Question about Evesham Axis PC Desktop
PC will not turn on
PC does not acknoldge on/off button. I have changed power cable and checked all power switches and buttons.
Before this I had difficulty shutting down the PC and also if you held the on/off switch in to reset there was no response.
Do I need a new PSU?
    Problem Solver:
  • 5 Answers
It seems your motherboard doest get powered or your on/off switch is not working.
please check the power supply if its fan is working ,if it is working please open your PC's cover and you can find the power switches on the motherboard. i want you to shortcut the power pins.
how you can find them ? you can see these pins at the corner of your motherboard . if you can find and shortcut the pins ,and if your power supply works ,then i think problem is your motherboard. you should replace it .
Posted on Dec 17, 2008
Server ON only by pressing power on button continously otherwise server downs & no display
where the cable for the power sw connects to the motherboard your polarity might be reveresed. Therefore, try switching the plug-in the other direction (groung and colored wires).
Sep 18, 2012 | IBM eServer xSeries? 3400
Tip
How to Reset Ink Level Canon MX300 Cartridges
1. Switch off the Canon MX300 and disconnect the power cable.<br /> 2. While press and hold the power button, Connect the power cable to electric socket.<br /> 3. While pressing the power button, press the "Cancel/Stop" button (red button).<br /> 4. Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says "idle".<br /> 5. Press "&gt;" (next button) once "Shipping Mode 3&prime; then Press the "OK" button. Press "OK" again for "without cleaning".<br /> 6. A test page will print.<br /> 7. Open the cover, like you are about to change the cartridges.<br /> 8. Disconnect the power cable again without switch off the printer.<br /> 9. Take out the both cartridges.<br /> 10. Close the cover.<br /> 11. Connect the power cable and turn on the printer.<br /> 12. Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
on Feb 17, 2011 | Canon MX300 Office All-In-One Printer
Tip
Customize the Shut down button windows 7
Customize the Shut down button The default action of the Start Menu's Shut down button is to turn off your PC. If you want to use the button for another action, such as restarting your PC, you click the arrow to the right of the Shut down button and select an action from the drop-down menu.
What if you rarely shut your PC down completely but frequently restart it? You can change the Shut down button's default action to be Restart -- or Switch user, Log off, Lock, Sleep or Hibernate.
To change your default, right-click the Start button and select Properties. On the Start Menu tab, click the "Power button action" drop-down menu and select which action you want to be the default. Then click OK, and OK again.
on Jan 12, 2010 | Computers & Internet
What's your problem?where is switch located that shuts off NV52 when lid closes
go to control panel /appearence personisation /system security go downtoo power optionsedit plan settings (change when comp goes to sleep /change advanced power settingsbox will open power options work way down to power buttons and lid open that up + on battrey open lid close action you will see do nothing open that up and press shut down
that will shut down youre comp when lid closes
Jul 16, 2012 | Gateway NV5215u Notebook
The power button will not boot my computer on
Are you saying that when you press the power button your your desktop pc, and nothing comes on at all? Or is it that the computer does turn on but nothing appears on your screen??? If you recieve nothing at all when pressing the power button on your desktop... Then you may want to assume that it is the powersupply. But before that, check for power cable connection to see if it is loose and fully pluged in. In some computer there could be a switch behind the computer where your power cord plugs which is the power supply and it might be switched to off. If not check to see if the powerbutton is loose, or sticky. If it is, that might trigger to computer not to turn on, and if everything seems okay.... then it is your power supply which had died. But if your computer does turn on and can hera the fans blowing, then you might have couple of cause that causing the computer not to boot probraly. If you can a change explain it in more detail please.
Jan 16, 2011 | Compaq Computers & Internet
Compaq presario sr2020nx will not turn on
Just check the power suply behind computer case , or check your cable power.
May 24, 2010 | HP Compaq Presario SR2020NX PC Desktop
I have acer 3050 is swtich on but no display
try this step:
Turn off the pc remove cables and battery on the laptop Press and hold the power button for 5 seconds Reinsert the cable and battery Turn on the pc If the screen won't turn on, check the power button of the monitor if it is on. If it does not, please call the tech support of Acer 1-800-816-2237 for possible replacement of battery...
May 20, 2010 | Acer Aspire 3050-1733 Notebook
My lenovo T400 will not shut down even when all applications are closed. I have to manually shut it down with the power button
Hi guest, try to turn off the pc by using the power button. Then remove the cables and battery on the laptop. Then push & hold the power button for 5 seconds. Reinsert the cables and battery then turn on the pc.
Check if you will be able to shut down your pc using the operating system..
May 15, 2010 | Lenovo ThinkPad T400 PC Notebook
Don't start up..
If your computer is not switching ON you can try the following in order
1.you have to plug the power cable properly then try changing the power cable.
2. Check C P U power Button is working this can be done by opening the cabinet and switching the computer on by touching the two power button front panel pins on the motherboard with a screw driver if the computer gets started then it is the promblem with the power button in the cpu
3.Try replacing the SMPS with a new one
4. Finally change the CMOS Battery
Thanks
Jan 23, 2010 | HP Compaq Presario SR1115CL PC Desktop
Pc keeps randomly powering off & then back on. Won't stop until I unplug it.Holding down power button won't shut it off. On occasion it will stay on - is able to boot & be used normally while it...
Power supplies usually are culprits in random shut downs, but random start ups is a bit more complicated. You say that when you hold the power button, the computer won't power down. Perhaps you have a faulty switch? Make sure your PW switch cable is securely attached to the motherboard. But I'm leaning more toward a faulty switch or a short in the wires. Seems like a good place to start.
Sep 05, 2009 | E-Machines eMachines Desktop PC
Evesham Axis PC Desktop Logo
87 people viewed this question
Top Evesham Computers & Internet Experts
Simon Clarke
Level 1 Expert
Lakshman P
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
