Question about Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi ZDT6252 Levelling
Machine has stopped working. I need to pull it out from the housing but the ceramic floor was fitted after the dishwasher.
I have undone the levelling screws at the front but it is now catching at the back.
I can't find any details about the rear levelling or how to get it out.
It appears that the inlet is blocked so it won't let in the water.
Can you help please.
John
  • sooty123 Nov 03, 2008
    John
After having the same problem I resorted to sawing off the rear foot, only to then discover that there is a crosspoint screw on the middle at the fron that winds up or down the rear foot.
Posted on Aug 06, 2009
How to reset Zanussi zdt6252 dish washer
To reset a programme in progress, open the door and press the push button of the programme under way for more then 1 second, until the corresponding indicator light goes out. The dishwasher is now reset and you can select a new programme.
Dado
Mar 03, 2015 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
I have a zanussi ZDT6252 - i had to call out a plumber to replace the hose which feeds in the water. Two loads after that the machine has just stopped - no lights and some water left in the bottom of the...
Possible that the main controller board is not working and so the drain was interupted or stopped thus resulting in the water remaining within the drum.
You will need to trace the main power to the control board and see if there was a break in the wire or a possible failure of the controller unit. If there is no output when plugged and start is initiated then the controller is a suspect.
Take estimate and decide.
Sep 03, 2011 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dishwasher power there but wont fill up with water makes a slight buzz sound any ideas please ?? It's a Zanussi zdt6252 by the way..
The slight buzz is coming from the water inlet valve solinoid. It's OK.
But check whether water is getting into the inlet tube of the washer. Check the filter at the rear of the dish washer body wher the inlet tube from your water tap is connected.
Apr 05, 2010 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi ZDT6252 fills with water when not in use
Sounds like you have a leaking inlet valve. The best option is to replace it with a new one. It does have overfill protection on it but this may not work if its leaking.
Nov 13, 2008 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi zdt 6252
I had the same problem with Zanussi ZDT 6252. To fix it, turn power on, close door fully, then open door, turn off then turn back on again. If you follow this sequence the machine is reset and you can select programs again.
Dec 26, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi zdt6252 stops on 'Rinse & Hold' midway thru Wash Cycle consistently...
The problem here is being caused by Blocked Filters in the Water suppoly In line/pipe. There are two(2) filters in this line, at the water connection point and at the Washer connect point(one at each end). If these filters become blocked, then the result will be a restricted water In-Flow and hence the Rinse & Hold Status. Disconnect the Water-Supply pipe and remove the plastic filters giving them a thorough cleaning before replacing them. All will be rectified by this action. Peter...
Jan 02, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
143 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
