Samsung Syncmaster 241MP Flat Screen TV - No Picture
I have purchased a pre-owned Samsung Syncmaster 241MP Flat Panel TV (a super tv when it came out in the late 1990's). I can get sound but no picture. I believe it is an NTSC tv. Is there a fault or will it not work in the UK? Does it need some kind of extras/conversion. Any help would be much appreciated. Thanks
pattersj78
  • 70 Answers
SOURCE: Sony Flat Panel tv with no Picture
Flat panel TV's typically do not have "bulbs," but rather backlighting.  Plasma displays are especially touchy during movement.  I would suggest checking your warranty status, as it's probably not something you can easily repair.  If you wanted to take on the repair yourself, be careful not to lay down the screen, as it will drastically shorten the life of the Plasma display.  I would start with checking the system boards for possible damage, since you did hear a "click," It was probably a fuse, chip, etc.
Posted on Oct 19, 2007
  • 1030 Answers
SOURCE: HDMI Cable - No Sound L42WD22 RCA Flat Panel TV
No sound and a digital picture. i will assume you have no signal on analog rf cable. Thomson(RCA) have been having problem with these sets. The trouble stems from the digital cuircit board. We see alot of these. You used to get the digital board.. they are not availble.. so rca found the component on these that fail.. A VERY SMALL surface mounted fuse. With a lighted magnifer and some fine tip twezzers. we replace these fuses on these boards. Do you have any soldering experence..
Posted on Jun 10, 2008
  • 11 Answers
SOURCE: How to clean a Samsung flat panel TV screen?
Only with the cleaning cloth provided....
Posted on Jul 31, 2008
stonephoenix
  • 563 Answers
SOURCE: Samsung Plasma TV have sound but no picture
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further
Posted on Jul 22, 2009
premtech
  • 934 Answers
SOURCE: no picture on flat panel tv. has sound
Sounds like the digital control board, 6871qch038a Lg Digital Control Module subs to 6871qch038c. But that's just a first something I would check in this unit. Replace also capacitor C19, 630V big blue square cap very common failure for no video. You might want to shop this one thee are a host of problems with this unit that would certainly get some needed attention if a qualified tech were testing it and looked up the bulletins.
Good Luck!
William Rayburn, CET
Premium Technologies
Posted on Oct 05, 2009
Samsung flat screen tv no picture sound only, I have checked all connections and remote still same problem.
The T con board is faulty. It is the board with flat ribbon cables going to the bottom of the screen. It is not hard to replace this board. You can get one from here:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 01, 2016 | Samsung Televison & Video
When powering on my Samsung 55 inches LED TV, the middle/bottom light panel just flash/blink and there is no picture on the TV screen dark/black screen. I would have to let the TV on for 1-2 hours to
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 06, 2015 | Samsung Televison & Video
How do I fix a cracked screen on a samsung flat screen
Simple answer - take the TV and throw it out and buy a new one. It is not economic to buy a new screen and replace it.
Oct 05, 2014 | Samsung SyncMaster 275T+ 27" Wide Format...
My samsung syncmaster 225 md displays a black screen. When turned on it shows picture for 2 seconds then returns to the black screen
My TV had the same symptoms. Opened it up and on the inverter board I noticed that two of the four capacitors near to the output connectors had discoloured and were bulging. Replaced all four capacitors (470uF 25V) and all works fine now
Oct 17, 2012 | Samsung Televison & Video
How do I connect my TV with the VCR Flat screen Samsung
here is the manual: http://www.samsung.com/us/support/supportDownloadCenter.do?prd_ia_cd=N0000347&prd_mdl_cd=LS27HUBCB%2FXAA&prd_mdl_name=275T
the TV you are using has to be connected with AV devices and can only be connected to video. You need speakers if you want sound.
May 26, 2011 | Samsung SyncMaster 275T+ 27" Wide Format...
Hi! i just purchased a Samsung SyncMaster P2370HD P2570HD flat screen tv and I was wondering if you are able to tell me the correct settings to put on the TV to get the best picture? The picture does not...
Hi Suzette my name is Roety,
I can help you with your issue ,
First of all make sure you have an HD signal connected.
These days using a non HD box will produce a bad picture on an HD TV.
If using a cable/Dish box set the output resolution to 1081i only,
for picture controls set them all center and max out the picture/contrast control
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 28, 2009 | Samsung Televison & Video
The screen will not come on
i think lose power
i hope i can solve your problem
Sep 02, 2009 | Samsung SyncMaster 730MW 17" Flat Panel...
Screen size changes on its own
Use the format button to switch betwen auto, widescreen (16:9), letterbox (4:3), and other options. not all formats are available on all channels.
Fame !
Jun 23, 2009 | Televison & Video
Syncmaster 710 mp picture in picture
Do you have the remote with it? It is the PIP button. When I press that button, I get the small TV picture in the upper right hand corner of the screen.
Jun 24, 2008 | Samsung SyncMaster 710MP 17 in. LCD...
Samsung syncmaster 241mp
have you managed to get this repaired? i have the same problem...
Sep 17, 2007 | Samsung 241MP 24 in. HDTV-Ready LCD...
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
