Question about Graco Spree 511 Holden Travel System Stroller
Immobiliser, Holden S/W 91,Zadi security system
I recently misplaced my immobiliser and tried to turn off the security system in the passenger door with the key(zadi), it would not swich off.
Somehow now the car will not start even though the red security light is off ?as with the dash security light and security beeping warning ? I've tried disconnecting the battery, and since crc'd the security lock in the door and swiched the security system to "off", the car still dosnt start, I have also tried switching it "on" and dissconted battery again the security lights stay off and car still no go nowhere? Please help me! I have run out of ideas.
3 Suggested Answers
  • 7 Answers
SOURCE: holden vx commodore immobiliser
The keys can be duplicated using a diagnostic scanner only if the origional one or your spare key is still working if not a new key can be reprogramed by holden.
Posted on Oct 04, 2008
to fix the key you need a screw driver to pry the to halves of the key casing apart (make sure you have a spare set) taking care not to damage the internal electronic component board, because this electronic circuit board (cct bd) is powered by a 3 volt battery (which is also used to run the bios on computers) can be purchased for about 3 dollars from **** smiths, you need a small pair of side cutters to cut the metal tag connections between the battery and the cct bd taking care to note which is the positive and negative tracks on the cct bd, then using a soldering iron desolder the metal tag connections from the cct bd take care not to damage the copper tracks on the cct bd, try to use the proper desoldering technique (the copper gauze or a suction gun) to remove excess solder from the metal tags because they need to be removed, when the tags are removed from the cct bd there is a small hole on each copper track for the positive and negative reconnections to the newly purchased battery, use light audio speaker wire, black for negative and red for positive, presolder the wire ends first then cut the bear ends down and solder to the tracks taking care not to cross tracks with the solder, then shorten the both positive and negative lengths so the battery and the wires will fit back into the casing of the key and resolder the wire connections to the battery, before closing the key casing test the key to see if the immobiliser is operating then relocate the ring seal and close the two casing together with tape or reglue with arildite glue. if your soldering technique is not up to scratch practice your technique until you feel confident and this should save you about $100
Posted on Mar 11, 2009
91 4 runner immobiliser with an equator immobiliser
I have a toyota4 runner which has an equator immobiliser now she won't fire have spark and fuel but won't start As old as this vehicle is you might think of replacing it with one that fires has spark and fuel.Goodluck )
Jul 20, 2016 | Toyota 4Runner Cars & Trucks
I have a holden viva that has an immobiliser problem
Have you had the battery disconnected? If so you have lost the key programming.
Jun 29, 2016 | Holden Cars & Trucks
Immobiliser on a Ve series 2 sedan 2012 how do I bypass the immobiliser and security alarm
You cannot bypass it which is why the security system is there. If you have a problem with the security system then you will need to transport the car to a Holden service center to rectify it for you. If you start messing with the system you will make your current problem worse. Contact Holden service and explain the problem exactly and they will advise you from there.
If you go to the boot and open the battery compartment on the left side of the boot in the sedan and disconnect the negative battery terminal for a few minutes the system may correct itself when you reconnect the power. If not, then it is off to Holden service to deal with the security issue.
May 04, 2016 | Cars & Trucks
Disabling immobiliser
Sorry dealer only or a auto locksmith
Dec 28, 2013 | 2006 Holden Barina
MERCEDES E220 CABRIOLET 1996 IMMOBILISER RESET
boot is the trunk,I have a 1999 s class and never had trouble like that.Lft battery unhooked for days.Is it not starting? If so your K38 relay might prevent you from starting.
Nov 24, 2013 | 1996 Mercedes-Benz E-Class
How do i by-pass an imobilizer in a vt holden
you could leave the key in ignition in the on position for about 10 to 20 minutes this over rides immobiliser so you can start vehicle. the red immobiliser light that flashes goes out when you can start it. the light is the red LED next to the trip computer buttons
Oct 14, 2013 | 1999 Holden VT
Car alarm went off while unlocking the door, now
you need to reset alarm/immobiliser.lock car with remote, hold button down for 30 secs,then press/hold down unlock button,should reset.another way is with key in ignition/turned on, press alarm button down and hold for 30 secs.this resets immobiliser.toyota
systems vary..depending on market.
Mar 30, 2010 | 1991 Lexus LS 400
Dashboard immobiliser light flashes. car tries to start but doesn
you cant if it has the emobilizer on you would have to know the resister number to install a resister chances are its already gone. there be a reprogram you can do to get it going sometimes when the battery goes dead the bcm will lose some of its programing . hope this helps Tunderboltz.
Jan 27, 2010 | Vehicle Parts & Accessories
Alarm/immobiliser
i cant help you but i need to send you by fax the information,email me reynosaelectronics@live.com.mx send me your fax number.
Mar 06, 2009 | Vehicle Parts & Accessories
Holden vx commodore immobiliser
Aug 02, 2008 | Graco Spree 511 Holden Travel System...
Graco Spree 511 Holden Travel System Stroller Logo
112 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
