Question about Canon PIXMA MP830 All-In-One InkJet Printer
Canon MP830 error code 1,0,0
I am getting the above error code, saying "insufficient memory". I have never had this problem before and cannot find it in the online manual. Any ideas? Thanks.
  • 286 Answers
Hhmmm, I would try deleting the reinstalling the driver. Check the manual and see if you can reset the unit to factory defaults. Is it just scanning to a file that causes the error or does copy or send fax also cause the error?
Posted on Nov 07, 2008
My canon mp830 printer is saying error 6500 and i cannot get it to do anything, i have un plugged and re plugged and nothing. what does this error code mean?
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much can user do instead of replacing the malfunctioning hardware. 6500 is generally logic board error code. If the printer is under warranty, you can ask for replacement
Abhilash
$7 is the charge for the service provided.
Oct 01, 2010 | Canon MP830 All-In-One Printer
My screen on my printer says error 6A00 error code. I have turned printer on and off...not sure what is going on
http://www.fixyourownprinter.com/forums/inkjet/39177
See website above for all details to do with this error.
Unfortunately 6A00 is a problem with the sheet feed unit.
Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility.
You most likely will NOT be able to resolve the problem yourself, sorry.
Your service and repair manual is below, for you to download. All error codes and fixes are in there.
www.pdfoo.com/result-pixma-mp830-service-manual-.html
Sep 30, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Our canon Pixma 830 is giving us a error code of 6500. It quit printing in the middle of a page and then wouldn't power up. Now we got it to turn on and now we have this error message
Unfortunately Canon is very little help on this issue... this is what they say..
Issue: ERROR: Error code 6500
1. Press ON/OFF switch to reset the multifunction device 2. The MP830 may require repair
Canon Solution: The MP830 may require repair
Unfortunately, the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.
http://www.usa.canon.com/consumer/controller?act=ServiceLocatorAct&fcategoryid=238&modelid=12804
Oct 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer, ERROR MESSAGE
tbryant619:
Have you checked the ink tanks to verify that they are OK. If 1 of them is empty that could trigger the messages. Look in the user's guide starting at pg 161 for a list of messages. let me know if you need any further assistance. i've pasted the user's guide address link just in case you don't have it.
peace-out
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://gdlp01.c-wss.com/gds/0900002862/mp830_ug_us_v4.pdf
May 23, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Memory full
Check for any saved faxes sent/received and remove. Remove the Canon Software and reinstall.
May 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Insufficient memory in Scanner
if you can't go through the menu and DELETE page in memory (like we couldn't :)
if you turn it off and then pull the plug, it will delete whatever's in memory
morelater the show doctor
Nov 02, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp 830 getting error 5000
Canon site if the link does not work just go to canon.com -> support-> select Multifinction --> Inkjet --> Pixma MP830
Then type in - error code 5000 - (Leave off the " - "
Select #3 - ERROR LCD: Error code (5xxx through 9xxx) appears on the display -
2. Press Stop/Reset and ON/OFF to reset the printer
3. Removing paper jams MP800R / MP830 / MP530
4. The MP830 may require repair
5. Unlock the scanner lock switch (MP800R / MP830)
The links above detail each instruction. If they do not work here then got directly to the Canon Site.
Basically at one point there was a paper jam so clear it and then reset the machine.
Worked for me. Good luck to you :)
Oct 24, 2008 | Office Equipment & Supplies
Canon MP830 Service Error 6000
Canon PIXMA MP830 all-in-one Inkjet Printer
Error code 5C10 on computor screen and on the printer it says 6A00
Jan 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
203 people viewed this question
old marine
old marine
