Hp 1320 prints blank pages
I would need more information on the same.
Is the printer printing blank pages, while printing configuration, internal test pages, or is it happening while printing from PC.
Please advise.
- Nikhil
Hello please sen cataloge for me
SOURCE: hp laserjet 1320 printing blank pages
Hi, If you have replaced the toner acrtridge and still the printer is printing blank pages than it please make sure you have removed the maler strip of the toner cartridge if yes than perform engine test page of the printer wherein remove the side panel and there is a small button to press and it print engine test page and that will bypass the formatter if the engine test page is also blanik than it is the issue with transfer roller (Which create the image) Power Supply( Create image on transfer roller) or Laser/Scanner assmbly which creates the laser image on transfer and all these three parts are not customer replacable(Hardware Issue) and customer need to get the printer repaired by HP Authorised Engineer.
Check whether the "print preview" on the screen shows blank too...
Make sure the document you are printing doesn't have blank pages. You may think that it might be one page, it might be two. Somehow you may have inserted a blank page or two.
Running a printer operation check
If you are unable to determine the source of the problem, performing a printer operation check can help you determine whether the problem comes from this product or the computer. get more information from here....... http://answers.yahoo.com/question/index?qid=20100905152100AAMq5Iv
SOURCE: After cleared paper jam, HP LaserJet 1320 prints blank pages
Yes you can replace the transfer roller, but check to make sure the roller is firmly seated into its holder and that the springs are contacting the metal shaft.
Good Luck
I have the same problem, it will not print test pages or config reports
My HP 1320 printer is printing blank pages and it will not even print test pages etc. i have changed toner so that is also not the issue
What if your printer suddenly starts printing blank pages? Well, the first thing you will do is to check the ink cartridges and refill them as per the requirement. But this is not the only reason your printer is printing blank pages.Read More here..
Why Is My Printer Printing Blank Pages?
