Question about Kitchen Appliances - Others
Breville grill hg 14
Antony worrell thompson electric grill no temperture at all, fuse ok . Element not open circuit. inside there is a bi metalic operated temperture control, the tips on this look a bit dirty and do not make when switch adjusted they are open all the time with power off should they be normally open or closed. trying to source temperture control
2 Suggested Answers
  • 248 Answers
SOURCE: Breville HG11 Antony Worrall Thompson Health Grill
web search-breville hg11-click on antony worrall site for parts and suppliers
Posted on Oct 08, 2010
I have misplaced my manual for my Breville Anthony Worrel Thompson BR11 breadmaker, could you please tell me when I can download the manual.
there is another solution listed alredy for this model
http://www.fixya.com/support/t4630596-anyone_know_download_manual
and it didn't look like the manual was available.
However, I would suggest that you contact Breville in your country and start with them. They may be able to suggest another model with similar function and you can then download that manual from their support page on their website.
If you start with www.breville.com and browse to your country, then try "Contact Us"
May 05, 2011 | Microwave Ovens
Soap remains in dispenser after completed cycle and dishes are not clean
Hello laura.... there are three possible causes of the dispenser not opening:
1.Timer
On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary. 2. Bi-metal switch or wax motor A bi-metal switch is a simple electrical device that deforms when electricity is applied to it. The degree of this deformation can be engineered to concise standards. The timer energizes the bi-metal switch inside your dishwasher door--directly behind the detergent cup--when the detergent cup should open. When energized, the bi-metal switch deforms away from the detergent cup latch, which opens the detergent cup. If the bi-metal switch is defective, it may not deform enough to open the cup. If that happens, you need to replace it. On some dishwashers, the bimetal switch is wired through the heating element or motor circuit. If the element is broken (or open), or if the motor is drawing low current because of a low-fill situation, the bi-metal switch doesn't open properly. Newer dishwasher models use a wax motor instead of a bi-metal switch. It's a sealed unit with wax that heats up and pushes a piston through to open the door. The wax motor, controlled by the timer, mechanically opens the door. 3. Detergent cup, itself The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly That said, one way around this is to simply add the soap or the soap tab into the dishwasher proper, not into the cup. Joe Thanks for choosing Fixya!
Mar 13, 2011 | Maytag Dishwasher
Dispenser does not work
Hello there:
Timer On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary. Bi-metal switch or wax motor A bi-metal switch is a simple electrical device that deforms when electricity is applied to it. The degree of this deformation can be engineered to concise standards. The timer energizes the bi-metal switch inside your dishwasher door--directly behind the detergent cup--when the detergent cup should open. When energized, the bi-metal switch deforms away from the detergent cup latch, which opens the detergent cup. If the bi-metal switch is defective, it may not deform enough to open the cup. If that happens, you need to replace it. On some dishwashers, the bimetal switch is wired through the heating element or motor circuit. If the element is broken (or open), or if the motor is drawing low current because of a low-fill situation, the bi-metal switch doesn't open properly. Newer dishwasher models use a wax motor instead of a bi-metal switch. It's a sealed unit with wax that heats up and pushes a piston through to open the door. The wax motor, controlled by the timer, mechanically opens the door. Detergent cup, itself The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly
Jan 13, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a whirpool dishwasher model #du980qpd85, soap door don't open. can you tell me what makes it open and what the problem could be/
Hello ramward. There are three reasons why the soap door won't open. The first is soap buildup. This is a common problem and requires old fashioned elbow grease, and hot water, and lots of cotton swabs. That said, read on:
2. On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary.
3. Bi-metal switch or wax motor A bi-metal switch is a simple electrical device that deforms when electricity is applied to it. The degree of this deformation can be engineered to concise standards. The timer energizes the bi-metal switch inside your dishwasher door--directly behind the detergent cup--when the detergent cup should open. When energized, the bi-metal switch deforms away from the detergent cup latch, which opens the detergent cup. If the bi-metal switch is defective, it may not deform enough to open the cup. If that happens, you need to replace it. On some dishwashers, the bimetal switch is wired through the heating element or motor circuit. If the element is broken (or open), or if the motor is drawing low current because of a low-fill situation, the bi-metal switch doesn't open properly. Newer dishwasher models use a wax motor instead of a bi-metal switch. It's a sealed unit with wax that heats up and pushes a piston through to open the door. The wax motor, controlled by the timer, mechanically opens the door. Joe Thanks for choosing Fixya!
Nov 21, 2010 | Dishwashers
Soap dispenser will not open automatically in a wash cycle
Hello there:
Please follow thew following solutions i have provided below
The detergent cup doesn't open When the detergent cup or dispenser will not operate properly or doesn't open, check these:
Sep 26, 2010 | Frigidaire Dishwashers
When i choose normal wash and the cycle has been complete I open up the dishwasher and at that time the detergent pocket opens up and drips out the detergent. My glasses are all chalky and unclean
When the detergent cup doesn't open, check these:
Timer
Jul 16, 2009 | Dishwashers
Not using salt
Timer
Jul 06, 2009 | Neff 18 in. S5943 Slim-Line Built-in...
Breville KM1 Antony Worrall Thompson Food Mixer
Hi, This might sound a bit strange but did you ever fix your food mixer, if not do you still have the beater, and ballon whisk attachments as i have the same machine but iam missing these parts. maybe you would consider saleing them if you do.
Thanks
Mar 04, 2008 | Dishwashers
Kitchen Appliances - Others Logo
103 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
