Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
No power light comes on
The door-top power light does not come on and the dishwasher will not start. Circuit breaker and GFIs are fine. Any ideas of some component that might shut-down the dishwasher?
  • Anonymous Mar 16, 2014
    everything is controlled by a a small switch and a button in the top of the door. You push the switch in and the red light comes on, so there is power. But the button does not work now, so you cannot scroll through the settings. When the red light is on and you shut the door the dishwasher no longer works (which it used too). Any one have any ideas please.
    President:
  • 878 Answers
Bone, you probably have a blown thermal fuse that is located on the control board, easy fix. First check your wiring to the diswasher behind the bottom panel. I will attach a photo..Catriver..post back.
Posted on Sep 28, 2006
Hi my my Kic fridge tripping electricity what
There are two things with different answers- \'trip\' normally can apply to either the circuit breaker (~15-20 amperes) or the Ground Fault Interrupter where the latter can be part of a circuit breaker or a wall-mounted AC outlet.
Circuit (overload) breakers prevent fires when appliances (or others) and GFIs prevent death by electrocution.
The first (breakers), can trip when motors and transformers fail, the second (GFIs) trip when a faulty current path is detected that can allow hazardous AC voltages to be present on accessible parts.
Both circuit breakers and GFIs can fail to perform correctly and some training and a multimeter is required to accurately determine the source of the problem.
Sep 19, 2014 | Refrigerators
How do I reset the control panel on my dishwasher?
could be wites in the door at the hinge, the microswitches in the door lick assembly, or if it is a series of flashes it could mean a code depending on your model number. Last to check is visuals on the control board for burning, or any loose wiring.
Jun 18, 2014 | Maytag Dishwasher
Dishwasher not working after circuit breaker turned off
Circuit breaker tripped because of fault in dishwasher, which is why it no longer works. Sorry but I can not tell you what dish washer fault is.
Sep 13, 2017 | Bosch Dishwashers
My Kenmore Ultrawash Quietguard Standard dishwasher won't start --or light up. I've checked the wall switch and circuit breaker and both seem okay. Darek Johnson darek_johnson@yahoo.com
Most dishwashers and other appliances using water, are protected by a Ground Fault Interrupter or GFI. These will sometimes trip without having detected any dangerous leakage current and others will get oversensitive causing them to trip well below their design current. A GFI wall socket will have two buttons on it; one to 'test' the other to reset. On some brands, when they are tripped, the reset button moves only a little further out and may not appear tripped. GFIs are also found combined with circuit breakers that also differ in appearance from the unprotected type and will also have a reset button. If your dishwasher is plugged in under the kitchen sink, check its appearance to see if it is GFI equipped.
BTW, these can be used in one location and connected so all of the wall plugs on the same circuit can be served by a single GFI equipped breaker so check any others nearby as well.
If a GFI refuses to stay set, it may be actually detecting some leakage current of a dangerous level so don't assume the GFI is bad, the appliance on it its circuit may have developed an internal problem.
Feb 02, 2011 | Kenmore Dishwashers
GE Profile GSD4010202AA Built in Dishwasher acts as if no power
1. turn breaker off to diswasher. 2. remove bottom access cover. 3. remove cover over electrical connection box on right side. 4. hold each wire nut connector and firmly tug on one wire at at time to make sure none of the wires pull out of the wire connecor nuts. A loose connection here is more common than you might think.
If those are all OK, turn breaker back on and make sure you have power there. (120 volts black to white) If that was OK, then check door latch switch inside door at the top center and wires passing through door at the bottom of the door.
Jul 26, 2010 | GE Dishwashers
Kitchen circut was accidently turned off. Now whirlpool gold disher will not work(unit was not running and the door was not closed all the way when circuit was turned off, All circuit breakers are on)...
You can put the unit into diagnostics (press the following keys in order within 6 seconds HEATED DRY, NORMAL, HEATED DRY, NORMAL all the lights will come on and it will start a diag cycle) and see if it recovers. If not, you are looking at a electronic control, and yes you CAN change the part yourself.
Mar 08, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
GE Triton not working
Jitterbugclu-
I may have the solution. Husband just turned off power to dishwasher via circuit breaker. Waited around 30 minutes.
Restored power and Triton came back with normal lights.
I just ran a cycle and all was well. Hope this helps you.
My fingers are crossed because I don't know what happened but did read on another site that this should be the first thing you try before expen$ive repairman.
Reply back if it works!
TootieC
Dec 25, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
...dead
CHECK DOOR SAFTEY SWITCH OR TIMER MOST LIKE SWITCH ASSOCIATED WHEN DOOR IS CLOSED
Jan 17, 2008 | Bosch 23 in. SHU303 Built-in Dishwasher
Won't turn on
The door switch is definitely not the problem if the indicator lights are not coming on. These lights are supposed to come on when the door is open.
The problem is 1 of 3 things:
1) No power to outlet that DW is plugged into;
2) Bad connection where power cord is connected to dishwasher (see very bottom front, under kick panel)
3) Some problem internal to the DW (eg., bad switch, shorted wire, etc., )
Our SHX46A is definitely having problem 3, but Bosch's manual gives zero help. So, off to find more info online or, lastly, to call Bosch repair person. Sigh.
Jun 13, 2007 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Kenmore Elite Dishwasher 13863 will not start
I would check the door interlock, an electrical switch that prevents the dishwasher from running whenever the door is open. Maybe a loose wire there.
Feb 25, 2007 | Kenmore 13863 Stainless Steel Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
318 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
