SOURCE: belling dishwasher IDW604
there is a small plastic catch in the door side of lock which loks arround the bar on the washer side of the lock somtimes it stays in you can click it out with a knife or simillar sould work fine after that
SOURCE: I keep getting error code E3 on Belling IDW604
The E3 code is normally related to the overheating of
the water during a wash.There is a thermal switch that
has a manual reset button mounted on it.The button is
normally red in colour and is about 3mm in diameter.
The switch is accessed by removing the silver plate
mounted beneath the door.Simply press the red button
to reset.
Tried all solutions, many thanks, but in the end nothing worked. Called out service who said motor was damaged and needed replacing. When he came to fix it, found a leak which had damaged the motor and said leak couldn't be fixed, so no point replacing the motor. Looking at New machine, :-(
