Question about Sanyo CRSR-10 SIRIUS Radio Receiver with Home and Car Kit
Receiver CRSR-10 not powering fully on
Reciever first lost volume but still showed reseption.Turned receiver off than tried to power on again.It will not fully turn on. Powers up to show Sirius Logo than it beebs and repeates the power up boot - this continues indefinitely. Please advise - if service tech is needed please advise as to where I might be able to go for service if it is not something I cannot do myself. I live in the Buffalo New York area. Thanks Gregg
  • timrachey Oct 01, 2008
    I have the same problem. If I leave it off and start it up it sometimes will work fine, but once I start switching channels then I loose sound but the display is fine. If I shut it off and power it back up I just get the Sirius logo and the beep every 20 seconds. Is this receiver shot, I bought a lifetime membership on this unit this new year.
I have the same problem. The final soultion as per Sanyo tech support and Sirius tech support is that radio is dead and there is nothing you can do. It has to be sent in for repair. You can call Sirius and they can direct you on how to best handle the servicing. The gottcha - as always - is the radio only has a 1 year warranty, so it costs more to repair it then to buy a new radio. Hopefully you are still covered by the warranty. This radio is a real PoS btw. If your lucky, you are still covered by the warranty.
Posted on Apr 06, 2007
GREGG, HAVE YOU TRIED TOSSING SIRIUS OUT THE DRIVER'S SIDE WINDOW AND TUNING IN A.M.? IT WORKEDS FOR ME GRUMPA
Posted on Jan 11, 2007
SOURCE:
Reciever slow to turn on volume
Hello Cindi, If the audio does not come on for a short period of time this usually indicates that there is an issue with the audio relay. To try to fix this, I would suggest a reset of the unit. After resetting I would also take another step of doing a power cycle. To do this you will unplug the unit from the wall for about 10-15 minutes to draw out all of the stale power in it. If these two steps do not address the issue then the receiver would have to go in for service. Thanks, FJD
Feb 16, 2016 | Onkyo HT-R590 Receiver
Lost video signal to monitor (TV)
I had the same problem - Onkyo had me reset the unit by holding down VCR and pushing the power button. Make sure you record your settings before doing this - as the unit will be fully reset. This solved the video problem for me.
May 26, 2010 | Onkyo TX-NR905 Receiver
Reciever constantly powers on and then off again
ryantrulling,
If the receiver is powering off/on, there may be an issue with the power supply. Have you unplugged the receiver from the electrical outlet? If not, unplug for 10 seconds and plug back in. This will reboot the receiver and have it reacquire the satellite signal. If the lights do not illuminate after plugging the receiver back into the electrical outlet, please call 1-800-333-3474. We need to replace the receiver.
Ray Calo
DISH Network
May 16, 2010 | DISH Network DVR-625 DTV Receiver /...
Receiver shuts off at higher volumes
The receiver may be too under powered for your speakers or the speaker ohm's may not be matched for your amp.
The reason it is shutting off is likely because the amp is becoming overloaded. At lower volumes the amp can handle the load of the speakers, but at higher volumes the power supply of the amp can't keep up with the power demand the speakers are pulling.
If you were previously able to turn the reciever high without turning off, then there is likley something wrong with the amp or possibly a blown speaker.
Try measuring the resistance of the speakers if you have access to a multimeter. They should normally read 8 ohms for home speakers, but some common home speaker impedances in order from (I'm assuming) most common to least common are are 8, 4, 2(bose), and sometimes 10 or 12 ohms. The lower the number of ohms, the more power the amp will need to put to the speakers and the more chance you could be overloading your amp.
Mar 30, 2010 | Audio Players & Recorders
Sanyo CRSR-10 will not fully turn on.
I just posted about what I think might be a fix in another thread.
Sep 06, 2009 | Sanyo CRSR-10 SIRIUS Radio Receiver with...
Receiver shuts off when volume raised above 10
A fuse breaker or resetting electronic componet device attaced to the audio receiver protects the amp & speakers for destruction! The quality of the amp ,spkers& spks. wires help on choosing for protection shut downs! Of course at 10 volume you risk all of the amp in the receiver , buy a higher quality brand reciever ,intergrated amp, single amp . BE CAREFUL AT THE HIGHER VOLUME RATINGS YOU RISK HEARING DAMAGE! FOR REAL!
Feb 04, 2009 | Philips FR975 Receiver
Onkyo HT-R501 7.1 reciever issues
i have the same problem with a onkyo tx ds494
Jan 05, 2008 | Onkyo TX-SR605 Receiver
No sound
you may have a blown fuse. check that first. Very if it still has a power.
Sep 12, 2007 | KLH SE-6000 System
Denon reciever
Sounds like you are exceeding the maximum power output of the receiver. Try disconnecting some speakers (and switch to A-only mode if your model has multi-zone) and see if that makes a difference.
Dec 31, 2006 | Denon AVR-2801 Receiver
Programming the directv remote to program a sony audio receiver
Go through the process of setting up the remote again instead of trying the volume first use the power off button. In my experience, Sony receivers can be picky and power cycling "will" insure the code set, then try the volume.
Nov 03, 2006 | Directv HR10-250 DTV Receiver
Sanyo CRSR-10 SIRIUS Radio Receiver with Home and Car Kit Logo
422 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Michel Laprise Sr
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
