Question about Earlex IS2000 Canister Steam Vacuum
Vax v-020 carpet washer
Can someone tell which colour wire goes on which contact on the green pump switch on my vax v-020 carpet washer
Vax Problems> The front brushes on my Vax V124
before it stopped working did it smell like burnt rubber at all if so its the belt
Jun 05, 2013 | Vacuums
I need an instruction manual for a Vax Rapide Classic carpet cleaner
i have recently been given a vax rapid deluxe unfortunatley it didnt come with the problem is the water isnt coming out ? please help
Sep 11, 2010 | Vacuums
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
Water lesking from vax rapide carpet washer
i have been using a vax v26 carpet cleaner and the washing water is leaking from the bottom then the solution will not come out has the pump given up?
Jun 07, 2009 | Dirt Devil CE5500 Floor Keeper Upright...
I have a vax rapide carpet washer was using earlier and blew my trip switch noticed that the filter is falling to bits doyou think it can be repaired?
Generic problem for all Vacuums
I have a Vax Rapide
Posted by paulxlyn on Apr 28, 2008
I have a vax rapide carpet washer was using earlier and blew my trip switch noticed that the filter is falling to bits do you think it can be repaired?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Yes, you can contact your local vacuum cleaner dealer and if they don’t carry the Vax Model then feel free to contact the Vax Rapide Factory Manufacturer phone number or the website for further information and to order parts if needed. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
If you have specific questions and you can't find the answer you’re looking for here, please call our Customer Service Department at 877.894.2031
M-F 8AM-7PM EST or check out our Contact Us page for more information.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Vacuums
Vax problem
Could be a bad pump.
Feb 07, 2008 | Vacuums
Earlex IS2000 Canister Steam Vacuum Logo
147 people viewed this question
Top Earlex Vacuums Experts
Are you an Earlex Vacuum Expert? Answer questions, earn points and help others
