD
Laptop Size: 15.6 inches
Features: 10/100 LAN Card, Carrying Case, Modem, Operating System, USB, Wireless Network Card
Mar 19, 2011 | Computers & Internet
Can my laptop sony vaio vgn-fj270 recognise a Hitachi Travelstar 500 GB Hard Drive? I tried everything and nothing work
Is it an external or an internal disk-drive?
What have you tried?
What error-messages did you get?
Nov 21, 2010 | Hitachi Deskstar 7K500 500 GB Hard Drive
320 external hardrive
Most commonly, 297 GB is the formatted capacity of the 320 GB hard drive. You can check if there is any unpartitioned space left on your hard drive. Right click My Computer, click Manage, click Disk Management, locate the hard drive which shows 297 GB (a big reactangle). If this rectangle is all the way from left to right, everything is fine. Else it will also show another rectangle next to it as Unpartitioned space which you can format and use.
May 29, 2010 | Western Digital My Book Essential Edition...
Replace the hard drive
remove all the screws in it and gently remove the cover.
Jul 08, 2009 | Sony VAIO VGN-NR285E/S 15.4" Notebook PC...
Clicking sound from the hard drive near the cd
A clicking hard drive is a dying hard drive. Stop using it immediately. Replace it, then use a SATA to USB or IDE to USB adapter to try to copy off any data you might have that is still salvageable. The more you try to use it, the less chance you have of recovering information.
Jul 01, 2009 | Sony VGN-NR185E/S VAIO NR Series
My sp0411n my hard disk of capacity 40gb it is showing 5gb space my know reason why it is showing 5 gb space
hi first off what OS (operating system) is installed. Did you install that OS?
If the answer is yes ,did you format and partition your hdd or did you format and create separate partitions and left atleast 30 gb unpartition
Feb 27, 2009 | Samsung (SP0411N) 40 GB Hard Drive
Computers & Internet Logo
David Payne
David Payne
